Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Drying cycle runs but does not dry clothes
After washing one evening, the clothes had almost stuck to the outside of the drum during the spin cycle. Subsequently when drying later I noticed the machine making a funny sound - I stopped and checked the load to find that there was a burning smell - I am presuming that the drying element may have burnt out due to the fact that no air could enter the drum because the clothes were stuck in the drum holes?? If anyone could advise if this is the case and the element needs replacing or if something else has burnt out?? Currently the drying cycle runs but the clothes are still wet afterwards? Regards Martin
    Novelist:
    Champion:
  • 244 Answers
More than likely that your thermostats have blown if you could smell the heater element getting hot then this will be the case m8
Posted on Aug 22, 2007
SOURCE:
During the spin cycle it spins correctly until the last 2-3 minutes and then it just fluffs clothes
Some machines used a variable speed slow down process to avoid clothing damage, this removes the items from the outside of the drum where if the clothing was left for a length of time after the cycle has finished it could damage the fibres, this way the clothing is also easier to remove from the machine and promotes airflow over the items
Jun 14, 2016 | Sears Kenmore Elite 3.9 cu. ft. Front-Load...
I have an LG model WF-T7015TP Turbodrum top-loader automatic washing machine. Having problem in that the drum does not agitate to and fro during the washing cucle. It's draining fine and even spin-drying...
check the agitator module unit and the start capacitor both in the back of the control panel One controls the agitation and the other starts the motor. If the start capacitor is failed simply replace it with a new one The agitator module will cost more . Have an appliance electrician check it out.
Aug 16, 2013 | LG WFT1071TP Top Load Washer
LG washer - loud noises & brown spots on clothes.
The drum bearing has perished this wild cause the noise and the brown spots on your clothes is probably the grease from the bearing
May 05, 2017 | LG WM2077CW Laundry XL Front Load...
I have a Kenmore frontloading washer, model no. 417.42042100. At the end of the wash cycle, the clothes are still very wet; that is, still SOAKED with water, even though all the water has been drained...
HI. your unit is equipped with a spin control board. this board, if damaged, will not initiate an adequate spin. This will not allow for proper drainage and drying of the clothes. The spin motor regulates the rotation speed during the spin cycle. It seems to be the culprit at this time. Have the spin board replaced asap.
This part will usually cost around $150.00 at the most.
Aug 27, 2009 | Kenmore Washing Machines
Clothes dryer drum stops turning during drying cycle
your motor is going out , it doesn't have wenough to keep going.
Jun 26, 2009 | Dryers
My LG TROM wash googd but dosn't want to spin
Check and see what type detergent you are using. I bought regular liquid detergent and the machine began making noise during the spin cycle and the drum would not spin. I was informed that you have to use detergent that is labeled HE (High Efficiency). The regular liquid detergent will suds up during the wash cycle which then causes the drum to slip and not spin during the spin cycle. What you are hearing during the spin cycle is the drum slipping. Unplug your washer for 30 minutes and let it reset. This lets the suds dry out. Run a cycle with no spin to rinse out the drum. This should eliminate your problem. If you have clothes in the machine, run a cycle with no spin, just don’t add any more detergent. Then run the normal cycle with spin a second time with no detergent. I hope this cures your problem.
Apr 11, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Clothes not drying even after 4 cycles
you have to check your dyer vent hose and vent pipe to outside for any restrictions. #1 problem for extented drying time. it like having a backed up sink
Dec 13, 2008 | Maytag PYE2200 Dryer
LG all in one washer dryer fills with water on the drying cycle
the unit is made to bring water in in the drying cycle ,,the water dont touch the clothes..the water is to take the lint away and to cool the drum,,you must remember that you can was 22 pounds but you can only dry 11 pound..so you must dry about half of what you wash..and drying the 11 pounds it will take 3 to 4 hours,,no exhaust...
Sep 21, 2008 | LG WD-3274RHD Front Load Washer / Dryer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
531 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
