Question about Kogi L7CH Monitor
Possible_backlight_issue my monitor works , but won't stay lit. cause everytime i toggle the monitor off and on, it seems like the backlight blacks out 2 seconds after it's on. but i can see windows running in the background,so it is functional.
  • mylesgarber Feb 08, 2008
    I have the L4BX kogi and yes the lcd screen is very dark I can see an image when I put a light on the screen . OK i know its the blubs?" i hope but who fixes this . who do I send it to?
    thanks Myles Garber
  • Anonymous Mar 04, 2008
    I've got the EXACT same problem; when I cu it on about 2 seconds later the screen blacks out and if I toggle it off/on it relights but goes out again 2 seconds later ... shining a flashlight on the screen at an angle shows it's got my page there.
  • 47 Answers
Hi goldeneye, Sounds like the backlight inverter board. Don't mind the explaination I just cut and paste this solution from one of my others. It's a very common problem. LCD's use four small Cold Compact Fluorescent bulbs to back light the display. (thats what gives the LCD it's brightness allowing you to see it) The inverter board runs these lights and when they go bad they will typically show symptoms like you have or the monitor power light comes on and you have either no display or a very dim display. If you ever have one that has no display but the power light is on you can check by shining a flashlight directly into the LCD from the front (right into the screen) if you can see an image then it's either the inverter board (most likely) or the CCFL bulbs have gone bad. The inverter board and CCFL's are replaceable. Good Luck, El Duderino
Posted on Nov 26, 2006
SOURCE:
Dell st2410b monitor won't stay lit
Ok, same issue here as well. Monitor would come on for 1/2 second and then the backlighting will go off. It's next to impossible to tell, but if you shine a bright flashlight at the screen, you can make out the video signal/desktop.
I have now replaced all the Capacitors except the very large one (didn't come with the kit that was available.) None of my caps looked bad (bulging) including the large one. Unfortunately, I still habe the same issue
So my question is....large capacitor replacement or something else?
Nov 29, 2012 | Dell ST2410 Monitor
HP LE1901W won't stay lit up
usually with lcds, this can be caused by a bad inverter or power supply
Jun 20, 2012 | HP L1710 LCD Monitor
I have a ViewSonic VX910 Monitor that hasn't been working. I bought the monitor at a thrift shop wishing to repair it after fixing 3 other monitors now. The monitor turns on fine, will sleep,...
There should be no liquid coming out from the cap at all. Is it the one that has 250~350vdc rating on it? The one in my pix has very small leak coming out, you can barely see it.
See pix here; http://s807.photobucket.com/albums/yy352/budm/VIEWSONIC/Viewsonic%20VX710_910/?action=view&current=DSC00865.jpg
It should have about 160vdc on this cap, be carefull, this is the HOT (LINE) side of the AC primary circuits!
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 11, 2011 | ViewSonic VX910 19" LCD Monitor
Monitor screen will not stay lit. It will only stay lit for a second then goes black.rq
The problem can be caused by bad caps in the power supply, bad inverter backlights circuits, bad lamps. Look for bad caps first, then post back what you find so we can guide you further, see example of failed monitors due to bad caps here: http://s807.photobucket.com/home/budm/allalbums
Jan 30, 2010 | HP w1907 LCD Monitor
SyncMaster 930B takes 20 minutes at least to become visable
IT SHOWS THAT THE PROBLEM IS IN THE POWER SUPPLY SECTION OF THE LCD. CHANGE THE CAPACITORS PLACED IN THE POWER SUPPLY SECTION. IT WILL WORK.
DONT FORGET TO VOTE.
Oct 10, 2009 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Displaying issue
Hi,,,there,
That's indicated your backlight inverter are busted. Need to replaced a new one or repaired it. To repaired look for a bad capacitors with a bulged on top of each caps. Not sure, just replaced all the caps... Have a nice weekend!
Oct 11, 2008 | Samsung Syncmaster 940BW LCD Monitor
Monitor won't light up. Only just for a second or two.
Hi
this issue is made by defective torch or lamp at the back of LCD...
Thanks!
Aug 05, 2008 | LG Flatron L1515S 15" LCD Monitor
Dell inspiron 1150 laptop black screen
Can you hear the Windows startup noises but can't hear it?
Does it work plugged into an external monitor? (Any good CRT or flat screen should work.
Be sure to plug in the screen before you turn it on.
If it doesnt output to the LCD automatically you may have to hit FN-F8 to switch to external.
If it works on external monitor you are just dealing with a screen problem of some sort - either a bad inverter or backlight in the LCD most commonly...
Let us know.
Dec 17, 2007 | Dell INSPIRON 6000 CENTRINO...
Black screen
Try pressing the 3rd button, as it toggles the Analog or Digital inputs...
Oct 05, 2006 | Dell 1703FPs 17" TFT LCD Flat Panel...
Kogi L7CH Monitor Logo
132 people viewed this question
Top Kogi Computers & Internet Experts
William Miller
William Miller
Steve Allison
Steve Allison
Are you a Kogi Computer and Internet Expert? Answer questions, earn points and help others
