Question about Baby Lock Esante
Touch screen very light
I have an older Esante model and the solution with holding down the 3 the buttons and then turning on the machine to recalibrate does not work. Please advise a different solution.
Thanks
I selected the basic operation, adjustment, then brightness of lcd.
Posted on Nov 16, 2008
  • Baby Lock Master
  • 1,388 Answers
When your BabyLock Esante ESi2 is otherwise working fine but the LCD display screen begins to grow darker and you find you just can't read it, the only thing you can do is replace the BabyLock Esante ESi2 LCD screen, or buy a new machine. BabyLock no longer stock this item direct, but there is an affordable replacement available....Check this Link
https://www.bargainbox.com.au/product_info.php?products_id=2169
Posted on Dec 13, 2011
When I try to recalibrate my BL Esante ESe, I get a screen with the numbers 1 - 30 instead of the normal 1-5
Turn off machine.Hold in the 3 buttons above the needle. Turn machine on, In screen calibration mode. Using touchpen carefully touch numbers 1-5 in order. repeat until you hear beeps. turn off machine. restart and your good to go. Hope this helps.....
Jan 13, 2018 | Sewing Machines
Flashing Display, Won't Connect to Computer.
I have not yet seen babylock release a driver for windows 8 and the BLN. The dealer likely has a computer with an older operating system.
Jun 09, 2015 | Baby Lock Esante
Reset button on Esante ESe2
1. Turn the power on while holding down the [Start/Stop], [Reverse stitch], and [Needle position] buttons.
2. Touch the positions marked with crosses (+) on the touch panel in order from 1 to 5.
NOTE
• Setting is successful if a single beep sounds when "5" is pressed.
• An error has occurred if two beeps sound when "5" is pressed. Repeat from position 1 again.
3. Turn the power off and then on again. Check that the screen display matches the positions on the touch panel
May 17, 2015 | Baby Lock Esante
How do i do a screen calibration on a PC-8500 sewing/embroidery machine?
C. POSITION OF TOUCH PANEL
STANDARD
The deviation of the liquid crystal display and touch panel should be within 1 mm when the touch
panel is pressed.
ADJUSTMENT
1. Turn on the power switch while holding down the start/stop button, backtack button, and
NP button simultaneously.
2. While holding down the start button, press the + positions 1, 2, 3, 4 and 5 on the screen in
order. If the buzzer sounds once when 5 is pressed, the position is okay. If the buzzer
sounds several times, the position is erroneous; therefore, adjust again. (When pressing
the screen, use a pencil (or match) with a round tip.)
3. Turn on the power again, and confirm that the screen display and touch panel positions
match.
Nov 18, 2014 | Brother PC-8500 Pacesetter Embroidery &...
Pc-8500 how to calibrate touch screen
ADJUSTMENT
match.
I cant remember how to recalibrate my baby lock esante ESe.I found the answer before but didn't write it down.Now it is out of calibration again and I can not find how to do it. Please someone help. I
Turn off machine. Hold in the 3 buttons above the needle. Turn machine on. Voila in screen calibration mode. Using touchpen carefully touch numbers 1-5 in order. repeat until you hear beeps. turn off machine. restart and your good to go.
Oct 01, 2014 | Sewing Machines
Touch screen
the machine should be checked to see if there is something wrong with the motherboard.
Sep 03, 2013 | Baby Lock Esante
Won't work at all-esante ese baby lock
Check that the button used to snip your thread at the end of your seam is not stuck. Mine will sometimes stick and if I just touch it again it will again activate and the red start/stop button will work again.
Apr 08, 2009 | Baby Lock Esante
My touch screen doesn't always work. Sometimes I have to touch all around the square and even then, it won't come on. At times, it stops working when I want to change patterns. It seems to work most of the...
Yes, I have a solution for this problem. Your screen needs to be recalibrated and you can do it yourself. Don't you wish they would just tell you this stuff instead of charging you an arm and a leg? Here's what to do: Before turning on the machine, press the start/stop button, the reverse button, and the needle position button all at once with one hand (one finger on each button). Hold them down and turn on the machine. What will come up is a recalibration screen. You will see the numbers 1-5 with a little plus sign beside them. Find a small blunt object (I used the tip of a mechanical pencil with the lead in instead of out) and while holding the start/stop button, touch the plus sign beside 1-5 in numerical order. Then, turn the machine off and on again in the normal way. This should recalibrate the screen. Pass it along, people! This is something no one should have to pay for!
Nov 03, 2007 | Baby Lock Esante
Sewing Machines Logo
309 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
