Question about Dell E173FP 17" LCD Monitor
Dell E173FP 17" Flat Panel
I was reading the other problems posted about the same mointor, regarding the power issue, the mointor can display fine, but only for about 5 seconds then turns off and cycles between powering off and on. I know it has nothing to do with my video card or anything because ive tried it on 3 diffrent computers, I have also replace the video and power cables on the mointor, I was wondering if anyone had another suggestion I might try?
  • stevedap Aug 25, 2008
    Hi, a friend gave me her 17" LCD monitor which was working perfectly. It's unbranded. I took it home and connected it to my computer and all I see ia a white screen with random horizontal black bars for about 7 seconds, then the screen shuts off and the green on/off light goes to amber. It does this avery time whether or not the monitor is connected to a computer. If you want to see the pattern it shows go here: http://www.youtube.com/watch?v=BZEB9cfCS... Any suggestions on what could be causing this? Is it worth diagnosing and fixing? Thanks, Steve.
  • DAZFJ Mar 04, 2009
    my moniter wont stay on it turns on for 3 seconds but the split second my decktop appers it turns off then flickers on off on off please help what can i do? is this worth getting repaired?
    Scholar:
  • 53 Answers
You are seeing a common problem there are 4 transistors that switch off the power to the back light most of the time these are not bad but the solder joints have cracked causing a bad connection and simply resolder these will fix the problem.But there are also a problem with bad caps in these monitors it is ez to see them cause the top of the bad cap will be bulging up I have seen 100s of these monitor fixed with just resoldering the connection in the power board which is also the back light board.any flicker in voltage in this circuit will cause the power to the pack lights to shut down.
Posted on Jun 10, 2009
You need a new backlight or inverter board. To check for a new lamp, shine a bright light at the front of the monitor and see if you can see an image.
Posted on Feb 12, 2007
    Problem Solver:
  • 13 Answers
Like xxdarkchild said, the 2SC5707 transistors are usually the cause. If any one of those shorts out, it will also blow the fuse.
Fix it yourself for less than $10. Here is the kit that I used to fix my 173FPB: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&Item=220486136668
Posted on Sep 30, 2009
The monitor yes power an one secon no apaers in the lcd no screeen
Posted on Jan 30, 2007
  • Gonzalo Najera
    Gonzalo Najera Jan 30, 2007
    am check la card of monitor and blink la lamp of lcd
MY DELL E173FPb FLAT MONITOR WILL NOT COMPLETELY POWER UP IN GOES
Most common failure in this model is shorted transistors in the inverter circuits caused by poor solder connections, see pictures here for guide: http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
Mar 27, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
I have a problem with a Dell e173fp monitor. On power up, the power LED goes green and screen flashes on once very dimmly, then goes black.
Look for shorted out transistors (4) (c5706/5707) in the inverter circuits, this is common problem, post back what you see so we can guide you further.
Jan 31, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Microphone
To my knowledge, a Dell™ E173FP Flat Panel Color Monitor does not have a built-in microphone.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 16, 2008 | Dell E173FP 17" LCD Monitor
Display is upside down
AN EASIEST WAY IS HOLD THE CTRL AND ALT KEYS,AND CLICK THE "UP" KEY
Jun 02, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
19 in Dell flat panel monitor
also need to see video how to remove back of monitor case
May 01, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Dell F1703 17 in. Flat Panel... Problem
There may be problem of heating the inside components. see him to expert.
Mar 03, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
hi, check out the micro switches on the monitor.. let me know..
Nov 17, 2007 | Dell E173FP 17" LCD Monitor
Monitor
i had a similar issue with my dell E172FPB, I have never seen a E173FP but this link might help you
http://syscon.wordpress.com/2007/07/13/dell-dell-e172fpb-lcd-backlight-repair/
Oct 21, 2007 | Dell E173FP 17" LCD Monitor
Dell E173FP 17" LCD Monitor Logo
1,455 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
