Question about CMB T43 750 Notebook
I want to use my laptop as a monitor for my desktop
My desktop boots up but the monitor says 'no signal'. can i use my laptop as a monitor for my desktop?
    President:
  • CMB Master
  • 1,314 Answers
No, that won't work. The laptop's monitor only displays on the laptop, and there is no video input on the laptop. Have you tried hooking the monitor to the laptop and see if the monitor works? If it doesn't, then the monitor needs to be replaced. If it does, then your video card is faulty and needs to be replaced.
Thanks and please take a moment to rate as fixya.
Posted on Nov 15, 2008
    Scholar:
  • 63 Answers
Check VGA cord connection, possibly try another, shorter VGA cord, plugging in cords BEFORE booting up computer, with monitor power on also. No signal is just computer telling you that it is not connecting.
You may have to go into Setup when computer boots up and turn on or select external monitor as some laptops may require this. Good Luck!
This is a great place for solutions that will save you lots of $$$$. I love it and it is my first contact with FixYA! jaballou
  • John Ballou
    John Ballou Nov 17, 2008
    Sorry that I got the problem wrong and thus the solution! I read it too fast and assumed that, as many users, you wanted to use your monitor to display your laptop screen. Antiochpc is right. There may be a video output on a laptop, but no video input, so the only real simple solution is to leave the laptop out of the equation and try to find out if the video card on your desktop is bad, as Antiochpc suggests! Sorry I got the problem wrong. I will begin remedial reading lessons soon! I hope the problem is solved. Good luck!
Black montior screen and it is saying no signal
If it is connected on your desktop PC,
• have it tested on other computer or laptop perhaps.
• Insure that the desktop PC where it is connected properly boot.
Jul 26, 2012 | Acer New America Corp H213hbmd 21.5inch...
Pc switching on but lines on screen only
If you can't see anything - even the text from BIOS when it boots, I would suspect that it is probably the monitor. If the PC USED to boot fine, then suddenly started behaving this way it is very possibly either the monitor or the signal to the monitor.
You didn't say if the PC is a desktop or a laptop. If it is a laptop, try to find an external monitor to connect to. Of course, in most cases laptops require that you switch them to a dual monitor mode, which will be difficult if you don't see anything on the main monitor.
Is the a Windows machine? What version of the OS are you running? Have you made any changes to the system?
Also: be sure that if you are using an external monitor, the cable is seated fully and tightened down.
Jun 03, 2012 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Nothing comes up on the monitor
Please check if there is power to the system.
Is this a laptop or desktop?
If it's laptop see if any light turns on in the computer and or if you can connect it to an external monitor to check if the problem is the LCD display or the Video Graphics Adapter.
If it's a desktop see if there's power to the monitor and to the system.
Do you seea any message like no signal or output out of range or is the monitor totally blank?
If you can provide additional information like if it's a desktop or a laptop, when was the last time it worked if there are any indicator of power coming to the system.
Hope to hear from you soon.
Aug 07, 2011 | Computers & Internet
Screen comes on says Acer then No Signal, and goes out. if shut power off and then back on get same result.
This means the monitor believes it's not connected to the computer. Verify the cables first of all. Then try booting in safe mode (F8 key at PC startup) in order to verify that the PC is sending data to the proper video port (you might have a dual VGA / Digital output, for example, and the monitor might be connected to the wrong PC port). Quite often, a "bad signal" will be the same of "no signal"; and you can have a bad signal if the monitor resolution on the PC is set too high. This could happen if you installed a high-resolution capable monitor, and then replaced it with a not-completely-plug-and-play, lower resolution one. The PC would keep sending hi-res signals to a monitor which can neither interpret them, nor tell the PC "please slow down". To check this last possibility, reboot your computer while the monitor is ON. When PCs reboot, they usually drop back to standard VGA signaling, which all monitors understand. If the monitor abruptly comes to life and displays a boot screen, then goes No Signal again after several seconds, you've got a resolution issue; get in Safe Mode with F8 key at boot, and modify the screen properties (right-mouse button on the desktop, then Properties).
If everything else fails, try also connecting the monitor to another PC or laptop, to see if it works there.
Dec 04, 2009 | Acer AL2223W 22" LCD Monitor
NO Signal, check cable
hi there,
you can enable a second monitor when it is plugged into the rear vga-jack while windows boots up and auto-detects it.
-by right-clicking on the desktop background, goto:
properties - display -settings- advanced - monitor - 2nd monitor:
here enable 2nd monitor.
this is only possible if u have the driver fitting your video-card and windows-version is properly installed!
good luck
Aug 04, 2009 | Computers & Internet
Computer Turns on but nothing on monitor
The monitor detects the presence or absence of synchronization signals so your video (integrated or otherwise) isn't putting out video or sync signals. This could be because the boot isn't happening as it should or just a bad video installation.
Dec 22, 2008 | Sony VAIO RB30C (VGCRB30) PC Desktop
Samsung Syncmaster 20 inch no signal
It is a fault with your CPU's Ram module(90%). Rest goes to motherboard/Graphics card.
Dec 17, 2008 | Computers & Internet
Vison 19 inch monitor
when you tried it on the laptops did you make sure that you went into the dispaly properties and checkd the extend my desktop on this monitor if nto it wont do anything anyways
May 18, 2008 | TDV Vison F173 17" Flat Panel LCD Monitor
I am trying to connect my laptop to the Polaroid LCD TV, as i would like to use the TV monitor as a computer monitor (my laptop monitor is broken). So I connect the correct wire to correct places, however...
The simple patch that I found (same problem) was to start by using any old monitor that I could borrow to set up my Dell Laptop.
After getting the Laptop booted on a regular monitor I right clicked on the desktop and went to properties then to the settings tab.
Here I found the dual monitor settings (#2 will usually be dis-abled by default.)
Click on #2 monitor and set the resolution to the lowest number (800 x 600 works well)
Then I clicked on "make this monitor my primary monitor"
As soon as I clicked apply the PC Windows screen appeared on the Polaroid TV screen
Earlier I had set the secondary monitor as "extend this screen to this monitor"
This also worked but I had to "drag the current screen to the right all the way off the
"borrowed monitor" until it appeared on the TV screen. The mouse pointer will be there also.
At first it took a little getting used to but in a few minutes I was up and running.
Hope this helps your situation
David Flournoy
Waxahachie Texas
Mar 10, 2008 | Televison & Video
Monitor powers down upin startup
you need a new video card. it is powering down becuase it is not reciving any signal from you computer. if you are useing onboard video (vga) get a pci video card if you are useing a pci card try puting it in a dfrent slot.
Dec 20, 2007 | Gateway 310S (2900621) PC Desktop
Computers & Internet Logo
561 people viewed this question
Top CMB Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
vojvodabudva
Masood Rasool
Level 1 Expert
Are you a CMB Computer and Internet Expert? Answer questions, earn points and help others
