Question about Sony CPD E230 17" CRT Monitor
Sony e230 display cable replacement
How do i replace my desplay cable myself... my original cable is damaged... i have to twist and bend to get the display working...any helpful site that describes with illustrations??? plz help
  • Larry Howard Apr 27, 2008
    Sony CPD 17SF2 17" monitor. Need pinout information for monitor end vs DB15. This monitor is in an industrial setup with touchscreen, and the cable has been damaged by a "technician".
    So far, I have found nothing (calling Sony resulted in "Discontinued". I knew that already. If this was anywhere else, I would simply tell the plant to buy a new one.
    I suspect my problem is about the same. And, I suspect Sony used the same cabling throughout the series.
    Any help will be a cost saving to the customer, and get the system up and running.
    Larry Howard
    lth@icelectronics.com
  • 180 Answers
You will get similar cable in the component market. Just pull out the cable after removing back cover of the monitor, and fix the new one.
Posted on Apr 08, 2008
No display on Sony VAIO vpcf115
check the internal display cable connection "LVDS" cable,
maybe you had trouble connecting it back fully, or you damaged it durring the replacing of the MB
Jan 23, 2014 | Sony Computers & Internet
Lcd screen
Well, you're not going to fix this without opening up the camera.
The LCD screen should have to wires going to it. One is for the light that illuminates the LCD. That one is obviously working. The other is for the LCD itself - it sounds like that isn't. Either the LCD needs replaced, or that cable is loose or damaged. I'd suggest opening up the camera, finding that cable (it will likely be a thinner cable than the other), and checking for loose connections, or an obvious break or sharp bend in the cable.
Unfortunately, even if you find the cable is damaged, I'm not sure you can get it replaced. If you're not confident you can take this apart and put it back together properly, I'd suggest either taking it to a repair shop, or just using it as is. I'd hate to see you damage it further. If you are confident, however, check that cable. If it's good, contact Samsung about a replacement LCD.
-Dyllan
Dec 20, 2007 | Samsung Digimax i5 Digital Camera
Sony walkman nwz-e354 screen went black, but still functions, i twist the device a bit and the screen goes back to normal until i let go. can i fix this myself?
As said cables, possibly loose or damaged, Are up up to it, open it up and have a look, You are the only one who knows if you can do it, It is possible
Mar 14, 2013 | Sony Walkman Nwz-e354 Black Digital Media...
How to replace the display of a sony DSC-W55 camera
It's easy - take it apart carefully and hopefully you have the replacement display, then make sure you connect the ribbon cable exactly like the old one to the main board. Then carefully reassemble. Make sure you put the screws back in to there original areas.
Dec 29, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Desplay not working, can I change the desplay and cost
Yeah you can replace it. I would suggest you to go to a mobile repairing shop and get repaired or you can to the service center. They'll charge you for the new display and for their service.
Good luck.
Thanks for using FixYa.
Jun 17, 2010 | Motorola Mobility RAZR2 V8 Cellular Phone
LCD screen not working on my Sony Hc 42 camcorder
Hi
The LCD cable is faulty. You need to replace the LCD cable from SONY authorised service center.
It's a common problem as this cable is bend each time when we open the LCD screen, so the cable become faulty.
Aug 11, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Display problem
check ur power outlet and cable and make sure its plugged in well........also check power cable if not damaged........if so get it replaced
also ur antenna may got a loose connection on the mast or antenna input on ur pc......
Jul 03, 2009 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
I'm looking for the 2000 isuzu rodeo 3.2L v6 connecting rod bearings torque specs.
1. Check the connecting rod alignment If either the bend or the twist exceeds the specified limit,the connecting rod must be replaced. Bend per 100 mm (3.937 inch) Limit: 0.15 (0.0059) Twist per 100 mm (3.937 inch) Limit: 0.20 (0.0078)
2. Measure the connecting rod thrust clearance. Use a feeler gauge to measure the thrust clearance at the large end of the connecting rod If the clearance exceeds the specified limit, the connecting rod must be replaced. Standard: 0.16 mm - 0.35 mm (0.0063 inch - 0.0138 inch) Limit: 0.40 mm (0.0157 inch)
3. Measure the oil clearance between the connecting rod and the crankshaft.
    1. Remove the connecting rod cap nuts and the rod caps (12). Arrange the removed rod caps in the cylinder number order.
    2. Clean the rod bearings and the crankshaft pins.
      1. Carefully check the rod bearings. If even one bearing is found to be damaged or badly worn, the entire bearing assembly must be replaced as a set. Reinstall the bearings in their original positions. Apply plastigage to the crank pin.
      2. Reinstall the rod caps (12) to their original positions. Tighten the rod cap nuts. Torque: 54 Nm (40 ft. lbs.) Note: Do not allow the crankshaft to rotate.
      3. Remove the rod caps.
        1. Measure the width of the plastigage and determine the oil clearance. If the oil clearance exceeds the limit, replace the rod bearing as a set. Standard: 0.019 mm - 0.043 mm (0.0007 inch - 0.0017 inch) Limit: 0.08 mm (0.003 inch)
        2. Clean the plastigage from the bearings and the crankshaft pins.
May 21, 2009 | 2000 Isuzu Rodeo
Compaq Presario Laptop (M2000 series) hinge
Hello Wendy names Nick and just done hinge work on the Presario V5000z and readin up on your problem my suggestion would be lookin on ebay or various sites for the hinge then go about replacing it.
Steps involved in replacing the hinge start with removing power and battery
Next come the more difficult step, removing all the screws fron the bottom of the unit (this is done to gain access to the wireless cables which run from the wifi card to the lcd display)
once the base is removed then you carefully use a flat head screw driver an near the top row of keys (while pressing a few of them down) you will see a few notches which you can pry off the top cover giving you access to the lcd screen connector and bracket anchoring screws.
hopefully you disconnected your wireless antenna leads by now, and also disconnected the lcd cable from the board.
now you have the lcd display free from the base, now to change the hinge.
under the lil rubber circle pads are screws holding the brazel to the front of the lcd, this should be removed to get access to the lcd itself and thus the hinge brackets.
remove replace carefully i might add. then do everything in reverse to get the system reassembled and there ya have it
hinge has been replaced
P.S. careful steps should always be taken to prevent shock damage to any computer system when working on internals, also mind bending and pincing cables since they can most times be easilly damaged
Aug 18, 2008 | HP Compaq Presario V5000Z Notebook
Sony CPD E230 17" CRT Monitor Logo
75 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
