Question about Averatec Computers & Internet
Cannot restore Operating System files to Averatec 5110p,DVDfail?
Unit crashed OPsys first, got Knoppix bootable CD to run fine for awhile, but one day, would no longer boot from CD. Tried to install Linux on hard drive-failed; managed to get DOS Command.com&Win98 screen on C: drive, but won't do anything more. Can't get unit to recognize D:drive(DVDplayer/burner) No luck with external DVD burner/player with USB entry; No luck with Linux boot on USB memory chip either. Installed A:drive with USB connect-would not recognize in SetUp. No way to install parallel A:drive, lacking ports.
Finally got another old hard drive that came from a laptop and looked similar to present one, running Linux. Installed this hard drive and booted to Linux, but could not recall password nor use this version of Linux. Do not know much about Linux, having run only Knoppix with X-Windows on this machine before when it worked properly.
Tried to remove DVD player to get new one, but could not find method to get it out. Got all screws out of bottom of laptop, but DVD would not come out. Put unit back together successfully, losing only one screw to bottom. Unit ran as before, booting C:, not recognizing D:
Baffled at moment, suspect issue with DVD still. C: only has command.com, can not figure out how to install any more DOS files. Was going to try USB link from another laptop, but doubt it will work, as USB chips not working. Struggled with this machine before but forgot what I did. I think I got it to fdisk and put Win98 partial, but not able to restore with orginal Averatec restore disks, which it won't recognize. SetUP works shows mem & hard drives OK.
  • 2 more comments
  • John Ballou
    John Ballou Nov 17, 2008
    Sorry I failed to make it clear. I can't get the laptop to boot on any CD. I got into the Setup by using F2 and by using F12 to change the boot order and the multi boot capabiliity, but it will not boot on the CD. It had booted to a Knoppix CD and ran successfully for months, but would not do that anymore and now boots only the hard drive, showing Command.com as only file. I may have tried to install Win98 to get that, possibly using laplink, but right now I can't do anything but what was accomplished above. I think the original DVD/CD is bad, but I can't get out and I am not sure that some controller to it or just a missing driver is the issue. Again, I lack fluency in Linux so I can't use that to diagnose the hardware. I am determined not to resort to taking this laptop to some repair facility for some outrageous diagnostic testing and repair costs, hoping to get some help here online from experts such as the one who has helped so far. Thank YOU!
  • John Ballou
    Changing boot order is not working, as per my commet above. I cannot get the computer to boot on anything but the hard drive that belongs in it, booting to a partial DOS of WIN98(w.command.com file only) OR another hard drive that contains Linux. In DOS, the D: drive is not valid, and an A:drive added via USB is not valid either.
  • John Ballou
    Already tried format c: and get bad command reply. Only DOS command that works is DIR, which shows Command.com as only file. fdisk and other commands won't work either. Thanks!
  • John Ballou
    Thank you so much for helping me with a problem that has plagued me for some time! The secret to your solution was : ??try to reinstall the OS with 2 or 3 times. It will be OK.? The Restore disks finally worked fine and now I have a brand new computer! You have saved me $$$$! Thank You!
    I Love FixYa.com! Thanks to ALL that participated!
    Brigadier General:
  • 6,966 Answers
An alternative; why force the issue? If the laptop will only boot on the HD C:, why not make C fully bootable with DOS. Remove the HD in question from the laptop, fit it to a 2.5 IDE/SATA to USB adapter; hook the combo to a USB port of another PC running Win98SE, parition/format FAT32, copy 98 installers to a temporary directory. Remove, install in laptop, boot, install 98.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 17, 2008
    Genius:
  • 1,011 Answers
Sir/madam,
Your OS is corrupt. U need not worry about the dvd player. If the OS is corrupt u need not play the dvd drive, usb all the things and the DVD-ROM is not to open. So don't worry that other things. First try to repair the OS with your original cd's. if the original cd is also corrupt, try to reinstall the OS with 2 or 3 times. It will be OK. If it is not worked? u need to connect the other laptop of ur drive and ghost the OS. Try to repair / reinstall with connecting other laptop harddrives. Better to Install windows XP.
thanks
good luck
    Sergeant:
    Champion:
  • 251 Answers
This should work when ur in the dos set up type as follows format C: chose y one the next and continue with y till the who computer is empty then put the cd in the cd drive hit boot from cd and follow the on screen guide this should work here to help u Shaun
  • Averatec Master
  • 19,396 Answers
You need to go to bios settings, and manage the boot startup options.
Posted on Nov 15, 2008
  • Ginko
    Ginko Nov 15, 2008
    You do not need to install any DOS files.
    It probably does not boot from CD because the Bios boot sequence does not have CD as first boot.
    Go to bios, change the boot sequence, and boot from CD, with a Windows disk inside.
  • Averatec Master
  • 13,433 Answers
If you go into the computer bios you can change the bootorder and then boot from a CD some computers also report in the start to press f12 for boot menu the button may be diffrent so you can select which drive to startup from, just do a fresh install of linux from cd you need to change the boot order or try the boot menu, this is the first thing to try.
EMACHINE HAVE AN UNMOUNTABLE BOOT VOLUME. HOW CAN I FIX THIS PROBLEM?
Run hard drive diagnostics: http://www.tacktech.com/display.cfm?ttid=287 (or http://www.bleepingcomputer.com/forums/topic28744.html)
Make sure, you select tool, which is appropriate for the brand of your hard drive.
Depending on the program, itll create bootable floppy, or bootable CD.
If downloaded file is of .iso type, use ImgBurn: http://www.imgburn.com/ to burn .iso file to a CD (select "Write image file to disc" option), and make the CD bootable.
You could also try a Live Linux like Knoppix Live from here:- http://www.knoppix.net/get.php,
download the Free ISO using a Torrent, burn it to a CD then run that it will load into Ram and then ith all the software in the CD you can examine the hard drive
hope this helps
Oct 28, 2012 | Computers & Internet
Unmountable_boot_values
hope this helps
Aug 15, 2012 | Computers & Internet
Panasonic cf-51 bluescreen unmountable_volume
hope this helps
Jul 02, 2012 | Panasonic Toughbook CF-51 Notebook
I have a Dell desktop that runs Windows Vista. When I try to get on the computer, it seems to load but when it gets to the black screen with the scrolling/ moving bar at the bottom. It doesn't leave...
first, recover your files. You will need to use something like this data recovery program.
http://www.asoftech.com/adr/
I've had to use it many times in the past but in this case you need to plug that drive into another system as an external drive or slave drive and run the software from there. It will rebuild the drive and hopefully recover the files.
After you get back your files, you can then format the drive and reinstall your system.
Jul 06, 2011 | Computers & Internet
What are the requirments for installing Linux System
Linux is much more HW friendly than MS Windows. There are no requirements generally. You may need the following:-
5 to 6 GB of **** space. 1 Gb of RAM should be more than enough.
May I suggest some options to you?
1. Go to www.custom.nimblex.com. Here you can customize your linux version. Ask for whatever you want from the list and you can download a .iso file which can be burnt to a bootable CD. This live CD can be inserted into any computer and boot from it in linux of your choice.
2. Go to www.knoppix.com and download the latest version of linux as a .iso file and then burn to a CD to make a live knoppix CD.
Both these options are cheap and very versatile. You can use them to boot any computer.
Sep 28, 2010 | Computers & Internet
Error loading operating system
What operating system? Windows? If so, what version? Linux? Mac?
It could be a corrupt system file or a corrupt section in the MBR of the drive. If you have critical data on the drive that needs backed up, then I recommend that you (from another machine of course) download a live cd version of linux to boot into along with an external usb hard drive. You can then mount your existing drive and copy your data to the external usb drive for a backup of data. I would recommend either PclinuxOS, Knoppix or Puppy Linux. Exit once backup is complete.
Next, boot your machine with either a restore disk received with the purchase of your computer, or if unavailable, boot to a system disk of your current operating system (such as windows xp, etc.). This MIGHT require a fresh install of the operating system - thus the reason for doing a backup of data first. If however, there is a bad sector in the drive's MBR then you're ultimately looking at replacement of the hard drive and then performing a restore or a fresh install of the operating system.
If you find this solution to be helpful, then please take a moment to rate this post. - Thanks.
Jun 19, 2010 | Seagate Barracuda 7200.7 40 GB Hard Drive
Gateway laptop reset
Gateway Direct systems went "media-less" back in September 2004. In the event of a system crash users could either 1) restore their systems from the Recovery Partition OR 2) from the backup media that they were prompted to create on first power-up -- which would provide them with up to 5 blank CD-R discs depending on their system's configuration.
On the factory load of the hard drive, the recovery partition will not contain operating system files. It only contains application and driver files.
The first time the recovery partition is used, it prompts the user to insert their System Recovery CD/DVD to copy files from the CD to the recovery partition.
The Drivers and Applications CD is not bootable and does not contain Operating System files.
The System Recovery CD/DVD is bootable but does not contain any application or driver files.
If the end-user erases the hard drive and restores the computer using the System Recovery CD/DVD and an Applications and Drivers CD, the recovery partition is not recreated.
This means that you will need the operating system restore disc FIRST then the recovery partition will work for you
Mar 14, 2010 | Computers & Internet
Blue screen of death. wont go into safe mode ,it just goes back to error screen stop:0x00000024
With the computer you wrote to this forum on:
1. Download Knoppix
a. KNOPPIX is a bootable Live system on CD or DVD, consisting of a representative collection of GNU/Linux software, automatic hardware detection, and support for many graphics cards, sound cards, SCSI and USB devices and other peripherals. KNOPPIX can be used as a productive Linux system for the desktop, educational CD, rescue system, or adapted and used as a platform for commercial software product demos. It is not necessary to install anything on a hard disk. Due to on-the-fly decompression, the CD can have up to 2 GB of executable software installed on it (over 8GB on the DVD "Maxi" edition).
b. http://www.knopper.net/knoppix-mirrors/download.php?lang=en&link=ftp://mirror.netcologne.de/knoppix
i. Click on agree
ii. Click on knoppix cd
iii. Then click on KNOPPIX_V5.1.1CD-2007-01-04-DE.iso
iv. Save
2. http://pcsupport.about.com/od/toolsofthetrade/ss/writeisofecddvd.htm <-- is a step by step instruction on how to burn an ISO file.
3. NOW – that you have this CD, start the problem computer up with the CD.
What this does is boot up to the CD as an linux operating system, allowing you to copy all your files to a flash drive or another hard drive.
Then reload your windows operating system.
Aug 11, 2009 | Dell Inspiron 9300 PC Notebook
Seagate Momentus 4200.2 120GB
Does it really shut down the computer by itself? Do you have an Operating System installed on it? The only thing I could think of is that the drive has something faulty on the PCB of the drive that is shorted or causing it to sink too much current and that shuts off your power supply. I've never heard of this though or come across it in real life.
Describe your problem in more detail
Dec 13, 2007 | Seagate Momentus 4200.2 100 GB Hard Drive
The DVD drive for my Averatec C3500 does not eject.
First check the bios settings, set to the default settings.
You can dowload a bootable linux CD from here:
http://www.knoppix.org/  (I recommend the v3.3)
If you can use a cd with that it is a software problem.
Nov 11, 2007 | Averatec 3500T60 Tablet PC
Computers & Internet Logo
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
