Question about Seiko Mantel Clock
Chimes are nine minutes slow
Chimes at 9 min. after the hour 24,39 etc.
Hour hand is aligned properly at top of the hour
Is there any way to adjust this?
    Problem Solver:
  • 6 Answers
Take the minute hand off and turn hand over. There is a brass bushing that attaches to the aluminum hand. Take a small screw driver and place in the square hole of the brass bushing. Turn either direction and test on the minute post of the clock. Keep adjusting until the clock chimes right on the 1/4 hour position. Make sure to put the hand back on the right 1/4 hour.
Posted on Apr 01, 2009
I have a Bulova chime mantle clock, three wind, that needs sync. it is off by 15 minutes (it chimes 1/2 hour on 15 minute time etc. can you help me?
Simplest way is to remove the minute hand on dial and reseat it at the correct setting I.e one quarter turn .recheck the hour chime is on hour etc.replace glass front.
Jun 20, 2015 | Bulova Collins Majestic Triple Chime...
How to adjust Grandfather clock that chimes one chime less ?
Move the hour hand counter clock wise to 10 o'clock. Then turn the minute hand clock wise to set the correct time.
Main Page
Oct 04, 2014 | Home
How to reset clock chimes
The hour hand is a friction fit, so you can probably just remove the clip or cotter holding the minute hand in place, pull off the hour hand and set it back to match the chimes. The minute hand is on a square shaft, so if you are off by a 1/2 or 1/4 hour, you can change its position also (but only in 15-minute increments).
Jun 25, 2014 | Home
I have a metamec grandmother clock it chimes 4min early have tried to syncronise it but it still chimes early
If your clock has a round arbour push fit hand it is quite easy to sync. Undo the nut and the minute hand will drop off easily, then gently but firmly pull the hour hand from the centre so as not to put pressure on the hand itself. As soon as the clock chimes, replace the hand exactly on the hour corresponding to the amount of strikes, replace the minute hand pointing exactly to 12 o'clock and replace the nut.
If the hour hand has a square fit arbour and held on by a rivet it is a bit more complicated and I would suggest you take it to your local clockmaker.
Mar 07, 2014 | Seiko Home
My clock chies 2 hours behind
If the clock is a mechanical clock there are 2 ways it can be fixed. You need to take the hands off the clock and gently replace the hour hand to the hour it strikes/chimes replace the minute hand and then gently clockwise ONLY move the minute hand to each hour letting it strike/chime the hour it is on. If this does not work there is another way and you can email me Yvonne. yvonne.finch@gmail.com for more information. Mechanical clocks only.
Feb 10, 2013 | Opromo Kassel 15-day wood wall clock w/...
The chime of my Howard Miller mantle clock are not w/the actual hour set.How can I reset the chimes? Daylight Savings time has messed me up.
The next time it chimes multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it chimes signaling 15 minutes after. Now put the minute hand back on pointing to 3 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
Nov 06, 2011 | Seiko Mantel Clock
How do i synchronize chimes with clock on westminister whittington clock .
The Westminster/ Whittington clock means that it has 2 or 3 settings.
1. Silent
2. Westminster Based on the music My redeemer liveth by Handel
3. Whittington
Set the clock onto the westminster setting, this is the easiest. At quarter past the hour it should sound 4 notes. The half past should be 8 notes. Quarter to the hour should be 12 notes and the hour should be 16 notes then the striking of the hour. For example on 8 'O clock you should hear 16 notes then the clock should chime 8 times. Sometimes if the hour is out just gently stop the pendulum, check what hour the clock is striking then without taking the hands off move only the hour hand to the hour. Do not do this with the minute hand.
I hope this helps you! If you are not sure please email me yvonne.finch@gmail.com I fix these clocks.
Apr 30, 2010 | Seiko Mantel Clock
The time and chimes are out of sync for our tempus fugit wall clock by 4 chimes does any know how to adjust it
Turn the minute hand until the 16 westminster chime operate and then the hour strikes. Remove the minute hand and simple put it back on at the 12 o-clock position. The chimes should now be in sync.
Fred
Apr 24, 2010 | Seiko Mantel Clock
I NEED THE INSTRUCTIONS FOR SETTING THE CHIMES/TIME ON MY WESTMINSTER LINDEN MANTEL CHIME CLOCK
Manually turn the minute hand forward until the 16 westminster chimes sound and then the hour strikes. Then remove the minute hand (it will go on in four positions) and put it back on at the 12 o'clock position. The chimes should now be back into sync.
Fred
Apr 05, 2010 | Seiko Mantel Clock
Strausbourg Manor Wall Clock chime adjustment
It is normal for the average wall clock. Of course, this can be adjusted, but without watch/clockmaking knowledge it is impossible, because first you need to find out which part of the movement is causing early chiming - and there are plenty of them.
Super fine adjustment can be found only in top of the range clocks. Hundreds of hours of craftsmenship are spent to adjust and fine tune them. That's why they cost a fortune.
If you can not live with that early chiming, you have to bring your clock down to the watch/clock repair shop and ask for help. Be ready to pay quite a money, as this job takes the skill and a lot of time.
Rate me, please.
Jul 29, 2009 | Seiko Mantel Clock
Home Logo
468 people viewed this question
Top Seiko Home Experts
k24674
Jimmy Accardi
Are you a Seiko Home Expert? Answer questions, earn points and help others
