Question about Belkin (F5D8231-4) Wireless Router (F5D82314)
Belkin router not working
I recently moved 2 portugal and when i tried to set up the wireless router it wouldnt work unless the cables were put into the wrong places. but that means i cant go on the internet and play my xbox at the same time. when the cables are in the the right slots i can go on the internet but that meansi cannot play on live. i tryed to keep changing the cables over but they are going 2 brake please help.
  • paul_afc92 Nov 15, 2008
    i cant get onto the website it just says cannot display the website.
    Genius:
  • 1,913 Answers
Access your router with following link
http://192.168.0.1
then type user name:admin
password is:admin or blank
then enable DHCP.then u can get ip automatically.
Posted on Nov 15, 2008
  • kishor khatri
    kishor khatri Nov 15, 2008
    type in run "ping yahoo.com -t" if u get replay your internet is working.but if u get requist time out something is rong.
    ok
    check your windows fire wall in control panel and also disable anti virus firewall if enable then try.
    also check your lan card isenable.and set ipo auto matically in.
    if u dhcp on on router.
Using belkin gigabit powerline adapter with a wirless router
Try to configure the 2 routers to work with one another when they are next to each other using standard ;an cable. Once working the powerline should work fine. If you try to configure them when they are apart you have 2 things that could be causing problems to take out the powerline to begin with, then when they are working close, move them apart
Nov 05, 2017 | Computers & Internet
The ''wireless'' light on my wireless router is flashing amber
Contact Belkin for Care at 1-800-585-2494 Toll Free,,
Jan 09, 2010 | Belkin F5D8236-4 Router
Want to connect 2 routers to 1 modem
as far as I know it would not work due to auto configuration of DHCP settings in the router when using cable internet. You may have to manually configure this to get it to work. If you are using dsl, I dont think it will work at all.
If it was to work, this is how I would do it:
Using Cat 5 cabling
Modem -> N Router -> G Router
Be sure to plug modem into the uplink port on N router. Then go from port 1 on N router to uplink on G Router. Set both routers to DHCP setting and see if that works. Im going to try this when I get home. It actually sounds ideal, never thought of it myself.
Hope that works for you!
Sep 22, 2009 | Belkin (F5D7231-4) Wireless Router
How do i connect my router to my adsl filter?
Reset your adsl and connect your LAN cable from your adsl to your wireless router. you should have wireless all over the place if not let us know
Jan 14, 2009 | Belkin (F5D9230-4) Wireless Router...
When i first connect my daughters computer with an belkin wireless router than i stop working than i purchase an d-link not thinking it would make a different but it didn't and still not working do i ahve...
No you can't use two routers (without being an expert to set them up correctly!). Make sure the Belkin isn't plugged in while you're setting up the D-Link. To diagnose the culprit, try these steps:
1) Plug your daughter's computer directly into the ethernet port of the DSL or Cable Modem. You'll need to do this to rule out your Daughter's PC as the problem. If it works fine, then move to step 2. If her computer still isn't working, and another computer connected the same way DOES work - then you need to work on your daughter's computer, becasue that's where the problem lies.
2) Ok since you confirmed your daughter's PC is just fine - and also the DSL or Cable connection is working as well - this indicates most likely the router(s) are at fault. So let's work with the D-Link, since we're not sure if the Belkin is working. Like I said, be sure the Belkin is completely unplugged and powered OFF. Now plug the D-Link into your DSL or Cable modem ethernet port. Turn on the D-Link, make sure the correct indicators are lit on both the DSL/Cable modem and the router. Reboot your daughter's PC and right-click on the wireless networking icon on her taskbar. Choose view available wireless networks - if you see your D-link listed, then the router is working! If you still can't connect - try disabling WEP/WAP and try again. Most likely it's just a security setting that's off.
Good Luck!
Dec 31, 2008 | Computers & Internet
Belkin N1 router - wireless light not on???
Wow! I'm having the same problem!!!! Worked great...Now it's pooped!
May 15, 2008 | Belkin (F5D8231-4) Wireless Router...
Belkin wireless router
You may contact to belkin tech support and ask for assistance. hope they will help you to resolve your problem. for more information you may visit : Belkin Tech Support Helpline For Router 1800 585 2494
Nov 11, 2007 | Belkin (F5D7230-4) Router (587009)
Belkin can't work it out!
If u r wi-fi router uses encryption u have to put it in u r connection wizard and trying putting DNS servers of u r service providers.
Oct 24, 2007 | Belkin (F5D7231-4) Wireless Router
Belkins router not connecting to cable modem
You need to start from beginning. Clear all temp internet files and run this programme Start>Run ipconfig /flushdns and hit enter. Get into the routers settings(probably 192.168.2.1) and ensure in the Lan settings that 'DHCP Server' is on and wireless is enabled.(you might need to be connected by RJ45 lan cable first) If it's a 125mbps router change settings to 54mbps to try that speed first(especially as your wireless cards will be 54 mbps) look in Mac address Filtering is off. Look in the DHCP Client list and see if your pc's were allocated ip addresses, if so it should allow an internet connection. Go to both your pc's wireless cards properties and under TCP/IP properties ensure obtain ip address automatically is checked. Restart both pc's and the router, disconnect cable and try wirelessly
Mar 07, 2007 | Belkin (F5D9230-4) Wireless Router...
Belkin (F5D8231-4) Wireless Router (F5D82314) Logo
77 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
