Question about AEG 18 in. Favorit 64800 Free-standing Dishwasher
Aeg dischwaher model oko favorite
Drain pump wont switch off . it works but does not allow anything alles to happen as it keeps running
  • 192 Answers
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Posted on Jan 20, 2010
AEG OKO FAVORIT 40300 When switching dishwasher on no water is flowing into the the dishwasher?
It should first be checked for correct water inlet hose with safety valve. After connecting the double-walled water inlet hose, the safety valve is next to the tap. Therefore the water inlet hose is only under pressure while the water is running. If the water inlet hose starts to leak during this operation, the safety valve cuts off the running water and the draining pump in the dishwasher is switched on. If the inlet hose with safety valve working correctly than could be some of following faulties.
  • The door of the dishwasher is not closed properly.
  • Mains plug is not plugged in.
  • House fuse in defective.
  • In the case of dishwasher models with start delay
    timer: A start delay is selected.
If you look at the lower electrical diagram then you can see that all electrical components are located in a circuit inlet valve which can be also faulty.
  • ON/OFF Switch
  • Door switch
  • Program controller (Timer)
  • Pressure switch
  • Inlet valve
  • Float switch
  • Wiring between all this components
Dado
Sep 15, 2015 | AEG Dishwashers
Aeg oko favorit 40300 service manual
Please help
Jan 11, 2012 | AEG Dishwashers
I have water in the bottom of my AEG OKO-Favorit
did you take the air gap by the faucet apart they plug alot the fist thing i usually check disconnect drain hose lay it in a pan does water drain, may need new pump
Dec 27, 2009 | Dishwashers
AEG OKO FAVORIT 6050 trips earth leakge
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
Dec 20, 2009 | AEG 24 in. Favorit 60830 Free-standing...
The drain pump on the AEG oko favorit 6050 keeps running even when the on/off switch is off or the door is open.
Empty all the water from the salt resevoir, (I used a turkey baster), then rock the machine backwards and forwards a few times and empty the last few drops from the resevoir again.
Oct 17, 2009 | AEG Favorit 50500 Built-in Dishwasher
Have an Aeg oko 4020 dishwasher. Installed a new pump and it worked for awhile. It now won't switch off but the cycles do not run. Someone suggested there maybe water in some area that has caused some sort...
it probably has water in the bottom tray
take bottom front panel off and this exposes the bottom tray
mop out water and machine will run
if fault reoccure then you have a leak
Nov 29, 2008 | AEG Dishwashers
Drain pump keeps running AEG oko favorit
Aug 29, 2008 | AEG Favorit 50500 Built-in Dishwasher
AEG OKO-FAVORIT 50800
C3 error means that there is water at the bottom of the dishwasher. Unplug the dishwasher, slide it forwards and push it back. So it stands on the 2 back knobs. Do this atleast at a anle of 45 degrees. You will see water flowing at the floor.
If this happens often you have a leak somewhere. Time to cal the technician then.
Mar 03, 2008 | AEG Dishwashers
Open Questions:
AEG 18 in. Favorit 64800 Free-standing Dishwasher Logo
1,395 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
