Dear Sir:
You must adjust , clean, and tigh very well the connector from speed sensor. see the diagram attached.
After that RUN the software calibration.
sincerely. God bless you.
ernesto cuadra
Dear Sir:
Since this a matter from High Teck, you must know digital electronic advance, you must know the DVOM, and other instrument for to execute differents Test, Of course you must have the complete, wiring diagram, adn schematic diagram, and service manual, for diverse operation test. All I can tell you, is better to call some service Tec field, and execute the operation. In that way you have more guarantee. You can pass a lot of time, and frustration try to replae component, and NOT fix it.
Remember I have 42 year to become a Electrical and Electronic Engineer, and I did make a lot of work in maintenance, I see frustation when you do not have a complete information in your Hands. However if you want to try go to the next page: www.fitnessrepairparts.com get the w. diagram+s. diagram+service manual, but you NEED to pay. sincerely. God bless you
ernesto cuadra
managua, nicaragua.
SOURCE: My Proform XP Trainer 580 started to speed up
Dear Sir:
Thank you by your request, I hope everything is fine.
I will try to help you inmediately.
Connectthe test leads to the volt-ohmmeter. Plug the black test leads into the blackjack marked "Com" or "Common" on the front of the meter. Plugthe red test lead into the red jack marked "Volts/Ohms" on the frontof the meter.
Setthe meter's function switch to "Ohms" and the range switch to the"R x 1" scale. If your digital multimeter is an auto ranging meter,you will not have a range switch. Instead, you'll have just a function switchbecause the meter will automatically select the right range for the quantitythat you are measuring.
Turnoff the power and remove the fuse to be tested from the circuit. Never test afuse for continuity while it is still connected to the circuit that it is usedto protect. If the circuit still has voltage, the meter will be irreparablydamaged. If the fuse is still in the circuit when tested it is possible to geta false indication that the fuse is good if the meter gets a completed circuitthrough other circuit components. To be safe, always remove the fuse from thecircuit before testing it.
Touchthe black test probe to one end of the fuse and the red test probe to the otherend of the fuse. It does not matter which probe you touch to which end becausefuses are not polarized. You are checking to see if there is continuity throughthe fuse element. A reading of approximately 0.5 on a digital meter's LCDindicates a good fuse. Most digital meters read their own internal fusesresistance, hence 0.5 Ohms and not 0.00 Ohms. LCD readout of "O.L."indicates no continuity through the fuse. The fuse is bad and needs to bereplaced.
I hope that you can Handle the DVOM(Digital Voltimeter)
Thank you in advance, sincerely. Blessing.
E.CUADRA
MANAGUA,NICARAGUA. C.A.
i know the problem is the controller because i have 2 treadmill same model and i switch the controller getting the same problem
i got the same problem when i use the faulty controller in the other treadmill
what i want to know is what components in the controller do i have to check or possibly replace to fix the problem, i already replace the IRFP250N but didn`t work
