Question about Canon EOS 400D / Rebel XTi Digital Camera
Canon XTI Flash problems
My Canon XTI flash pops up and no flash. There is a white light that flashes on the front of the camera that I have never seen before. I have changed the battery, thinking that would help.....but no luck. I did tap the flash and it flashed, but did not work with the camera. Is there a bulb that could be lose or something? Please advise,
Thank-You......
  • littlemoon54 Nov 29, 2008
    Thank-you for taking the time to help me resolve my issue with my camera. I am sending it back to Canon and hopefully it will bring a smile back to my heart. Needless to say, I was heartbroken and you gave me the faith to believe it could be fixed.
    Thanks again,
    Diana
    Problem Solver:
  • 15 Answers
I personally would recommend getting expert help - flashes produce a high voltage flash (several hundred volts to several thousand), and can be dangerous - even this camera's flash gun. It sounds like it is shorting when you tap it, so likely a loose connection. You can't do it yourself, so get proper advice. You can try your local camera dealer, or better, send it back to Canon Service. If out of guarantee, get a quote for looking at it. They will likely have come accross this before, so don't worry - it is likely fixable .
Hope this helps
Posted on Nov 29, 2008
My camera rebel xti flash will not work all of a sudden, what could be the problem and how may I fix it?
Does the flash pop up when you try to take a picture in low light in the Green Box Mode? If the flash does not pop up the problem may just be that something sticky is keeping it down. If it pops up but does not fire, the problem is usually either a bad flash tube or the wiring to the flash has broken where the flash head pivots up and down.
When the flash is fully charged the capacitor retains a voltage of over 300 volts even when the camera is turned off and the battery is removed. I've seen several cameras where the owner tried to repair the flash and ended up burning out the entire Main PC Board.
Bob Kilbourn www.camerarepairs.com
Sep 29, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
We have a Canon rebel XT EOS the flash pops up no matter what the
Frustrating I am sure. I had the same problem on my first XTi. I cannot remember what the settings were, but I think I was set for portrait and had flash set as the white balance default source. Therefore the camera always popped up the flash assuming that I wanted or needed fill flash.
Change you white balance to sun/shade/tungston etc as is appropriate, choose a faster ISO speed in lower light levels and try using the P or Tv mode and use a shutter speed that generates a middle range aperature for your particular lens.
Jan 18, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Canon rebel xti flash pops up but says it was obstructed
This is a problem known by Canon, you will have to have it serviced.
Oct 30, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
I recently bought a used canon EOS 400d which was
Be aware that the built in flash does not pop up automatically in all picture modes. Try it when in the different modes (on the mode dial) and see what I mean. Does it popo up when manually opened ?, (small button on front left hand side of the viewing pentaprism/flash housing.)
Oct 02, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Flash
mcomijohns. WHAT ARE YOU SUGGESTING!!!! Stop.
Lakshmy Be aware that the built in flash does not pop up automatically in all picture modes. Try it when in the different modes (on the mode dial) and see what I mean. Does it pop up when manually opened ?, (small button on front left hand side of the viewing pentaprism/flash housing.) PLease let u shave more information for a proper solution.
Sep 26, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
The built-in flash on the Canon Rebel XTI won't flash.
i am having the same problom try this i just found this ... http://www.fixya.com/support/t1021194-flash_not_working
Aug 20, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
EOS Rebel XTi 400D flash not popping up
Flash will automatically pop out only in AUTO mode, if the camera needs some additional lightning. In manual modes, you should use the flash button located at the left down side of the flash compartment, to manually force the flash to pop up
Jul 13, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Built in flash problem
most likely you have set the camera to the auto mode and you are shooting in a place with plenty of light.
your camera has a sensor which activates the flash when needed.
you can set the camera to the manual mode so that you can chose the flash to work even in the day.
Aug 11, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon Rebel XTi/EOS 400D
I made the mistake of putting ahotshoe protector from my old camera on the new EOS 400D. It stopped the flash from popping up. I took it off and things now work.
Mar 11, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
How to switch on Auto Flash in Auto mode
Put the camera in "P" and press the flash button above the lens release. If the flash pops, than you probably just have too much light to need it when you are in auto. The flash button is not active in auto so if the xti doesn't want the flash in auto, u can't make it fire. If the flash button does not make the flash pop in "P", search this site for another post about flash not working and u will find that this could be the flash deactivation button in the hot shoe sticking. Not likely though with a new camera unless u have had a speedlite mounted alot.--
I found the answer and fixed my flash. Look on http://photo.net/bboard/q-and-a-fetch-msg?msg_id=00ODWf
This will describe how, if you have been using a speedlite alot, than the little tab under the shutter release side of the hot shoe can get bent down thus constantly pressing down (toward the bottom of the camera) the small button which deactivates the pop-up1.gif flash even when the speedlite is not attached. Just bend the tab up a little with a jewler's screwdriver, turn the camera off and on and voila!! Fixed!!! Dan describes pushing the tab down, but on the xti, the tab needs to be bent up to release the flash deactivation switch and fix the problem. Thanks to Dan D on photonet for saving me a service call.
Dec 26, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
Canon EOS 400D / Rebel XTi Digital Camera Logo
142 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
