Question about Cuisinart Coffeemakers
Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
My brews just fine, but once it's finished, shuts off & does not keep the coffee warm, any suggestions? Cuisinart DCC-2000 12-Cup Coffee Maker
  • 16 more comments
  • hamiltongi Nov 15, 2008
    Yes! That did it. Simple solution, don't know why I didn't think of that - thank you so much!!
  • Anonymous Mar 09, 2009
    10 cup brew and serve brews full pot then shuts off will not stay on
  • Anonymous Mar 12, 2014
    Do I use ground coffee for farberware coffee maker 12 cup?
  • Anonymous Mar 13, 2014
    I need to program my Cuisinart fast brew coffee maker.
    I have the Cuisinart K cup maker and when I turn it on water just flows through and will not stop... We have had no issues for a year now and all of a sudden this started. Any way to fix so that I dont have to spend $150 on a new one. Thanks
    Will not brew when button pushed
  • Anonymous Mar 18, 2014
    My coffee maker continuously drips after brewing is complete.
    won't process water
  • Anonymous Mar 19, 2014
    is leaking when I turn on the brew function
    water does not pour into coffee in filter
  • Anonymous Mar 20, 2014
    brewing is interrupted before complete and will not turn on again.
  • Anonymous Mar 22, 2014
    Grinder stopped working
    cuisinart coffee maker not brewing
  • Anonymous Mar 23, 2014
    Keurig says brew and nothing happens, thought it might need cleaning, cleaned as per the instructions and it still won't brew, starts too and then shuts down
  • Anonymous Mar 24, 2014
    coffee makes doesn't start brewing
  • Anonymous Mar 28, 2014
    I have run vinegar regularly in my brewer however, it is slow to brew a 12 oz cup of coffee. It also has started brewing about 4 oz of coffee on the 12 oz setting
  • Anonymous Mar 29, 2014
    Takes to long to make a cup off coffee
  • Anonymous Mar 31, 2014
    Is there a fix for when the brewed coffee does not flow thru the lid to the pot?
  • 4 Answers
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
Posted on Nov 15, 2008
  • Pam Holdway
    Pam Holdway Nov 23, 2013
    Yeah!!! This worked.
Filter lid spins properly, brew lights are on; but it won't brew coffee.....please help
How to Repair a Cuisinart Coffee Maker - Java Jenius
www.javajenius.com > How-To
How can I flush it if it won't brew at all? ..... The filter basket is in the proper position for the coffee to enter the filter but the ... I have a regular cuisinart coffee maker for12 cups (no grinder). ... I have the Cuisinart automatic grind and brew, model DCC490SA. .... The pot brewed a good cup of coffee but as of now it is useless.
Jan 21, 2016 | Cuisinart DCC-790PC 12-cup Grind & Brew...
I have a 12-cup DCC-1200 black & chrome Cuisinart coffee maker, like the one pictured below. Once every three weeks or so the brewing function goes into overdrive and, instead of brewing a pot of...
It sounds like there's a problem with Charcoal Water Filter. What it does is it eliminates chlorine, calcium, bad tastes and odors on the brewed coffee. You can try to clean it manually or if that doesn't work, replacing that might fix the problem.
Keep us updated. Hope that helps.
Sep 09, 2008 | Cuisinart DCC-1200 Coffee Maker
Brews good hot coffee but warming plate has stopped heating! Are replacement elements readily available or could it be a fuse...??
The DCC-1200 has only one element, that both heats the water for brewing and keeps the carafe warm. If you're brewing coffee then the element is fine and the suspect part is the Thermistor. Another forum suggested this was a Vishnay NTCLG100E22245B, available from DigiKey (their part # BC2467), connected to the control board with thin yellow wires. The same forum suggested that this thermistor should test at 220K ohms at room temperature, dropping to 20K at about 220F.
Nov 17, 2015 | Cuisinart DCC-1200 Coffee Maker
Shuts off after brewing
THE COFFEE POT SHUTS OFF RIGHT AFTER ITS DONE BREWING AN THE COFFEE IS WARM NOT HOT !!! THE POT IS ONLY 10 OR 11 MONTHS OLD !!!
Nov 16, 2012 | Cuisinart DCC-1200 Coffee Maker
How do I clean my cuisinart DCC-12
1/3 cup of white vinegar and 2/3 cup of water. Run through brew cycle. Run brew cycle again with plain water.
Sep 14, 2010 | Cuisinart DCC-1200 Coffee Maker
Coffee maker shuts off too soon after brewing.
Hello FloydBob, The Cuisinart DCC-1200 has the ability to program the auto-off function that keeps your coffee warmer plate on after brewing is complete.
The unit lets you select the time increments from zero up to 4 hours.
See page 6 of the attached manual for the full instructions for reprogramming the coffee maker.
To program the Variable Auto Off:
1. Turn the FUNCTION KNOB to the “Auto Off”
position. Press and hold the “Hour” button
for 2 seconds. The clock display will start
blinking.
2. Program the coffeemaker to shut off from
zero to four hours after brew cycle is
finished by using the “Hour” and “Minute”
push-buttons.
I figured you might also like to have a complete instruction/owners manual so you can have access for any other questions you might have about your coffee maker, in the future.
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf
I hope you find this Very Helpful and best regards!
Nov 09, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Cuisinart DGB-300 coffee maker brew pause valve
No one has just the individual part, but you can get the whole brew basket with the part included on Cuinart's website, or by calling them.
Feb 03, 2009 | Cuisinart DCC-100 Coffee Maker
I just called Cuisinart and they will send me another brew basket for my DCC-100 (it has a Brew Pause valve also) for $9.14 (part + S&H). Did you try to contact Cuisinart?
Aug 30, 2007 | Cuisinart DGB-300 Coffee Maker
Cuisinart Coffeemakers Logo
1,913 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
