Question about GE JVM1440 Microwave Oven
I have A JVM1430 SPcesavee over the range microwave. It is saying
F3 in the window and it keeps beeping. When it wAS UNPLUGGED OVERNIGHT AND THEN PLUGGED IN AGAIN I COULD SET THE TIME AND BOIL SOME Water but then it stRTING BEEPING F3 AGAIN.iT is from Oct 2002.
  • 78 Answers
Touch pad on m/w needs to be replace
Posted on Nov 30, 2008
Microwave keeps beeping on GE spacesaver JVM1640WB
Does the display say anything?
If it says "F3" then you have a shorted keypad.
Please post a new question with full model number and more detailed symptoms.
Nov 29, 2012 | Microwave Ovens
We have a GE microwave model JVM1430 that gives an error code of F3 which is keypad. My questionis can it be cleaned versus replacing it. Thank you
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad.
So until it is repaired, please leave it unplugged or leave the door open.
On these models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
It is usually called the "Control panel asm" in the parts list (ref # 105 on the exploded view) .
You simply move your circuit board into the new frame. That is a simple do-it-yourself job.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
Sep 26, 2009 | GE Microwave Ovens
Have a GE model JVM1430 that has error code of F-3
Sep 25, 2009 | GE Microwave Ovens
F3 code on GE
ok here is the result to searching GE the answer to thew code.
Please rate our help to keep this free service online
Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control. · Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace.
If all above is ok replace control.
Aug 28, 2009 | GE JVM1430 Microwave Oven
Ge microwave jvm 1430 error code F3
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Jul 17, 2009 | GE JVM1430 Microwave Oven
GE Microwave displaying --F3--
F3 on a GE / Hotpoint microwave means you have a shorting keypad / controls.
There's a chance it can come on by itself and run unattended, which can result in a fire.
On this model, the keypad is not available as a separate part, so you would have to replace the entire controller assembly.
Then you disconnect the wires and install the new controller.
You can order part number WB07X10903 here for $114.37 (compare that to $174.75 direct from GE!).
Jun 24, 2009 | GE Microwave Ovens
Frigidaire F3 problem
thank you, problem resolve....bought new micro
Mar 22, 2009 | Frigidaire FMV145K Microwave Oven
Spacemaker beeping loud and f3 message driving us crazy
The error code F3 indicates an oven sensor problem. The oven sensor is most likely the failed part. The oven sensor probe must have the correct resistance readings at specific temperatures. When the electronic range control (ERC) cannot identify the correct resistance of the oven sensor or the resistance is way out of specs F3 will display.
I recommend calling a service technician to diagnose and repair your oven.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave shows F3
microwave quits working and F3 comes up on the readout - along with a series of beeps - pressing any of the buttons on the touchpad does nothing - The F3 stays there and beeps intermittently
Jul 25, 2008 | GE JE1460 Microwave Oven
Have a ge spacemaker xl1800 - f3 error
I had the same problem. I removed the grill and opened the control panel as I read an answer from "GENE" on APP (Appliance Pros) that this indicated a short in the circuit board (TouchPad). I was going to replace the faulty circuit board but when I opened the control panel there it was......One wire harness had just came unplugged!! I plugged it in, reassembled and the microwave works again!
Mike
Tampa, FL
Jan 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1440 Microwave Oven Logo
109 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
