First wasnt working at all. I seen motor was full of dust so i vacuumed it off. now it works but ac not blowing out cold air.
SOURCE: furnace fan running off and on blowing cold air
Need a little more info. Does the fan never stop? Is this a gas furnace? Is your thermostat in the fan auto not fan on position?
SOURCE: ac blowing hot air instead of cold
Check for the following problems
(1) Check if compressor is geting power
(2) Check if system have Refrigerant in it
(3) Check if pressure switches are operational
(4) Check Thermostrat setting.
(5) Check for dirty or block condenser or evaporator
Send feed back if you solve problem
SOURCE: Refrigeration AC not blowing cold air
If you can hear the A/C compressor start and run then your system has lost it's charge of refrigerant. If the compressor does not start and run it could be a control problem.
SOURCE: ac BLOWING HOT AIR INSTEAD OF COLD
Check to see if your outside unit is running. If not, check the breaker. If it is running you may have an issue with the reversing valve. It looks like three lines coming out of the top and one on the bottom. Trace the wires back to see that they are tight and secure. Of course, TURN OFF THE POWER first. good luck.
SOURCE: lennox air unit not blowing cold air
your fan motor outside is going bad, have a service company change it out for you.
the motor stopped working and that overheated the compressor shutting it down on thermal cutout, and it will only come on once it cools down
theres no outdoor unit
it installed in a double wide manufactured home
