Question about Minolta Office Equipment & Supplies
DiAlta Di7210 Copier. Problem = "SC35-03 Report Code" Need to know what is means and how to repair. Thanks
    President:
  • 1,952 Answers
Better u consult with service center regarding this error
Posted on Nov 15, 2008
  • 3,037 Answers
To clear a fuser service code (SC 34-xx, SC 35-xx, SC 36-xx).
Using the 25 mode, soft switch 3, bit 1 must be changed back to 0 (off). To do this, perform the following steps:
1. Access the 25 mode.
2. Press [1: Software SW setting] on the touchscreen.
3. Press the left up-arrow, which is displayed on the touchscreen, twice. The number displayed above the up-arrow will change to 03.
4. Select the bit number of switch 1, using the right up-arrow. 03-1 will be displayed.
5. Press the [OFF (0)] key, which is displayed on the touchscreen.
6. Power the machine OFF/ON to exit the 25 mode or press RETURN, MODE CHANGE and then BASIC SCREEN to return to normal operation.
Let me know if you have further questions or if this doesn't work for some reason
C06 50 error code minolta dialta copier
The scanner which is the bright lite under the big glass has a home sensor to let the copier know that scanner is back home and ready to scan again. will the code is saying the senor is bad, could be dirty get some can air. Remove big glass will be though to get at small and black under the scanner bay side.
Dec 02, 2013 | Minolta DiALTA Di183 Copier
Minolta dialta di183 copier error code c06 50
C 0650 - Faulty scanner home position sensor.
Remove the glass and clean the home sensor.If the scanner moves smoothly remove foreign matter and other obstacles,clean the scanner rails,clean or change the scanner bushing.Place WD 40 oil on scanner bushings.
My dialta minolta di183 is showing C06 50 code and i dont know how to go about it
Clean the home scanner sensor scanner is what moves as it scans the document. then go back to home position there is sensor that tell the copier it is back home clean dirt or might need to be replaced.
I have a Dialta Di-620 copier with an error code C-0540
i have a problem di620 code error c0540 please solve this thanks alote
Aug 23, 2011 | Minolta DiALTA Di620 All-In-One Laser...
Reports keep on printing!!! Minolta Di251/351
You need a service technician to down load program that will stop it. Its on service web site
Mar 27, 2009 | Konica Minolta DiALTA Di200 Copier
MInolta Di 183
Abnormally high toner density detected Black ATDC (auto toner density control circuit)
Replace black IU, check toner motors, make sure toner is loose not clumpy. Change dev reset toner level.
Thanks.
Mar 25, 2009 | Minolta DiALTA Di183 Copier
Minolta DI200 Error Code 00070
try and take the toner bottle out and turn machine on and than put the bottle back.it;s bottle sensor problem.good lock
Feb 05, 2009 | Konica Minolta DiALTA Di200 Copier
Minolta dialta Di200 on screen :malfunction detected code:COO4E
C004E: Power Unit Cooling Fan Motor malfunction
Check the power supply fan for proper operation.
Nov 11, 2008 | Konica Minolta DiALTA Di200 Copier
81 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
