Question about Sony CDX-S2210 CD Player
Need a wiring diagram for CDX-GT23W, which blue wire goes to the amplifier?
iadame
  • 676 Answers
SOURCE: I need the wiring diagram
The following should help you out.
Posted on Mar 25, 2011
  • 11 Answers
SOURCE: need a wiring diagram for a sony cdx-gt08 it is
yellow to yellow main power wire
red to red key wire
black to black ground
speaker wires are green purple for rear speakers and white and grey for front speakers solid wire color is power and black lines is ground
orange is dimmer switch you wont need it
blue wire is for power anntenna your car shouldn't have it and blue with white stripe is remote wire if you have an amp it will shut off your amp when hooked up any other wire unnessary for your car some head units need a anntenna adapter to work good luck. remember ground before anything and disconnect the battery so you don't blow the fuse
Posted on Mar 14, 2010
welcomejee
  • 10594 Answers
SOURCE: need a wiring diagram for sony cdx-gt41ou head
Click Sony Support to download wiring . connection manual of CDX-GT410U
Posted on May 17, 2009
SOURCE: Wiring Diagram For Sony Disc Player
how do i install a cdx-s2210 to my 92 camry..what wires do i connect?
Posted on Jul 11, 2009
  • 10 Answers
SOURCE: need wiring diagram for sony cdx-gt200
blue\white stripped= amp remote
black= ground
blue= ant
red=positive
yelow=positive 12v
white=left +
white\black striped= left -
gray= right +
gray\black striped= right -
green=left rear +
green\black striped=left right -
purple=leftr rear +
purple\black striped=right rear -
Posted on Jul 19, 2009
Need color code from cdx gt23w to put original plugends back on
Sony has the documentation for the CDX-GT23W on the product support page: https://esupport.sony.com/US/p/model-home.pl?mdl=CDXGT23W&template_id=1®ion_id=1&tab=manuals#/manualsTab . Look at the Installations/Connections guide under manuals. The wiring diagram is in diagram 3.
I hope this helps.
May 31, 2015 | Car Audio & Video
Lost the power speaker plug to my sony xplod cdx-gt23w how can i get a wiring schematic to insure the plug i have is the correct wiring order
click here for install manual click this link then click on the tab manual and spec then select the sony install manual and view the harness wiring diagram to double check you wiring . have any question email me at
radiorepair@windowtintingin239.com
Oct 28, 2013 | Sony Car Audio & Video
I get sound with radio but not with cd or USB, even though the display says they are working (cdx-gt590ui)
use the blue/white wire to turn your amplifier on. the blue wire is antenna remote turn on, the blue/white is amplifier remote turn on.
when the radio is not in tuner mode the blue wire turns off.
Feb 04, 2011 | Sony Xplod XM-1652Z Car Audio Amplifier
Need a wiring diagram for a sony cdx-gt08 it is going into a 2000 saturn sl2 I have the new wiring harness but need to know what wires go where
red to red key wire
Mar 13, 2010 | Sony XPLOD CDX-GT200 CD Player
I have a sony xplod cdx-gt09 and i need the wiring manual I don't know where each cable goes
COLOR FUNCTION
You can use the following. You may not have all the wires but you should have most. Good Luck and please rate.
RED ACCESSORY
YELLOW BATTETRY
BLACK GROUND
BLUE POWER ANTENNA
BLUE/WHITE AMPLIFIER TURN ON
ORANGE ILLUMINATION
ORANGE/WHITE DIMMER
GRAY RIGHT FRONT +
GRAY/BLACK RIGHT FRONT -
WHITE LEFT FRONT +
WHITE/BLACK LEFT FRONT -
VIOLET RIGHT REAR +
VIOLET/BLACK RIGHT REAR -
GREEN LEFT REAR +
GREEN/BLACK LEFT REAR -
Dec 02, 2009 | Televison & Video
I need a sony cdx-gt23w head unit wiring color codes
The web site should have it, but if it doesnt they are usally color coded...if they are not i would take it to a radio shop.
Nov 01, 2009 | Car Audio & Video
I need a wiring diagram for sony cdx-m630
red -Acc power
yellow -12 memory power
black -ground
blue -amplifier remote
blue/white -power antenna
SPEAKERS
white left front +
white/black left front -
grey right front +
grey/black right front -
green left rear +
green/black left rear
purple right rear +
purple/black right rear -
Aug 27, 2009 | Car Audio & Video
I need a wiring diagram for this stereo
FOR 16-PIN HARNESS
Pin Number Wire Color Function 1 White Left Front (+) 2 Green Left Rear (+) 3 Violet Right Rear (+) 4 Grey Right Front (+) 5 Blue/White Amplifier Remote 6 Blue Antenna Remote 7 Red Accessory 12 Volts 8 Black Ground 9 White/Black Left Front (-) 10 Green/Black Left Rear (-) 11 Violet/Black Right Rear (-) 12 Grey/Black Right Front (-) 13 Sky Blue Telephone Mute 14 Orange/White Illumination 15 Not Used Not Used 16 Yellow Constant 12 Volts
FOR 9-PIN HARNESS
Pin Number Wire Color Function 1 Not Used Not Used 2 Black Ground 3 Grey Right Positive 4 Grey/Black Right Negative 5 Blue/White Amplifier Remote 6 Red 12 Volt Switched 7 Yellow 12 Volt Constant 8 White Left Positive 9 White/Black Left Negative
MAY THIS HELP YOU
Jul 04, 2009 | Sony CDX-GT210 CD Player
SONY CDX-M8800 STEREO
Red (accessory wire)- goes to hot wire that can be turned off.
Yellow (constant wire) goes to your cigarette lighter
Blue/white is your amplifier remote turn-on wire.
Probably have green and green/white- brown and brown/white-white and white/black, and another color for speaker wires.
You can hook one pair up to your cd player and find out if it's hooked up to the right speaker channel.
Orange (remote antenna) wire.
Apr 20, 2008 | Sony CDX-M8800 CD Player
Sony CDX-S2210 CD Player Logo
1,638 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
