Question about Whirlpool ED0GTQXMQ Side by Side Refrigerator
Cold water dispenser stopped working
There is a click sound when the lever is depressed but no water.
  • 700 Answers
Have you checked to see if the resevour was frozen up ? its on the inside back wall of the refrigerator.
Posted on Dec 22, 2008
I just changed the water filter and now the water will not dispense? I can hear what I think is the pump but no water?
After you changed the water filter and then you were to depress the front dispenser to get water the humming sound that you are hearing is the water inlter valve located at the rear of your machine. You would have to pull the unit out away from the wall to locate the valve. Before you do this did you with a empty cup depress the water lever on the door of the machine for about 3-4 minutes? When you remove the old filter you also take the water that is filled inside the filter out which when you plug in the new filter it will take a couple minutes of depressing the water lever to get the water to flow to the filter then it leaves the filter and goes to the water valve. When it goes into the water valve it then splits where one line carrys water to your icemaker and the other carrys water to the water dispenser on the door. If after the 3-4 minutes you dont have water pull the machine away from the wall and remove the line from the inlet valve that comes from the filter then have someone depress the lever on the front door which would tell you if you had water going past the filter. If you do have water going past the filter to the valve then you would disconnect the line that goes to the water dispenser and see if you can get water to flow out of that nozzle as well. If water is not flowing out of the valve then you would either try to clean the small screens which sometimes get clogged with calcium deposits or you would have to replace the water valve itself. If you have any further questions message me back. Thanks
Rick
p.s also if you have no water going to the ice maker you can remove the front cover on the ice maker and use a jumper wire and jump from L to V which would also activate the water valve immediatley
Sep 21, 2011 | Maytag MSD2756G Side by Side Refrigerator
Whirpool Gold 21 Cu. Ft. Side by Side. Water dispenser will not dispense water. I hear the solenoid click. I think the line in must be frozen some where.
Do the following: Flush the water system. Use a sturdy container to depress and hold the water dispenser lever for 5 seconds, then release it for 5 seconds. Repeat until water begins to flow. Once water begins to flow, continue depressing and releasing the dispenser lever (5 seconds on, 5 seconds off) until a total of 3 gal. (12 L) has been dispensed. This will flush air from the filter and water dispensing system, and prepare the water filter for use.
Ensure that the freezer door is closed completely? Close the door firmly.
Ensure that the water shutoff valve is fully open.
Ensure that the water pressure is at least 30 psi (207 kPa)? The water pressure to the home determines the flow from the dispenser.
Check for any kinks in the home water source line? Straighten the water source line.
Check the water filter. The filter may be clogged or incorrectly installed.
if still there is problem of water flow then please take assistance of a technician to check the plumbing.
If the fridge is new and in the warranty period get in touch with the service center and ask for free service.
Feb 01, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water dispenser dripping water all the time
First be sure the refrigerator is connected to a cold water supply. After connecting the refrigerator to a water source or replacing the water filter, flush the water system. Use a sturdy container to depress and hold the water dispenser lever for 5 seconds, and then release it for 5 seconds. Repeat until water begins to flow. Once water begins to flow, continue depressing and releasing the dispenser lever (5 seconds on, 5 seconds off) until a total of 12 L has been dispensed. This will flush air from the filter and water dispensing system, and prepare the water filter for use. Additional flushing may be required in some households. As air is cleared from the system, water may spurt out of the dispenser.
One or two drops of water immediately after dispensing is normal. It may be necessary to hold the container under the dispenser for 2 to 3 seconds after releasing the dispenser lever.
Hope this will be useful.
Thank you
Jan 04, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
5-10 second delay when depressing the water dispenser lever
the water line maybe frozen in some parts. once you get water to flow from it. let it flow for a minute or so by depressing switch and catching the water in a large container
Jul 24, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kitchen Aid water dispenser makes a hammering sound when in use.
this is a pressure problem . some times caused by line size . but generaly changing the water valve will correct this problem . ****
Jan 06, 2010 | Whirlpool GS6NBEXR Side by Side...
Water not coming out
Without knowing the model # filter is usually located on bottom of fridge in grill. When you depress the lever listen for the water valve in back of fridge to click on if not you may need a new water valve. What is the age and model # of fridge?
Nov 07, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Have ice but no water
The line is clogged with lime if you can free the line up try a coat hanger are somthing to wipe down in the water line to free lime deposits out.
Oct 07, 2008 | Refrigerators
GS6SHEXMLoo side by side ice dispenser not working
On advice from the tech I removed acess door. It was covered by frozen moisture.
I removed the motor it was full of water. I verified 120 volts at plug to motor from control
by depressing the door switch and ice dispenser lever at same time. The motor ohms out
but because of amount of water removed from it I am going to replace it and see what happens.
Aug 05, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool ED0GTQXMQ Side by Side Refrigerator Logo
50 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
