Question about Lexmark Office Equipment & Supplies
How do you install printer cartridges? - Lexmark Office Equipment & Supplies
  • JTAtlanta228 May 11, 2010
    what type of printer do you have?
    Guru:
  • 558 Answers
See this and let me know if it is helpful for you:
This is my Tips posted here in FixYa related to all printers:
Drivers and Installation problem
or
http://www.fixya.com/support/r1133275-drivers_installation_problem
Thanks,
Scott
Posted on Nov 15, 2008
  • Puneet Jain
    Puneet Jain Nov 15, 2008
    Regarding Cartridge if it is Inkjet ; Pull out the wrap from the Contact strip of Cartridge and from nozzle then put it in the Carriage rack of printer firmly till you get the clicking noise.
    For Toner in case of Laserjet printer: Remove the wrapp and a thin strip to be pull out before using the Toner first time.
    Then open the top cover where you find the old Toner and replace it. Thats All about it.
    Dont vote if you not like the solution! Vote it Helpful or FixYa if you like and do not have any further querry.
Colour ink cartridge not reconise. replace colour ink cartridge.cod 3603
To resolve the issue:
  1. Make sure you install the correct type of KODAK Ink Cartridge for your printer. Currently we offer two types of ink cartridges (10 Series and 30 Series). Installing the wrong type of ink cartridge may result in this error. You will need to install a new, correct type of KODAK Ink Cartridge.
    NOTE: For more information, see Which ink cartridges to buy for all-in-one printer.
  2. If you are using the correct type of KODAK Ink Cartridge, reinstall the color ink cartridge.
    1. Open the printer access door.
      NOTE: If the ink cartridges don't move to the center, see Printhead and ink cartridges don't move to center with access door open.
    2. Wait until the printhead is idle and silent, then pinch the latch on the color ink cartridge with your thumb and forefinger and lift it out of the printhead.
    3. Install the color ink cartridge back into the printer, making sure to press down on the thumb tab until it clicks into place.
    4. Close the printer access door. For printers with LCDs, follow the instructions on the LCD screen.
      For more information on installing ink cartridges, see the Extended User Guide for your printer. Review Maintaining Your Printer - Replacing ink cartridges.
  3. If the error continues, restart your printer:
    1. Turn off the printer by pressing the power button.
    2. Wait five seconds.
    3. Turn on the printer.
  4. If the error continues, and you have extra, new KODAK Ink Cartridges on-hand, try to install a new ink cartridge (or a set of new ink cartridges).
  5. If the error continues, contact us.
When the issue is resolved, we highly recommend that you upgrade the firmware for your printer for optimum performance:
  1. Locate and select the firmware for your printer.
  2. Follow the instructions to install the firmware.
Source: http://support.en.kodak.co.uk/app/answers/detail/a_id/39315/selected/true
Jun 07, 2011 | Office Equipment & Supplies
Re: The printer will not recognize the installing of a new color cartridge.
after installing a new cartridge you need to open the program for your printer tray and reset your cartridges so that the printer and pc reconize the cartridge is full
Sep 19, 2007 | Dell 942 All-In-One InkJet Printer
How do I install the printer cartrige? I do not have the booklet...
  1. Turn on your printer.
  2. Open the front cover.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press the tabs on the cartridge lids, then lift the lids.
  1. Remove the old ink cartridges.
  1. Store the cartridges in an air-tight container or dispose of them properly.
  2. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
NOTE: You can use your printer with one cartridge (color or black) at a time. To extend the life of your color cartridge and improve printing speed, install both a color cartridge and a black cartridge at the same time.
  1. Insert the new ink cartridges. Make sure the color ink cartridge is secure in the left ink cartridge carrier and the black ink cartridge is secure in the right ink cartridge carrier.
  1. Snap each lid closed.
  1. Close the front cover. The front cover must be closed to start a print job.
  1. Open the Dell Printer Solution Center by clicking Start® Programs or All Programs® Dell Printers® Dell Photo Printer 720® Dell Printer Solution Center.
  2. Click the Maintenance tab.
  3. Click Install a new print cartridge.
  4. Click Next.
  5. Select the type of cartridge you installed.
NOTE: Specify whether the cartridge is a new cartridge or an old cartridge (one that has been used before). If an old cartridge is incorrectly identified as New Cartridge in the Dell Printer Solution Center, ink levels may be incorrect.
  1. Click Next.
Dec 17, 2010 | Dell Inkjet 720 Printer
SCREEN READS "INSERT RIGHT CARTRIDGE" ONLY THE COLOR CARTRIDGE IS LOADED. CAN'T I STILL GET IT TO PRINT??????
No..! you need to install the black cartridge..!
The printer needs to be aligned with both the cartridges no matter if they are empty or full. So even if the black cartridge is empty and the color cartridge is full. The color will print and the black wouldn't.
But if you install only one cartridge it will not work as i said that the printer could not align to the cartridges unless both the cartridges are installed.
On some printers if you install the black one only it works. Without installing the color one. But on this printer It is mandatory to install both the cartridges together other wise it will give you error codes.
This model needs the cartridges to be aligned and then print and if you see inside the printer it has a carriage holder for two cartridges which moves back and forth to print.
So install the black cartridge and it will work perfect.
May 11, 2010 | HP OfficeJet 6110 All-In-One InkJet...
How do I align ink jets?
Microsoft Windows 95/98/Me:
(Applies to all printers)
  1. Click Start, Programs, Lexmark Series.
  2. Click Lexmark Control Panel.
  3. Click Print Cartridge installation.
  4. Depending on which cartridges you are using and which printer model you have, select Install Color Cartridge or Install Black Cartridge or Install Photo Cartridge.
  5. Carefully remove the tape covering the printhead of the print cartridge. Important: Be sure to remove all of the tape. Do not touch the copper area on the back of the cartridge.
  6. Insert the print cartridge into the print cartridge carrier.
  7. Push the cartridge back until it clicks into place.
    • If the print cartridge moves loosely in the carrier, it is not locked into place. Repeat step 7.
  8. Click the appropriate Cartridge Installed option in the printer software.
    • If you choose to install a new print cartridge, you will be prompted to align your print cartridges. The printer will print a page with a bi-directional alignment pattern. Follow these steps to align the cartridges:
      1. On the printed test page, locate the number under the Bi-directional Alignment pattern that comes closest to forming a straight line.
      2. Enter the number as the Bi-directional Alignment setting in the Alignment Cartridge screen.
      3. Click OK.
  9. Close the front cover of the printer.
Nov 13, 2009 | Lexmark JetPrinter Z11 InkJet Color...
HP Photo smart c6180 All-in-one wrong cartridge
Hi The 363 cartridges that came with the printer MUST be used before any cartridges you buy in the shop are installed. The cartridges that come in the printer box are called "host cartridges" their ink is different and is required to install the printer for the first time. Once the installation ink is used, you are free to install & use any cartridges you would normally buy in the shops.
If the cartridge that came with the printer is not working, contact HP technical support and they should send you a free replacement.
Cheers.
Oct 24, 2009 | HP Photosmart C6180 All-In-One InkJet...
I installed a new print cartridge into my printer... after installing the new cartridge "install print cartridge" window prompt shows "unsupported cartridge" and instruct to install a correct print...
maybe it have the ink level chip which can be resetted by removing the cartridge and oning and offing the printer for 5 times within 10 minutes coz it saves data of a cartridge upto 5 use before only.. and 6th time insert it.
Oct 12, 2009 | Dell 810 All-In-One InkJet Printer
Installation of the cartridge for Canon Pixma iP1600 printer
To print normally, install or remove ink cartridges in an orderly procedure.
How to install ink cartridges
1. After confirming that the printer is powered on, open the front cover. The ink cartridge holder moves to the replacement position.
2. Take out an new cartridge from its casing and gently remove the orange protective tape in the direction of an arrow.
Caution: Do not attempt to reattach the protective tape once you have removed it. Do not touch the gold electrical contacts or the print head after removing the protective tape.
cartthingsnottotouch.jpg3. Insert the color cartridge into the right slot and then the black cartridge into the left slot.
Note: Push up on the nearest side of the cartridge until it clicks into place.
ip1600puttinginink.gif4. Confirm that the ink cartridges are installed properly.
(A) The ink cartridge is not installed properly.
(B) The ink cartridge is installed properly.
5. Close the front cover. Wait until the preparatory operation is complete; it takes about one to two minutes.
How to remove ink cartridges
2. Remove the ink cartridges.
Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
Jan 06, 2009 | Canon PIXMA iP1600 Printer
How to change lexmark Cartridge
      3. Click OK.
Dec 09, 2008 | Lexmark X1150 All-In-One InkJet Printer
Ink cartridge problem! The following ink cartridges appear to be missing or damaged.
hi!!!!
try to clean the nozzle of your cartridge with the alcohol
or solvent used cotton
or replace the cartridge
try to email me ronaldsuboc@gmail.com
Sep 18, 2008 | HP Photosmart C7280 Printer
20 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
