Question about ViewSonic PJ556D DLP Projector
Lamp won't come on
Powers on green but then goes into the amber flashing mode both for Source and Power lights. It's been working great until now.
    Genius:
  • 1,447 Answers
Hi
Check the cables, try taking out lamp and put it back in. If all fails replace the lamp.
Hope this helps
Posted on Nov 15, 2008
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
Panasonic PTL500 LCD HIDEF projector - Unit occasionally powered up briefly, lamp lit, then shut down, standby LED flashed orange/red. Sometimes lamp lit and sometimes not. Technician diagnosed bad ballast...
The bulb is a discharge type - it needs a very high tension to work. The role of the ballast board is to convert the low voltage DC current coming from the power source in a high tension DC current for the bulb. Unfortunately you were truly unlucky : when the ballast board died it sent a high tension surge thru the power source and from there at the other components on the mainboard - the processor couldn't handle it and got fried. So now when you try to start the projector this is what happens: the power source starts normally - the status light goes to green as it should; it functions normally so it powers the ballast board and the rest of the mainboard - the ballast works so the bulb lights up; the mainboard on the other hand remains dead because the processor is dead so no sustain signal is sent to the power source; without the sustain signal the power source goes, as it should , in an very normal stand-by - the status light goes to red.
The entire mainboard will have to be replaced - you can't replace just the processor, it's glued in there. This is going to be expensive so ask a quote before doing it.
Dec 23, 2010 | Televison & Video
My samsung 46 in. hdtv will not power up when plugged in standby light is lit turn on then it flashes lamp led it after theen goes back to standby mode repeats this process three times then all three...
Have you Check the Lamp Fan is it still running while Lamp trys to light?Ballast board is what powers Lamp on ,but if the Lamp Fan is defective Lamp will not light.
Sep 10, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Tv shutdown
check your lamp door interlock switch.
Jul 31, 2010 | Mitsubishi WD-65733 65" HDTV
Just replaced lamp. when plugged in, power light
hello make sure the lamp is fitted securely and the lamp cover aswell
regards
shaun
Jan 16, 2010 | Panasonic PT-50LC13 50" Rear Projection...
I have the same issue minus the clicking
check the lamp for bulges, black spots, or fogging. if that's ok, check the colorwheel. if that doesn't spin, the lamp won't light. if they are ok, replace the ballast.
Sep 30, 2009 | InFocus SP-LAMP-LP3F Projector Lamp for...
4600C no power, flashing amber light
i have a dimension 4600c. same problem. amber flashing light no sounds. replaced my power source and its now working fine. bought one on ebay for $47
Apr 11, 2009 | Dell XPS 700 PC Desktop
Panny pt-50lc13 steady amber flashing light
Sounds like a defective lamp diever or ballast.Listen for a buzzing sound when you turn the set on. If you do not hear it then most likely you have a bad ballast or lamp driver. Worst case scenerio would be the engine itself.
Dec 28, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Projector
A couple of things...
If the fan is not working, the lamp will not fire. If you have the owner's manual, it should indicate what the flashing lights mean. Check to make sure that the panels are seated properly. When you replaced the lamp, the outer cover was removed. If that is not seated back 100%, the unit will not work. There are a number of safety "checks" built into the unit to prevent damage and possibly fire as the lamps get really hot.
Check the items above and let us know your progress.
Dan
Jun 19, 2008 | Dell 2300MP Multimedia Projector
ViewSonic PJ556D DLP Projector Logo
241 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
