Question about Toshiba SD-3990 DVD Player
DVD is not recognized in the player
We've tried several DVD's and when inserted the "no disk" signal comes up. Is there a way to rescue the player or do I just need to go to the store.
  • jtroup Dec 08, 2008
    When I insert a DVD, the player display says, NO
  • Anonymous Dec 15, 2008
    Unit always says "No" when disc is loaded and will not play.
Unless you know how to repair by taking off cover, maybe blow off dust from sensitive areas, see if disc is spinning---get a new Sony one for $40. @Target or whateve..
Posted on Aug 30, 2009
I have been playing DVDs without problem for several years on my RCA 20F510TD 20 in. TV/DVD Combo. Now when in the DVD mode, with a disk inserted, the screen comes up with no disk found. What can I do
NOT much you can do---It is a bad optical unit inside the DVD unit---they do not see parts----only the complete DVD portion----much cheaper to go out and buy a DVD player and connect it to the audio and video jacks this unit should have.
Mar 22, 2012 | RCA 20F510TD 20 in. TV/DVD Combo
DVD Player does not recognize disk and displays 'insert disk' message.
Sounds like compatibility issues, your player maybe old enough not beable to recognize newer disc.
Aug 10, 2009 | Sony SLV-D380P DVD Player/VCR
DVD Player cannot recognize any DVDs
Laserunit faulty.Did you cleaned the laser allready?
Jul 30, 2009 | Sony DVP-S550D DVD Player
Disk rotating and a message "invalid disk"
you can try manually cleaning the laser lens ( gently wipe , do not press down hard , it is suspended by fine wires ) using a q-tip and a drop of that cleaning solution you got with the laser lens disc. ( fluff another q-tip a little ) then dry wipe it with another q-tip and try a disc.
you can look at the laser lens and see if you see the laser come on also to determine if that is working ( do not look directly into the laser ! )
if the laser works but it still does not read discs after cleaning it manually , then there is a problem with the focus coil on the laser or the signal board is bad
Jan 10, 2009 | Coby DVD-211
D1817PKG DVD. Turn on unit - insert cd movie- audiovox loading - does not recognize cd
My dvd player tries to load dvd, then says Cannot Read Disk. Have tried different disks.
Jun 13, 2008 | Televison & Video
DVD Player Displays 'Disc Error'
try a cleaner disk, if that doesnt work, junk it and buy something better than this one...cheap dvd players have a habit of not working very long....
Mar 31, 2008 | Durabrand DVD-1002 DVD Player
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
DVD won't recognize the disk message below
Try running a DVD cleaner through it and see what happens. You can get one at Walmart for under $10. If that doesn't do the trick then take it to someone that can open it up to clean it.
Nov 26, 2007 | GoVideo VR3845 DVD Recorder/VCR
Why when I have a DVD inserted does it tell me to insert disk
Well the problem you are having there is that the dvd player does not like the disc because it has not been finilised before so you have finilise it first and then it will work perfectly well that is what i do all the time.
Oct 28, 2007 | JVC XV-N320 DVD Player
DVD not playing
here is the link to the user manual, troubleshooting and venturer support contact details; http://www.1800customersupport.com/products.aspx?view=93&p=43&sc=5&sn=Portable%20DVD%20Players&pn=DVD%20Players%20and%20Recorders Hope this helps, please post again if not :)
Jan 30, 2007 | Venturer PVS177W Portable DVD Player
Toshiba SD-3990 DVD Player Logo
512 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
