Question about Panasonic CQ-VD6503U Car DVD Player
Everything but sound works
I have a 2004 silverado with a bose system. The scosche wiring harness i bought says to put the rca jacks into the pre-outs. Everything with the player works but i get no sound out of it
There is a blue and white wire from the head unit that needs to be connected to the blue wire from your car harness. This powers up a separate amplifier that provides sound to the speakers crossovers. Without doing this you will not get any sound.
REgards
D
Posted on Jan 25, 2008
2004 GMC Sierra 2500HD with factory Bose stereo system but no on-star, put an aftermarket clarion CD/DVD player in it over 2 years ago i put in the adapter for making the Bose factory system work and
either your connectors need cleaning or maybe a break in the wiring. Is there on spot where both wires come together if so check there.If there is any plugs, pull them apart and clean them with contact cleaner
Dec 15, 2014 | 2004 GMC Sierra 2500HD
It's a 95 ford explorer and we bought a wiring harness for the new radio, the old radio worked fine and everything. We hooked up the new radio to the wiring harness and it powered on and everything, b
try hooking the radio power wires to the battery! To '' TEST'' twist red and yellow put on the poss. blk. on neg. ! take a speaker and test speaker wire out put! if don't work output is blown out! but will still work with rca jacks hook to small amp ! this to pull sound out of your radio for sure!!
Dec 27, 2012 | Cars & Trucks
CAN THE BOSE CD PLAYER BE FIXED IF SOMETHING IS
Yes, many aftermarket radio/CD players are made that will fit. Look on WWW.Crutchfield.com
Feb 07, 2010 | 2000 Nissan Maxima
What do i need to hook up ipod to bose 321. (wires etc)
This is the quick and easy way to adapt a standard stereo 3.5mm (1/8 inch) sound output into standard RCA plugs. Ideal for connecting your MP3 Player with a 3.5mm plug to VCR's, TV's or anything else that has RCA stereo sound inputs.
General Features:
- Fits standard 3.5mm (1/8") stereo phone jack
- Gives you two male RCA (left / right) sound outputs
- Great for converting a headphone jack to standard RCA sound outputs
- 6 foot length
- Straight cable (not a coiled cable)
Generally these connectors cost between $1.00 to $5.00
Pictures to help you find them
Search google for headphone to rca adapter for more info
Hope this helps
Jan 16, 2010 | Bose (321GS) System
Ipod nano connector for Bose 321 GS Series III
OK! The cheapeast and most simple way would for you is to get a 1/8th inch conector jack that adapts into red/white RCA jacks (it will have a couple feet of wire in between the jacks) plug the 1/8 inch adapter into the jack on I-POD and the RED/WHITE ends into the back of your systems aux inputs RED/WHITE! OR tape input ect! make sure I-POD is turned up! and you may have to adjust I pod eq to get the best sound out of system! (OH you can get this adatper at any radio shack or wall-mart!)
Please take a second and rate this response
THANK YOU!
Jan 19, 2009 | Bose 3 2 1 Series I DVD Home Entertainment...
No sound from rear speakers of Bose V20
Are you useing a digital coaxil cable? or optical cable?(you will need one of these connections to get 5.1 surround!) the white /red rca jacks will not do the 5.1 surround! (back speakers)
Please rate response!
Jan 07, 2009 | Bose Lifestyle 12 System
No volume
The Bose system in the Z is wired to control the entire car's speakers. Each speaker has its own amplifier, and the OEM head unit puts out a line-level signal to each amp. Your Clarion unit puts out speaker-level signal (in effect, an amplified signal), into the Bose amps, and it's probably overdriving them and putting them into shutdown.
Your best bet is to replace the Bose speakers with aftermarket speakers meant for a speaker-level drive (which is what I did in my Z, and never once regretted it). If you do so, you'll need to run new wires to the speakers, or if you use the OEM wiring, you'll need to unplug the amps and run the wires from the amp harnesses directly to the new speakers. I think there is an adapter harness you can use that will tap into the line-out jacks on your Clarion, so that a line-level signal can be sent to the Bose speakers - I'd do a google search for "Metra harness 300zx" or something along those lines (Metra makes the lineout harness adapters - I use one in my Audi).
Sep 16, 2008 | Clarion DXZ755MC CD Player
Trying to install after factory radio in 94 Honda accord ex and can't get any sound
I have a 93 accord ex with the bose amp system. Had a Sony deck put in it. It had the popping and the noises. It was installed at a store and they had to hook the red power wire to the antenna wire to get the sound to come out of the system when playing a CD. I thought that was bogus to have the antenna up all the time so I took it back out and put another quick hookup harness in it and it did the same thing. Will not put out any sound till the red power wire is hooked up to the antenna wire so that it goes up when the key is turned on. Installed the same stereo in a 94 taurus SHO with amp and it worked great. I believe that there is an expensive kit that converts the bose system to hook up a unit so that it doesn't pop click buzz, and have to have the antenna up to play.
Jun 19, 2008 | Car Audio & Video
Panasonic CQ-VD6503U Car DVD Player Logo
193 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
