Question about Fahrenheat Electric Convector Baseboard Heater, 240 Volt
Hooking up the heater
I'm having a problem figuring out what wires go where. Can you explain that to me?
  • golf2day626 Nov 15, 2008
    It's 240 and the wire colors are black and brown & the ground wire.
  • 6,674 Answers
240 VAC or 120 VAC, and what colors are on your heater?
Posted on Nov 15, 2008
Tested Elec and have 240 at wall box but when hooked up (wired) unite does not come on.
How did you test for 240?
How is the unit wired?
Which brand and type water heater do you have?
What product are you hooking up to 240V?
What does product label show?
Is this electric tank-type water heater, or electric tankless?
Is the water heater new? Or older heater?
Have you pressed in reset button on tank-type?
Add a comment for followup.
Sep 16, 2013 | Rheem Water Heaters
Im hooking up a base board heater for the first time with a non programmable thermostat that has 2 black wires on the thermostat. I'm hooking it up to a two pole breaker that means back wire to top screw...
Hello there
It sound alright but You should draw out a wiring diagram on paper first before you tackle the job that way you know you're doing it right.
Good luck Dickson
Nov 04, 2010 | Fahrenheat Electric Convector Baseboard...
Replacing 9420 robertshaw hooking up 6300B honeywell. I have a wire (W2) i don't know what to do with?
If you have a single stage furnace, you do not need that wire....if you have a two stage, then you cannot use that thermostat because it will not do 2 stage...
Apr 28, 2010 | Honeywell Focus 6300B 5-2 Days...
Line voltage Tstat installation Dayton D-F79 elctric shop heater
If I understand your post correctly....You state that you are hooking up a 240v heater and towards the end you speak of removing jumpers...W2 terminals..ect. It sounds to me your trying to us a 24v low voltage thermostat instead of a Line voltage thermostat.That's what I'd take a look at.
Dec 16, 2008 | Dayton (3E379) Heater
Blower fan
you could use only 2 wires, R and G terms all you would get is blower fan. so on stat make sure you connect to R and G also. also did it have a fresh air return and you miss hooking up those wires, i have seen that before.
Dec 15, 2008 | Goodman GMS90703BXA Heater
Hooking up my heater
The white is the common neutral, it is probably a 3 wire unit, and you are missing the ground wire. Check inside the control panel and see if someone wired it using the white wire for the ground, it will be screwed into a terminal lug. Check the schematics to see if the unit requires a common neutral to run the controls.
Nov 24, 2008 | Dayton G73 Utility Heater
Fahrenheat Electric Convector Baseboard Heater, 240 Volt Logo
69 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
