Question about Sony Cyber-Shot DSC-P73 Digital Camera
P73 switching off!
The camera tuns ON fine and display says "Access" then it switches off. If I start the camera in Setup mode it will remain on, but anyonther mode that requires the lens to move, automatically switches the camera off! Any ideas? Thanks
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 216 Answers
This is most likely a weak battery. Be sure to charge at least 14 hours before using rechargeable batteries. If alkaline, replace with fresh ones. The zoom motor uses more power that any other features.
Posted on Nov 24, 2006
Sony DSC-P73 auto power off in picture mode
Hello!
You may try using any another compatible Battery pack in the Camera to ensure if the issue is not causing due to the Battery. Actually, when the Camera is switched to the "Picture or Camera" mode then the power consumption increases spontaneously. So, if the Batter is not holding sufficient charge to cater the power need of the Camera in the Camera mode then it'll automatically turn off. However, if the issue persists with spare Battery also then you may try resetting the Camera to the original factory settings by pressing and holding the Reset button for 30 seconds. Otherwise, it's required to get the Camera to resolve the hardware issues.
Aug 21, 2009 | Sony Cyber-Shot DSC-P73 Digital Camera
Canon a610 no display of new pictures only previous
I almost have the same problem.
My camera automatically switches between playback and camera mode quickly only for a while,then it remains still in the playback.When it remains in playback,if I toggle the playback/camera switch few times,it may work for some shots but again the problem begins. (http://www.fixya.com/ThreadAsker.aspx?thid=2918658)
Did you find any solution?
Aug 15, 2009 | Canon PowerShot SD1000 Digital Camera
The only functioning modes are the picture viewing & set up modes
Have Sony DSC-P73 with exact problem. Only turns on in SETUP mode and when switches to all other modes camera shuts off usually with lens extended. Have tried new batteries - new memory stick - new everything and nothing helped. I just took out the batteries and attached the AC ADAPTER and all works perfectly now so problem is with either batteries - battery compartment or battery connections. As long as you do not need a "PORTABLE" camera, using AC Adapter solves this problem :)
Dec 25, 2008 | Sony Cyber-Shot DSC-P73 Digital Camera
Sony cybershot 4.1 megapixels mpegmovie vx dsc-s90
Your camera has problem in Lens mechanism. If Lens doesn't open properly, camera will not show picture at all. There would be Loading Motor section demaged in Lens mechanism and it needs to be replaced to work camera OK.
Now come to blue screen in playback mode, This model doesn't have internal memory, so you need memory stick/ card to see previously taken pictures.
Jun 21, 2008 | Cameras
Time set and LAP
With the radio turned off and displaying the time, hold the MODE switch until the time display flashes (about 2 seconds). Release the MODE switch then quickly, use the TUN (up) to set hours, TUN (down) to set minutes.
Oct 06, 2007 | Koss PP257 AM/FM Radio
Black Screen
camera ccd is / has failed - also possible , lens iris is stuck closed ( on monitor , can see very faint snow noise against black background - check if iris opens , by shining penlight into lens );
May 03, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Adjuster tight
Of course there is a chance that contact spray (non greasy) can solve the problem. If not, there is also an ultimate option to change the control switch block part number: 147838411 If you need more info please advice
Mar 28, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Durabrand wd810
Page 12 of the WD810 manual states: XM OPERATION =SWITCHING TO XM MODE Press MOD button (6) shortly to select XM mode. =SELECTING CHANNEL UP/DOWN Press the TUN/TR>> button (17) or TUN/TRK<< button (16) to select the channel up or down. = SM MODE SELECTION Press LOC/XM button (2) to switch Category mode, Skip mode or normal. It is used as the selection of each: Normal >> Category mode >> Direct Tune >> When Category mode or Skip mode is engaged, the "CATEGORY" function is turned on in the display. When Category mode or Skip mode is released, the "CATEGORY" function is turned off. When Direct mode is engaged, "DIRECT" of alphanumeric display is turned on. How to direct tune (omitted)
Dec 28, 2006 | Durabrand WD810
No display in record mode on Samsung VP-D31
Sounds like you may have a problem in the auto iris curcuit or the auto settings was switched to manual and the lens is closed. Check first to see that the lens is setup in auto mode. If it is then the auto iris as i said before is bad or stuck closed unless the small caps in that curcuit went bad as they always do after a few years. Good Luck
Apr 14, 2006 | Samsung VP-D31 Mini DV Digital Camcorder
Sony Cyber-Shot DSC-P73 Digital Camera Logo
44 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
