Question about Kitchen Appliances - Others
My Ruud Furnace wont stay lit
This heater will start as normal with a fan stating to run for a minute then the burner will ignite and go out almost immediately so we dont get any heat.
  • bmreid Dec 15, 2008
    I have the same issue. It is sporadic though. It won't work for a while and then will work for a week or so and then won't again.
    Problem Solver:
  • 10 Answers
Get a new furnace.
Posted on Jan 20, 2009
Hi Bmreid
The problem you describe sounds pretty much like your gas valve is going bad. There is a brand by Honeywell called a Smart Valve which is anything but smart, when the electronics in the valve start going bad the furnace will run great for a day or two and then the next day may not run at all and then an hour later my run and then an hour later may not run again. Very sporadic operating furnace is usually the Honeywell Smart gas valve going bad.
Posted on Dec 17, 2008
Pull your flame sensor out from in front of the burners. It is about a 3" long metal rod. Clean it with a piece of sand paper and then reinstall it. It should work fine.
Posted on Sep 20, 2012
Hi my sister's furnace won't stay lit the burner that hits the flame sensor won't lit is it the gas value
Posted on Feb 09, 2009
What is kicking off to make my furnace go through its cycle and then blow cold air and wont shut on my Ruud gas furnace
it could be flame sensor or high limit switch how long do burners run does the fan stay on while this occurs
Dec 15, 2016 | Ruud Heating & Cooling
The heater turns on, but does not ignite. The fan runs for about 5-7 seconds then shuts off. I am assuming the heater needs a good cleaning?
pilot lit on gas furnace, but the burners won't light (Home ...
answers.angieslist.com > Home > HVAC
Oct 26, 2013 - i have a gas furnace with a lit pilot, but the burners won't light. ... I hv gas furnace we turn thermosate on upstairs but still wont turn on coud turn ...
Furnace Not Starting - Clean the Flame Sensor - YouTube
? 3:15
https://www.youtube.com/watch?v=Ecd5CzJjss4
Jan 4, 2012 - Uploaded by Home Improvement Videos
If you woke up to find that your gas furnace is not starting or it's ... If this sensor gets dirty (and they almost always do over time) then your furnace will try to light, ... working, you can hear it starting, but the burners on not coming on. ... The furnace nowcomes on every time and the house is nice and cozy.
Furnace wont start. What to do before calling the repair man ...
? 10:11
https://www.youtube.com/watch?v=yJxDc90hs4g
Sep 12, 2012 - Uploaded by grayfurnaceman
Our property manager is great about sending a repairman, but the house is a mess. ... While troubleshooting my downstairs furnacethat wouldn't turn on, I turned off the ... Not sure what to do now about flame rollout switch..
Jan 05, 2016 | Heating & Cooling
Goodman furnace Model GDS80703AXBB -fan comes on then igniter light comes on, then burners turn on but shut off right away and wont stay lit. Now igniter light wont come on so burners not coming on at...
Sounds like either the flame sensor is not working.
The sequence for starting the furnace is:
1. extraction fan on
2. pressure sensor (for fan)
3. ignitor (spark or glow plug) comes on
4. gas valve opens up
5. ignition of flame
6. flame sensor (or temperature sensor)
7. plenum temp. sensor
8. main fan starts
It is most likely that the flame sensor is dirty or gone,
or (and I hope not), the module is gone and needs to
be replaced.
Sep 10, 2017 | Heating & Cooling
Lennox furnace model G11Q3-110 v.2 burners light but go out before fan comes on
Troubleshoot an ignition problem on a Lennox gas furnace ...
? 2:44
https://www.youtube.com/watch?v=yXIxgzwMkPs
Nov 17, 2012 - Uploaded by grayfurnaceman
This furnace should light its pilot with a spark then the pilot proves its on ... Troubleshoot an ignition problem on a Lennox gasfurnace .... Pilot and no inducer but is the same model as that great video! ... You probably have dirty burners. ... How do you know spark module is not sending 24 volts to mv and pv ...
Lennox Furnace Model G11Q3-82-2 - RepairClinic.com
Nov 19, 2012 | Heating & Cooling
Janitrol GUPS075-3 Furnace burners will not stay lit
The first thing I would do is make sure the flame sensor is clean, this is a metal rod immersed in the burner flame on the opposite side of the igniter. If too much oxidation builds up on it, it will not allow the burner to stay lit. To clean, just turn off furnace and remove flame sensor and clean with steel wool and then reinstall. If this does not solve the problem there may be a problem with the gas valve.
Nov 08, 2012 | Heating & Cooling
Goodman furnace gmh95090cxac wont stay lit keeps clicking will lite then clicks back off what would be the problem
Hello, if the burners light but do not stay on for more than 10 seconds, I would clean the flame sensor. The flame sensor is a metal rod that is on the opposite side of the Igniter, sometimes it gets coated by oxidation and does not sense the burner flame and shuts the Furnace down. To clean to kill power to tje furnace, remove flame sensor and clean with a steel wool, then reinstall and start Furnce back up. If this does not work then most likely the Igniter is too weak to ignite the gas and will have ro be replaced.
Oct 29, 2012 | Heating & Cooling
Ruud furnace Model URKA A030jK08 Code opt 589
Flip the lower panel over and look for a wiring diagram. On that diagram there will be a diagnostic chart. Let me know what 5 blinks represent. Then I want you to read on.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Nov 23, 2009 | Heating & Cooling
Rheem gas furnace pilot lights, but no burners or fan
If the burners do not fully ignite, the sensor will shut the furnace down. The lack of sufficient burner flame is a gas valve or gas pressure problem within the valve.
Replacing the gas valve with the original one may get you going. I surely suggest a professional service company for safety reasons and a thorough inspection. A 20 year old furnace is past it's normal life span.
Jan 06, 2009 | Heating & Cooling
Blower won't stay lit
If the fan motor is blowing out the burner then is there a hole in the heat exchanger
Jul 18, 2017 | Honeywell Power Humidifier: Furnace...
Kitchen Appliances - Others Logo
532 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
