Question about Kenmore Elite 45986 Front Load Washer
Front load washer seal issues
Our unit is actually the HE5T, model #110-47088601, I have a service tech. coming out today for an issue we had already had once before, the gray seal between the drum and the door is very thin, even when new and I believe due to the material (possilbe silicone) it wears easily and thins more so and even develops holes or tears due to the possibility of clothing getting in the slot.
We are very careful to zip up coats and even turn them inside out, I know if a zipper gets in there it can do some real damage to the seal. We have had clothing damaged or torn due to getting in this area. I am sure there needs to be some gap but I would think there is a better design, comercial units have to be set up different since you know people are not as careful when the machine is not there own.
This to me is a part that should be made of thicker material. I am sure it will be replaced with the same part today. I spoke to Sears and really did not get anywhere as far as questioning the part design or material, if they have not had other complaints I would guess people are simply not looking or cleaning their unit as the manual describes and they probably have tears etc. in the seal without even knowing it.
I simply do not want to cause any possible water damage to the unit or our house by water that could get through any tears or holes that would develop over time. More so the warranty will be up soon and I will be stuck with a good unit but one that has in my opinion a inferior component. Last time the service tech. replaced it he said if it was out of warranty the repair would have been over $200.00, if that is the case I would rather go purchase a new cheap unit that may not have this issue but I have a matching set and the top folding station that lays across them.
The strange part is other units on the market appear to have a much thicker rubber seal that would not get damaged so easily, with us being as careful as we can without watching to make sure no clothing gets in the groove during the whole cylce I am not sure what else we can do, very frustrating especially after spending a good amount of money on a unit that should be one of the best on the market.
  • 5,911 Answers
I can surely sympathize with you. I can't understand why your door bellow is wearing as fast as you say it is, but some of the common causes are attributed to sharp items on clothing (as you have mentioned). The rubber is usually pretty resilient and can take quite a bit of punishment. Now, using the wrong detergent (non-HE) can contribute to quicker wear of the rubber as regular detergent is at a higher concentration and can act as a corrosive to rubber. In addition, overloading can cause excessive wear. I know the manufacturer states you can really load these washers, but you have to be reasonable about the load size. I actually had a customer explain to me how she laid on the floor in an attempt to push the door shut with her feet to lock it because she was doing a large load. She then couldn't understand how come the door latch was broken. That's a good example of overloading. Now...I'm not accusing you of abusing your appliance. I just put this information out because some consumers simply do not understand that front loaders do require a little TLC.
Some other problems with the door bellow are attributed to leaving the door closed all the time. It is important to leave the door ajar when not in use to allow the wash tub to air out. The following link explains:
http://www.fixya.com/support/r513372-front_loader_mildew_odor
I know you didn't write to me to get a lecture about mildew and mold, but it is important to understand that you have to routinely inspect the door bellow to ensure it is not holding water and small articles of clothing are not getting caught in the folds. I agree that it is a poor design. If the holes in the door fold become clogged with debris and do not drain (coupled with the door staying closed), you can create a stagnant water situation that allows mildew and mold to form. This will also contribute to breaking down the rubber. Keep the small holes in the door fold cleaned out and cleared. NOTE: Leaving the door open will not evaporate all the water. This only allows the tub air out. It is normal to have some residual water remain below the spin basket and in the drain lines.
As far as maintenance costs. You can actually replace a door bellow yourself and cut the cost in half. Searspartsdirect.com carries the part for about $93. Just type in your model number and look under the "Door Latch Parts" heading for item number 2 (part #8182119). Some additional parts to consider are items 1 & 5, which are the bellow clamps (if needed). If you ever need to replace the bellow again and wish to perform this repair on your own, follow these steps:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
I personally own a Kenmore frontloader and have a family of 8. I've owned it for about 8 years now and have never had a mold or mildew problem using the advice I provided you. I did have to replace the bellow ONCE during this time, because they do wear out over time. However...they should not wear out as often as yours.
NOTE: Some consumers are concerned about leaving the door open around small children ,because they like to climb into things. If you live in a household with small children, the washer does have a safety feature that locks the control panel when not in use. Simply press on hold the "Drain/Spin" button for 3 seconds to Lock/Unlock the panel.
I hope you find some of this advice helpful. Let me know if you still have questions/concerns.
Posted on Nov 15, 2008
Hello. I installed a new never used Kenmore washer today front load. As soon as we turned the water on at the back of the machine the water stated to enter the unit, Even when there was no power to the...
Not come across anything like it before, however, check your manual and see what it says about the position of the valve at the back of machine, if you've not already done so....otherwise goodluck.
Mar 05, 2015 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Front door seal installion
Hi Bill Osborn - I am happy to assist you. First, I will need your model number to better address the issue at hand. What exactly is your concern or issue the unit is experiencing? Is the door not sealing properly?
Jan 18, 2013 | Frigidaire Affinity ATF7000E Front Load...
I can't find my users manual and I am getting an rL code on my Kenmore he5t front load washer.. Can you tell me what that means please?
"rL" indicates garments were detected (by weight) inside the wash tub during a Cleaning Cycle. Anytime the cleaning cycle is selected, the wash tub must be empty. Press PAUSE/CANCEL and inspect the wash tub and rubber seal (bellow) for any loose garments. If the error reappears, try unplugging the washer for at least 30 minutes to reset the Central Control Unit (CCU). Sometimes, resetting the CCu can clear momentary program glitches. If the error reappears following a CCU reset, you may have a legitimate issue.
NOTE: EACH ONE OF THESE APPLIANCES COME WITH A TECHNICAL DATA SHEET INSIDE. THIS IS THE SAME SHEET AN APPLIANCE REPAIRMAN WILL REFERENCE ON A SERVICE CALL. REFER TO THE TECH SHEET FOR MORE DETAILED TROUBLESHOOTING INFORMATION.
The tech sheet contains troubleshooting data, wiring diagrams, diagnostics procedures, component illustrations and all error code definitions.
To access, you will need to remove the lower toe panel directly below the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access to the screws (a 2x4 works well for this). With the screws removed, the panel should drop down, and come off. If the tech sheet isn't directly behind the toe panel, it will be affixed to one of the interior cabinet walls.
It is recommended that the tech sheet be placed back inside the appliance when repairs are completed in order avoid losing and to keep this pertinent info for future use. If you have any questions, please post back and let me know. I hope this helps you.
May 09, 2011 | Kenmore Elite HE5t Washer
The rubber seal at the front of the machine has gone mouldy. I have cleaned it before with bleach but the mould comes back all the time
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Oct 21, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
F35 code appears, even after changing the steam chamber.
IT IS THE ANALOG PRESSURE SENSOR NOT THE STEAM CHAMBER.
May 27, 2009 | Kenmore Washing Machines
Clothes washer won't drain - digital display shows LD
looking at the tech sheet for this, it appears to be a standard whirlpool top load but with electronic controls, correct? normalling with this type a lid switch is the issue but the electronics would have a different code for this, LD is Long Drain for this model. suspect a transmission but this should help you troubleshoot. go to www.servicematters.com and click technical reference - tech library - tech sheets, enter model minus 110.prefix. this will show tech sheet with diagnostics. this book can also be found inside your console.
Mar 14, 2009 | Kenmore Elite 45986 Front Load Washer
LG Washer Issue - can you please help
Generally, this happens when the washer was pushed back into place by applying force to the front of the machine, thus pushing the front panel in just slightly. Sometimes you can fix this by just moving the location of the spring of the front gasket clamp from the bottom center to the left side hinge area. They actually make a special tool for expanding the spring, but you can manage without the special tool. Other times you may have to pull the front panel a out a bit or possibly replace the gray gasket / seal.
Nov 28, 2008 | Washing Machines
Kenmore he5t
this looks like a classic whirlpool control board issue. fault is a communication error between board and panel. check connections.
whirlpool always recommends replacing both at same time. very common problem.
Jun 01, 2008 | Kenmore Elite 45986 Front Load Washer
LG WD-3243RHD Front Load Makes grinding, crackling noise
Fixed!
"LE" code Stator/Motor Error.
It was a simple fix and only cost $17.68 at PartStore.com no affiliation.
Hall Sensor 6501KW2001A
http://www.partstore.com/Part/LG+Electronics+Incorporated/LG+Electronics%2fZenith/6501KW2001A/New.aspx
Here is the Service Manual
http://oasisappliance.com/products/lg/LGComboServiceManual.pdf
Bonus, it actually completes a wash cycle and does not stick at 6 minutes, drying forever.
Freakin service tech stated it was the Power Control Board, IDIOT!
While I was in there, I cleaned out the heater blower assembly and sensors. They were full of caked on lint and the sensors had debris all over them.
Also cleaned out all the lint and debris around the rubber seal, this will eliminate those annoying mildew oders.
Hope this helps someone, Happy New Year!
Feb 11, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Kenmore Elite 45986 Front Load Washer Logo
252 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
