Question about Epson Stylus Photo R220 InkJet Printer
Blank paper no IMAGE or TEXT
Hi
my Epson R230 printer not printing
when I send or order a job to print
the printer works but NO image or NO text
printing its BLANK PAPER
how I can solved this problem
or what unit I to CHANGE
faruque
  • westlandhigg Nov 22, 2008
    I have the same problem the printer just keeps feeding the paper through but doesnt print any text
    New Friend:
  • 3 Answers
In case anyone else runs across this, the problem is caused by a blown fuse on the main board. It is labeled F1 and it is near the 3 tall blue capacitors. If you have a meter you can check across it,if it reads anything more than a couple of ohms it is bad. This is a fast acting 2.5A fuse. You can get a fuse and fuse holder at on line or at your local Radio Shack or similar store. I know the 230 is the European/Asian version so I don't know if you have something like a Radio Shack. The R220 is the US version and it is identical.
You can jump it out but this is not recommended. If the fuse is not there, you could cause more expensive problems later.
Posted on Jan 21, 2014
  • Stubborn Heart
    Stubborn Heart May 04, 2015
    Even its an old issue I will thank you for your answer it helps me a lot
    Problem Solver:
  • 14 Answers
Frd
there is problem with your r230 printer mlc and head it coast near about 5000 so best to change your printer
Posted on Dec 02, 2008
Print but now text or image?
Verify if the copier function is working.If is working your problem is in the PC or the data cable.
Apr 19, 2013 | Samsung SCX-4100 All-In-One Laser Printer
Epson workforce 600 blurry 5th line
Update: Blurring of every 5th line occurs in text mode but not text & image mode. Know of a way to see text & image as default for all print jobs?
Aug 18, 2012 | Epson WorkForce 600 All-In-One InkJet...
Blank paper no image or text
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Apr 01, 2011 | Epson STYLUS R230 InkJet Photo Printer
My new epson r230x printer is printing text and images blur
pls download the latest drivers software version of the printer that you use... then after that reinstall the old drivers software that you install previously.
Mar 02, 2010 | Epson STYLUS R230 InkJet Photo Printer
Printing is really slow almost 10 mins to print i am using Vista and have had updated the driver for vista but still
Epson R230 print slow at PHOTO, very slow at BEST PHOTO, if you do not need photo quality prints try printng at TEXT AND IMAGE for faster printing and the quality is still good. Also try to lower the resolution of that you are about to print, high the resoluton images takes longer time to print. Hope this will help you, Good luck!
Oct 14, 2009 | Epson STYLUS R230 InkJet Photo Printer
The text of a document will not print. The
Print From Your Computer : Windows Printing Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. 1. Select a Quality Option that matches your document or photo, and the print quality you want. Quality Option settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032347", false); WebWorks_WriteDIVOpen("wwdd1032347", false); • Draft: for rough drafts with reduced quality • Text: for documents containing only text • Text & Image: for documents with text and images • Photo: for photos and graphics with good quality and print speed • Best Photo: for photos or graphics with high print quality WebWorks_WriteDIVClose(); 2. Select the paper Type setting that matches the paper you loaded. 3. Select the paper Size setting for the paper you loaded. Paper size settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032380", false); WebWorks_WriteDIVOpen("wwdd1032380", false); You can load paper in these sizes and select the size in the printer software. (Wider papers are for use only when reducing large images with the Reduce/Enlarge Document option.) A User Defined option is also available so you can create a custom size. A4 (8.3 × 11.7 inches) A6 (4.1 × 5.8 inches) Letter (8.5 × 11 inches) Legal (8.5 × 14 inches) Half Letter (5.5 × 8.5 inches) 3.5 × 5 inches 4 × 6 inches 5 × 7 inches 8 × 10 inches 16:9 wide (4 × 7.11 inches) Envelope #10 (4 1/8 × 9 1/2 inches) WebWorks_WriteDIVClose(); 4. If you’re printing borderless photos, click the Borderless checkbox. For documents or photos with borders, select Borders. Note:
For borderless photos, make sure you loaded a compatible borderless paper size and type. 5. Choose Portrait or Landscape orientation for your document or photo. You can also:Select Print Options Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. Select graphics & text. USER'S MANUAL EPSON WEBSITE: http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Jul 22, 2009 | Epson Stylus CX4400 All-In-One InkJet...
Epson r390 printer prints blank(no text on paper)
check that there are drivers installed for the printers
Jun 24, 2017 | Epson Stylus Photo R390 InkJet Printer
Epson cx4800 - will print in text mode but gives me a paper jam message in photo mode pape ris not jammed
It sounds like a driver issue. Have you tried to uninstall and reinstall the software on your computer?
Nov 02, 2008 | Epson Stylus CX4800 All-In-One InkJet...
TO Print the image using IPL.
I've printed images over 500kb. Can you print a small image? If not, perhaps the driver is the problem.
If you're trying to send a text file of IPL commands to the printer, set up a Generic Text printer driver, to to send the file as ascii characters instead of as a graphic image. You can set this up in addition to your Intermec driver.
Go to Printers and Faxes, Add Printer, Next, Select the Port, Select "Generic" Manufacturer, "Generic / Text Only" Printer, and give it a name like "Text". Cycle the printer power to clear previous attempts, then print the file to this printer name.
Aug 22, 2008 | Intermec EasyCoder 3400 Thermal Label...
Epson Stylus Photo R220 InkJet Printer Logo
294 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
