Question about Samsung SyncMaster 17 in. LCD Television
Tuner problem? After a recent move, my syncmaster experienced difficulties that I think are in the tuner. I suspect that a connection inside has gotten loose but I can't figure out how to remove the back cover to inspect. I removed the 4 screws that are visible (+2 underneath) but the back cover won't budge. Any suggestions? Here's why I think it's the tuner (or tuner connection): 1) it works just fine as a PC monitor 2) As a tuner, most channels are visible but fuzzy or black/white 3) when I bypass the tuner from my cable box the picture quality is good on all channels (but here I am using the cable box as the tuner -- right?). Finally I guess it could be in the connector/adaptor that goes from coax to the jack. Any idea where to buy one of these?
    President:
  • 3,130 Answers
They install plastic tabs around the cabinet to prevent tampering. You could have a bad tuner, or the input block as you mentioned. You will need to find those taps and pry off the back of the set to see if there is a small square box that takes the coax or is the connection right on the tuner? If this is the case, a tuner will most likly be available at PTScorp.com. If they do not have one, take the generic number off the side of the tuner and see if they have or can rebuild the one you have. Good Luck PS Please do not forget to rate this thread
Posted on Dec 08, 2006
My gear is stiff and experiencing a difficulty when engaging second gear. other gears seems to be fine but the shifting is not smooth.
I suspect that it will be in the shift mechanism
If it is a cable shift then replace the cable
If it levers or other linkages check and adjust or lubricate as required
I doubt it is in the clutch as you haven't mentioned difficulty in selecting first gear only shifting from 1 to 2nd.
Jun 21, 2015 | Opel Corsa Cars & Trucks
Two friends possess Sony 32" flat screen TV`s and they suffer loss of picture or break up I suspect it is the Aerial Connection, I have swapped cables that was not the answer however When moving the...
since moving cables rectified the problem i think the problem must lie with in the connector of the cable.
you can change it easily. its cheap only
Aug 02, 2008 | Televison & Video
Coaster gear problem
I suspect that the synchro ring energising spring is failing and not allowing the connecting dog to move into position properly. First and second are on the same selector rail and move the gear dog from one position back to another position moving the same connecting dog. I think that you may have to pull the box to fix this.. get hold of a Toyota workshop manual and you will see from the diagram of the gear box what I am talking about.
Nov 17, 2013 | Toyota Passenger Cars & Trucks
Samsung syncmaster 930b 19inch: blinking green light on startup screen does not respond turn off or on after a random time period it usually works once screen goes from black to windows it stays...
<P>If you try new cable, try with another PC and still have the same problem, then you need to inspect the inside for bad caps first just like all the SAMSUNG as shown.</P><P style="tab-stops: center 3.25in left 255.75pt"><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><A href="http://s807.photobucket.com/home/budm/allalbums"><FONT color=#800080>http://s807.photobucket.com/home/budm/allalbums</FONT></A><?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></P><P><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><A href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</A><o:p></o:p></SPAN></P><P><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Capacitors kit: <A href="http://lcdalternatives.auctivacommerce.com/Viewsonic-C196320.aspx"><SPAN style="mso-spacerun: yes">&nbsp;</SPAN>http://lcdalternatives.auctivacommerce.com/</A><SPAN style="mso-spacerun: yes">&nbsp; </SPAN>he can make you a set of caps for you.<o:p></o:p></SPAN></P><P>&nbsp;</P>
Aug 25, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Intermittent, but complete, loss of FM signal. Often there will be no signal (according to the tuner display) and then the signal will be captured momentarily; occasionally I will have a strong signal for...
It IS an airborne signal so you can expect it to be affected by the antenna and other electromagnetic interference. Most FM tuners have a selector for how aggressively they accept or reject a marginal signal. Perhaps yours is crossing that threshold periodically.
Jun 10, 2010 | Audio Players & Recorders
How do you connect the aerial to the back of the Samsung Syncmast
This is a monitor, not a TV.
Therefore there's no tuner, no antenna input.
Feb 01, 2010 | Samsung SyncMaster 403T 40 in. LCD...
Shadowing
Has a shadowing problem where everything on the screen was shadowing to the right. Did basic troubleshooting techniques and found that it was due to a loose connection to the computer. You may want to check this if resetting to factory settings doesn't help.
Apr 18, 2008 | Samsung SyncMaster 940N Flat panel Monitor
SyncMaster 920n Power Cable (?) Issues
I think my monitor power connector broke too
Sep 29, 2007 | Samsung SyncMaster 920N 19" LCD Monitor
RCA F36450 TV is intermittently snowy
Your tuner assembly has a bad connection inside of itself, or there is a bad connection around the tuner assy. if this is an ATC113 chassis Good Luck
Mar 21, 2007 | RCA F36450 36" TV
Samsung SyncMaster 17 in. LCD Television Logo
88 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
