Question about JVC Cameras
JVC GR-D260EK camcorder (to casette) was working fine now wont fire up. Tried new battery n charger but no sign of life. Any ideas?
  • 3 more comments
  • peterw666 Nov 15, 2008
    The charger & new battery both checked & fine.
    Wont fire up with AC connection. Definately not water/liquid or contact damage. Don't think its a short but have not the expertise to check the motherboard - made need to take it to a dealer :-/
    switch and contact points all OK
    ... not the memory card either
  • peterw666 Nov 19, 2008
    OK guys you can stop now :) You know the one about taking the car to the garage and when you get there the problem has solved itself. Decided to take the unit 12 miles down the road to the nearest camcorder doc, he picked it outa the case and, yes, it burst into life!?! Think it is the circuitry n not convinced it won't happen again, but at least I can get the tape out that was stuck in there. Thanks again for all the replies - share the fee however.
    Brigadier General:
  • 6,966 Answers
Most of the responses of the others relating to power is correct. To be more specific, the JVC GR versions has two (2) fuses in the main board, one for the AC power and another for the DC power. Pls reference below partial diagram.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 18, 2008
  • Louie  Role
    Louie Role Nov 19, 2008
    Hi again,
    Any development(s) so far?
  • 4,806 Answers
Like all electonics things go wrong from time to time, check to see if the internal fuse has blown or that any ribbon cables or leads have become dislodged from the housings
    Sergeant:
    Champion:
  • 347 Answers
Hellow PeterW666,
On JVC's website, there is no information about a repair shop in you rcountry,
However, i suggest you to click HERE, and there you will find some contact informaton, about where to call them and ask them directly how can you reach them.
If you want, click HERE to find about a camcorder repair shop in London.
Good luck and anythign esle you need let me know,
Dahaka
Posted on Nov 15, 2008
    President:
  • 2,712 Answers
I would say there is a circuitry/power issue. No point opening it up if you don't know what to look for :)
Best suggestion would be to get it serviced, or buy a new unit, whichever works out cheaper for you..
  • 1,879 Answers
If you have the knowledge in electronics, open the camera. Else you need to take it to a camera repair shop.
  • monk3ybidzness
    monk3ybidzness Nov 18, 2008
    very small electronic on the motherboard - taking it to the repair shop is your best option since it won't power up with batteries or ac power.
    Genius:
  • 1,913 Answers
Put away your memory card .
then try.
    Genius:
  • 1,447 Answers
Hi
Try checking powerbutton or switch. then check leads for batteries as well( contact points for batteries)
Hope this helps
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Nov 15, 2008
    transistors on board is either burned or overheated. have it service..
    Thanks for using fixya!
    President:
  • 1,952 Answers
Check ur chargerr chord...whether the voltage passed in it?
  • JVC Master
  • 19,396 Answers
When there is no sign of life is always a power problem.
Go to a camera repair shop and ask to test the camera with different charger.
If it is the charger, buy them a new charger.
  • Ginko
    Ginko Nov 15, 2008
    Naturally , the first thing to do is testing the camcorder with a new battery and AC adapter. You told us that you did this already.
    Try starting the camcorder With the AC adapter only (use an adapter that is tested and proven to be good and working). If the battery is shorted, or the battery contacts are shorted, the camcorder wwont turn on whenever the battery is present.
    Inspect the battery contacts inside the camcorder battery slot, if there is fluid or oxide, this can cause a short on the camcorder battery contacts and the unit will not start.
    Check the AC adapter slot connectors on camcorder, if they are defective the camera wont start.
    A common reason for camera not powering up at all, is when there is a bad soldering joint on the power adapter socket, inside camera. The socket is soldered to the camera main board. If one of the contacts is defective the camera won't start.
    More reasons for cameras and camcorder not starting at all are associated with liquid damage, shocks, and some faulty component on the power area of the internal board.
What type of casette do i use for jvc gr-axm18u camcorder
JVC called it a C-CASSETTE or a compact VHS tape.
Oct 12, 2010 | JVC GR-AXM18US Camcorder
Camcorder not charging
Since the camcorder will power up and work with the charger connected, it sounds like the battery has died and will no longer hold a charge.
Feb 06, 2010 | JVC GR-D850 Mini DV Camcorder
How do you remove safe mode from jvc GR-D770U
how do i get out of safe mode on JVC GR-D77OU? tried what manual said with taking battery off and putting back on and taking charger off and back on?
Dec 15, 2009 | JVC GR-D770 Camcorder
I need a battery charger and instruction book for jvc mini gr-d27
Have you tried the JVC website? They have accessories along with chargers.
Rob
Feb 06, 2009 | JVC GR-D270 Mini DV Digital Camcorder
JVC GR-D33U Doesnt charge
your battery way have went bad shorted internally.
if this is what happen and you pluged the charger in it may have also shorted out your charger.To know for sure get a good battery and test the camcorder,you may need to get a new or recondition charger.hope this has help jerry
Sep 27, 2008 | JVC GR-D370 Mini DV Digital Camcorder
Jvc gr-d770u battery problem
maybe u r using wrong reference battery
Jan 31, 2008 | JVC Cybercam GR-D200US Mini DV Digital...
Problem charging GR-DX77
check the charger output if it has an DC out voltage about 8.4 volts. If it does not have, your charger is effective.
Aug 07, 2007 | JVC Handycam GR-DX77 Mini DV Digital...
My GR-AXM18 JVC Compact VHS w/LCD Screen isn't recording!!
Blue means that there is no signal. It can be that the head is dirty. Use a cleaning casette, (do not use cotton swab and alcohol)
May 25, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Cameras Logo
Top JVC Cameras Experts
Jax Planet
Jax Planet
sonic boom...
sonic boom...
Are you a JVC Camera Expert? Answer questions, earn points and help others
