I just downloaded ares ultra and i cannot connect with a wrt54g router? I need to fix the port forwarding how do i do this?
  • 1 more comment
  • Anonymous Dec 16, 2008
    i cant connect for some time now is anyone outhere who can help
  • Anonymous Dec 21, 2008
    does not connect
  • Anonymous Jan 20, 2009
    las descargas son muy despasio
    Problem Solver:
  • 15 Answers
Portfowarding dot cam should help figure it out
Posted on Nov 15, 2008
Port forwarding
Connect your Internet phone directly to the cable modem and see if you can use Internet phone directly through the modem.
If it works through the modem then it must be the issue with the port forwarding.
First get the port numbers from the phone manufacturer.
Open the setup page of the router and open those port numbers.
Jan 15, 2012 | Linksys Wireless-G WRT54G Router
Hello i need to open some ports in order for my ps3 will function properly..I need the Tcp ports open #'s (80)(443)(5223)(10070)(10080) and also need the UDP ports open #'s (3478)(3479)(3658)(10070) model...
LINKSYS ::::
NAT STRICT
Step 1 : Connect Router - Computer
Step 2 : Open Router Setup by typing http ://192.168.1.1
Step 3 : Click Applications and Gaming
Step 4 : Click DMZ
Step 5 : Select Enable and Give the IP Address of the XBOX/PS3/Wii in it
Step 6 : Click Save settings
Step 7 : Unplug the Power cord from the router and turn Off XBOX /PS3/Wii
Step 8 : Plug the power cord back to the router and wait till the lights are Solid
Step 9 : Turn on the Xbox/PS3/Wii
Step 10 : Test the Connection
Else ...
Under application and gaming you can find port range forward
There you can open the ports one by one
And give the IP Address of the PS3 for all the ports opened
Dec 21, 2010 | Linksys Wireless-G WRT54G Router
How to i unlock my router ports to play on my xbox? xbox live told me its these ports i have no idea how to unlock them im not looking to spend another 30 dollars on fixing the issue... i run my lap top...
I'm guessing when you say unlock you are needing to forward these ports. Follow this link...it shows you how to get into the router and forward the ports:
http://portforward.com/english/routers/port_forwarding/Linksys/WRT54G/default.htm
Feb 27, 2010 | Linksys Wireless-G WRT54G Router
Port forwarding with linksys router
If you can get online. Definitely, your DNS server is correct. Meaning that your DNS and your static IP are on the same range. Because if the DNS server is NOT within the same range of your static IP, you will never get online. Slow connection has something to do with either the router settings or your ISP.
Port forwarding is opening a specific port so that you could send/receive messages, so that you could allow other URL. Like https, FTP and other stuff.
If you're connected wirelessly to the router, you may need to check/cnage the wireless channel of the router. And if the Internet is still slow, you may need to verify it with your ISP. Maybe they are doing some settings on their end.
Have a great day!
May 29, 2009 | Linksys Wireless-G WRT54G Router
GGPO connection problem...
go to start find the program that says run type cmd
when the comand promt opens up type ipconfig/all that should show you all the stuff you need
Jun 24, 2008 | Linksys Wireless-G WRT54G Router
Help with my router
You did not have this problem before because port forwarding was set on the previous router settings, or you were using a modem ( no firewall) .
Here are instruction for port forwarding
Here are more instuctions
One last thing, if your computer is powerful enough (1gb memory would be good), use Azureus, is much better.
Jun 08, 2008 | Linksys Wireless-G Broadband Router
Port Forwarding for Transmission
This web page has a wonderful graphic step by step to use port forward for your linksys router:
Hope this helps.
Mar 29, 2008 | Linksys Wireless-G WRT54G Router
I can't connect to the Playstation Network for some reason.
You can typically see the setup for this router by going to http://192.168.1.1 or http://192.168.0.1 . The default login is admin/admin . Once you access the setup page, you will see an Applications and Gaming section to forward ports through to whatever you need. To get the ports forwarded, you need to know which ports and the internal IP address of the device you want to forward them to.
Feb 16, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
