Question about Philips Philishave HQ5812 Electric Shaver
My shavere fell to water the stops working. I open it and saw that the the chip is faulty (broken). What is the chip part number and desctiption? does anyone have schemes? ASAP
0 characters
1 Points
Philips Shaver Faulty
Replacement under warranty involves promising to remove the battery from the old shaver and disposing of the battery and the carcass in an environmentally safe way.
The shaver can be split apart after removing three torx screws and then prising the plastic parts apart against their clips. Be VERY careful when releasing the plastic clips inside because they are brittle and fragile.
On opening the cover containing the battery, motor and control circuitry the ingress of water was clear. The shaver is supposed to be wet and dry, has only been used dry but the exterior has been washed.
The water was displaced using WD40. The shaver operated normally straight away. If your shaver's motor starts with the button but stops again half a second later, the problem might be caused by water ingress.
Dec 16, 2013 | Philips Aquatouch At890 Wet And Dry...
When does the batteries need replacement?
the shaver will slow down as the batteries discharge. To suddenly stop suggests either loose batteries or faulty switch. There should be a charging cradle for the shaver to keep it working but if you need batteries then open the battery cover and replace with the same batteries.
Jun 26, 2013 | Shavers
My Igia AT7352 micro hair trimmer fell and came apart. I need a drawing to show me how to reassemble it please
mcdevito75 here, You try online at or you can try a drugstore to re-assemble the shaver for you if they can, some parts may be broken.
Jun 30, 2010 | Igia AT7352
Blades fell off oster dog clippers but can't fit them back on. Please help !!
With the hinge of the clipper facing you:
Make sure hinge is open, if it is not, prize it open with a flat head screwdriver.
Slide the blade on with the blade siz/number faceing you.
Snap shut.
If this fails, try again, but push the latch in as you snap them shut.
If this fails, you may need repair!
May 15, 2010 | Oster Golden A5 2-Speed Universal Motor...
I dropped the razor and the 3 heads fell off, nothing is broken, but I can't figure out how to put it back together Help!
all you have to do is put them back in there place you should have two legs that spring out from the blades align them with the 2 holes on the shaver and push them in
Oct 21, 2009 | Philips Philishave HQ8150 Electric Shaver
The shaving blades came loose and fell off my sunbeam shaver, how do i put them back on?
Make sure the clippers are running.
Make sure the hinge (the bit you put the blade on) is open, if it is not, prize it open with a flat head screwdriver.
With the hinge open and facing you, slide the blade on the hinge with the blade number/size facing you. Snap the hinge shut.
Jan 27, 2009 | Sunbeam Oster Blade 918-306 Size Texturing...
Springs fell out
I did get it fixed. I kept looking at it and studying it and I finally figured out that the small, gold head is where they had to go. I pushed on it and it finally fell out. I saw two small holes that looked like they were the same size as the springs. I put them in and when I put the piece back in the razor, the spring lined up with 2 small pegs on the inside. I snapped the head in place and the gold bars then moved up and down with a little resistence. I turned the shaver on and it worked just fine.
Sep 10, 2008 | Shavers
Part fell out of cleaner base
It's probably one of the support rubbers that holds the shaver in place, and keeps it from falling too low into the cleaner. It's probably broken, but maybe you could put it back in place. There are two of those rubbers in the cleaner on the side where the trimmer is faced. If they both are broken, the shaver will fall too low, and the electric contacts on the top will also not fit - no charging as a result. My Braun service rep. said that the whole cleaning unit will have to be replaced to fix this. My plan, however, is to try with some small screws before I throw the whole thing in the "broken parts basket"....
Jan 30, 2008 | Braun Syncro 7680 Electric Shaver
Philips Philishave HQ5812 Electric Shaver Logo
23 people viewed this question
Top Philips Shavers Experts
Robert McClure
Are you a Philips Shaver Expert? Answer questions, earn points and help others
