Question about GE WPRB9220D Top Load Washer
Necklace under the agitator and need to get it out
I tried to pull the necklace out but it would not budge - now I guess I need to remove the agitator but I can seem to get it out. I took the fabric softener part off but I can see how to the next section off. I believe that the model # is WBSR31400 - not sure where to find the model number.
  • rayutaylor Jan 06, 2009
    I have a Maytag model# MTW5600TQ2, can't get the agitator off. How do I do this? Help
    Wanda
5 Suggested Answers
SOURCE: clogged fabric Softener
I had the same issue, and ran vinegar through the fabric dispenser with a load of towels. Not only did it solve the 'sour towel' problem I had with that load, it also cleared my fabric softener section. Now, I water down all fabric softner when I use it, which is less frequently!
~Steph
Posted on Nov 23, 2008
SOURCE: how can i clean the entire fabric softner
You can take it out and soak it. You can't take it apart though.
Ge washer repair in orange county, ca
appliance repair orange county, ca
Posted on Feb 06, 2010
  • 500 Answers
SOURCE: I have a front load
Hi jmcgarity,
There are 3 things to check.
- Check the Inlet Valve, sometimes it is a 3 way inlet valve, and the solenoid responsible for water to die Soap Box might be malfunctioning.
Easy way of testing: Attach normal power to both points (Does not matter which side is which, as it is an alternating current) - Be sure to check the voltage of the solenoid, which would be displayed on it 110V or 220v - apply power accordingly. Then attach hose and tap to it, and switch power on and off to the solenoid: ON - Water should flow through, OFF - Water should cease.
- Check the Soap Box Upper area/roof (After removing Die Soap Dispenser Drawer), they got small holes where the water should come through, sometimes (Yet rarely) these get clogged - You can clean it with toothpicks.
- The simplest thing to check is too see if your Dispenser drawer has a siphon cap installed in the softener compartment - Remove this cap and clean the hole under it, and give the cap a good cleaning as well.
If all 3 these things are tried and tested and found correct, then your PCB / Timer may not be giving power to the solenoid when softener should be applied - You can test power to the solenoid mid cycle to check if power goes through to the solenoid after Main wash - If it does not, you need to replace the PCB / Timer.
Hope this helps you :-)
* If you found this solution helpful, please accept it
Posted on Jul 26, 2011
richroth
  • 9472 Answers
SOURCE: GE washer problem
Sounds like the lid switch may be bad. Could you please explain exactly how the washer is malfunctioning?
Posted on Dec 04, 2011
How do I get a mattress cover stuck under agitator out?
On the older machines, the cap on top of the agitator unscrewed & then the agitator could then be raised.
Sep 13, 2014 | Washing Machines
/There is a gold chain necklace wedged under the agitator. How do I loosen the agitator so it will lift up just an inch or so?
remove center downy cap on top of agitator get a 7/16 socket and long extension and hold base of agitator and loosen screw in center of agitator pull up agitator out of washer...
Jan 27, 2011 | Maytag Atlantis MAV6000 Top Load Washer
The bottom part of the agitator seems stuck. It won't spin during a normal wash cycle and it won't budge when I try to move it when it is not on.
Small garments can get caught under the bottom agitator. Disconnect power then remove the agitator cap to expose the agitator bolt. Using a small flat-head screw driver, insert it between the agitator and the cap then pry the cap off the agitator. Remove the barrier cap if present then remove the stud and seal holding the agitator to the shaft using a 7/16" socket wrench with extension. Once the stud and seal are removed, lift the agitator off the shaft. You may need and extra shear of force when pulling the agitator off the shaft.
You don't have to accept or reject and rate this post to add information, comments, and follow-up questions. But accepting the solution will not terminate your communication with the expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Oct 31, 2010 | Washing Machines
How do I remove the agitator - I removed the bolt on the top and can't budge it
Pull harder. You have to pry your finger tips under the base and give it a good pull.
Sep 19, 2010 | Maytag PAV2300 Top Load Washer
A necklace has dropped down under the agitator in my Simpson Espirit 700, how do I get it out. Thanks - ****
Hi just read your posting.Now do you still require help?If you do then pull the middle of the agitator out and shine a torch down the center.You should see a 10 mm bolt.Grab a socket set and turn the bolt anticlockwise to remove it and then lift the agitator out.Please reply on how you got on and for more advice if needed.Looking forward to your reply.
Aug 17, 2010 | Washing Machines
Laundry is trapped under the base of the agitator.
Im not very familiar with that type of top loadign washer,,, but on most agitators there is a bolt that runs down the center of the agitator, connecting it to the transmission/gearbox. Usually there is a cap, or softner dispenser that can be pulled off, revealing this bolt.
Mar 13, 2009 | Washing Machines
Necklace caught under the agitator
In the center of the sgitator, there is a bolt.
Sometimes there is a plug to remove by prying out.
Remove this bolt.... or just loosen it, and the necklace will come free.
See item 2 in the expanded view on the left side.
Thank you for using FixYa - A FixYa rating is appreciated!!
Jan 26, 2009 | KitchenAid KAWS750L Top Load Washer
Necklace stuck in washer
Hold the bottom part of the Agitator,(The part that you are talking about),Undo the very top part in an anti-clockwise direction and it will come right off.Use a wrench to remove the nut on the top of the agitator and then lift it right out,you may need to move it from right to left.You will now be able to remove the necklace.Replace the Agitator the reverse of removal.
DW
Oct 18, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Necklace wrapped around bottom of agitator
1. Pry off protective cap with knife or small screw driver.
2. Remove agitator bolt
3. Lift off agitator
4. Retrieve Necklace
Regards;
reg501
The FixYa team
Jun 23, 2008 | Roper RAS6233KQ Top Load Washer
I have a pant leg caught under the agitator I cannot budge it. What can I do? I need help.
Check on the top of the agitator for a cap to uncover a screw or bolt to remove the agitator, if not you may need to unsrew part of the top of the agitator.
Either way if you can remove what is attaching the agitator, pull it up and out, then the pants should come out.
Apr 01, 2008 | Washing Machines
GE WPRB9220D Top Load Washer Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
