Question about HP LaserJet 1020 Printer
Will not print
Have checked for jammed paper. When you ask it to print it runs for a few seconds like it is going to print and then shuts off. I have taken the ink casset out and put it back in. It has paper. The settings look OK.
  • thayerbooks Jan 09, 2009
    Printer thinks it has a paper jam. Have removed toner cartridge and checked for stuck paper - found none. Removing/replacing toner cartridge and closing case does not prompt a reprint attempt as it normally would. Turning printer on and off does not remedy problem. It resets to "ready" but then when a job is sent, it reports back that there is a paper jam.
How to replays tephlon sheet for hp laserjet 1020 printer
Posted on Nov 21, 2008
Constant Paper Jam
check the wheels that pick it from the tray.
If they feel smooth, try to put some tape on them and rip it back off.
This cleans the wheels. Also try a new pack of paper and check if it\'s set to plain paper and not to heavier or coated paper
May 30, 2013 | Brother MFC-7840W Multifunction Laser...
The paper light is flashing. The tray has paper, there is no paper jam. I check everything, put tray back in, press go and after a few seconds, there is a click noise and it starts flashing. What do I do?
The light flashing may mean more things, not just a paper jam. Could mean any of the following:
- Front cover is open: Close the front cover of the printer.
- Back cover is open: Close the back cover of the printer.
- Paper jam: Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the Go button.
- No paper fed manual feed slot: Put the paper back in the manual feed slot.
- Memory full: The printer memory is full and the printer cannot print full pages of a document. To solve this problem, click here.
- Print overrun: A print overrun occurred and the printer cannot print full pages of a document. To solve this problem, go here.
- Drum Error: The corona wire needs to be cleaned. To see how to clean the corona wire, click here.
Thank you for using Fixya!
Dec 02, 2010 | Brother HL-2040 Laser Printer
Paper Jam
Have you checked for paper jammed in the rollers or any other small item like a paper clip? Also are you running this on wired or wireless connection?
Jan 13, 2010 | Brother MFC-7820N Printer
Model 7700 won't allow me to run printed page through for two-sided print. Shows jam warning, but no jam. Unprinted pages run fine.
Are you using the bypass tray for the second run? If so, of course you have a problem with the bypass paper path. As you might know, the workaround is to place the printed page face down on top of the paper stack in the input tray. . I would be amazed that if you tried to run it this way (page on stack) that the machine would cough it up. That would amaze me. Try running sparcely printed stuff through, stuff printed on only one side of the page, then the other, then the center, etc. Could be that there is some sensor in there that doesn't like black toner marks just to see what is going on. Then go from there by asking online with that info. . Good luck.
Nov 25, 2009 | Xerox Phaser 7700DN Laser Printer
Is there a fix for error 6A80 for a Canon mx700 printer?
You can try a few things:
RESET the printer:
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Check for paper jammed in the paper output slot, the Rear Tray, or the Front Tray.
Remove the paper following the procedure below.
(1) Slowly pull the paper out, either from the paper source or from the paper output slot, whichever is easier.
(A) When printing from the Rear Tray
(B) When printing from the Front Tray
bullet_s.gif If the paper tears and a piece remains inside the machine, open the Scanning Unit (Printer Cover) and remove it.
After removing all paper, close the Scanning Unit (Printer Cover), turn the machine off, and turn it back on.
* Be careful not to touch the components inside the machine.
bullet_s.gif If you cannot pull the paper out, turn the machine off and turn it back on. The paper will be ejected automatically.
(2) Reload the paper in the machine, and press the OK button on the machine.
If you turned off the machine in step 1, all print jobs in queue are canceled. Reprint if necessary.
i_note.gif Note
bullet_s.gif When reloading the paper in the machine, confirm that you are using the correct paper and are loading it into the machine correctly.
bullet_s.gif A5-sized paper are suited to print documents consisting mainly of text. We do not recommend using such paper to print documents with photos or graphics, since the printout may curl and cause paper exit jams.
If you cannot remove the paper or the paper tears inside the machine, or if the paper jam error continues after removing the paper, you should take the printer to a service shop since the printer will have to be disassembled to remove the torn paper.
Oct 16, 2009 | Canon MX700 Office All-In-One InkJet...
Printer keeps paper jamming when i go to print. I
check to see if their is a paper size adj. it might be on legal length si=ze and you are getting 1 and 1/2 sheet duration and then shut down
Jul 31, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Hp photosmart 2410xi - paper won't feed properly through, jam
Go to an office supply store and pickup printer cleaning sheets. They are sticky on both sides. You run a sheet through it a couple of times to remove paper dust from the rollers. The pickup roller is so slick it is drawing in more that one sheet of paper. Cleaning the rollers and the paper path will solve your problem.
Mar 18, 2017 | HP PSC 2410 All-In-One InkJet Printer
PRINTER ERROR. See manual
May be a paper jam causing it.
Or you have given prior command which is still in the Print.
Try to open the Print Window by :
Start --> setting /Control panel--> Print and Faxes --> the select the printer and open the window
Cancel all document if still there.
After then, go to start -- > Run--> Type --> msconfig
Go to start up Tab --> Uncheck the entries for printer and then restart the computer. It will definetly fix the error.
Have a nice day. Dont forget to vote me.
Regards
Ellin
Sep 25, 2008 | Epson RX620 All-In-One InkJet Photo...
HP LaserJet 1020 Printer Logo
103 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
