Question about Bunn BT10B Coffee Maker
BUNN BT10B carafe leaks from spout down side while pouring
My sister and I love this coffeemaker but both of ours leak from the pour spout on the carafe--making a mess everytime we try to pour a cup of coffee. I emailed the company and they advised to scrub the spout with scrubber before each use which sometimes made it leak a little less but never has solved the problem.
  • meizelis Nov 16, 2008
    I have had the same problem & cleaned the spout too but the problem has never gone away. I finally gave up & bought a $15 replanement coffee maker that has a heating element for the 12 cup pot.
    Know of anybody that needs a used Bunn caffee maker?
  • mjemons Nov 29, 2008
    I too have this problem....and so do my in-laws. Frustrating and there's nothing we can do!! Love the maker but hate the decanter....funny how there's a new decanter with this model. I would love to buy the decanter only but I can't seem to find one.
I emailed the company again and they are replacing the thermal carafe at no charge. Thanks!
Posted on Nov 19, 2008
    New Friend:
  • 3 Answers
There is a rubber seal on the inside of the carafe. Cut the seal out where the pour spout is and this should solve your leaking issue.
Posted on Nov 13, 2015
MY BUNN COFFEE MAKER MODEL BTX-B BREWS SLOWER THAN IT USED TO. IS THERE A WAY TO CLEAN IT?
To clean your brewer, pour in 1 qt of white vinegar into the top, place the carafe on the base and close the lid. Allow the vinegar to sit in the machine for 2 hours. After 2 hours, turn off the machine and let it cool. Then remove the sprayhead and insert the metal spring(deliming tool) into the hole where the sprayhead was and twist it 5-6 times. Then you will flush out the machine by pouring 8-10 carafes of water through the machine.
Jun 16, 2010 | Bunn BT10B Coffee Maker
When pouring coffee it drips, also doesn't keep coffee hot
Hi - Any time I've had an issue with my Bunn BT10-B, I go to the website, www.bunn.com , and go to their Customer Service area. They have been extremely helpful and informative.
Aug 16, 2009 | Bunn B10 Coffee Maker
Our Bunn has a thermal carafe. This thing has leaked every time we pour our coffee. We pour over the sink most of the time. Now for some reason the metal has slipped from the plastic rings holding it. Is...
I do apologize that you haven't received an answer. The thermal carafe can be replaced at no cost to you but simply calling customer service with the model and date code.
Apr 19, 2009 | Bunn Coffee Pots: Thermal Carafe
Leaking pour basin
Your only hope of getting a new tray for these would be if your local Bunn repair shop has some hanging around that broke down for another reason. This is a very common problem with those models. You can find a list of Bunn repair depots at www.bunn.com Good luck!
Jan 21, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn coffeemaker
If you still have warranty on the machine take it in to the nearest service center.
Its probably a lose pipe in the machine. so if you dont have warranty left just open it up and look for lose pipes and reconnect them.
Jul 14, 2008 | Bunn Cuisinart Coffeemaker: Pour-Omatic...
Empty bunn coffeemaker
The easiest way to empty these brewers is to turn them upside down over the sink. Turn it on it's side, always keeping the fill hole down toward the sink, and keep on going until you have the unit completely upside down. If there is a push switch under the lid to stop water from going into the pot until the lid is closed, you will have to keep this pushed in until the unit is empty
May 30, 2008 | Bunn Cuisinart Coffeemaker: Pour-Omatic...
BUNN Pour-Omatic
Most likely it is your tank heater, but look on the top of the tank heater, because sometimes the wire will burn off the top of the element
May 20, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Lid on carafe
Sadly, I have about 10 people who have this coffee maker. It is a wonderful little coffee maker and is very delicate.
the worst problem all the people here say is the lid leaks like a waterfall or it leaks by dripping non stop while pouring.
I had to call Bunn, who made this machine, and they have yet to figure out a solution to this problem other than having people who own this machine buy a whole new carafe with new seals.
You might try your local applianace repair store. Sometimes their engineers are smart guys who knows exactly what seals will work or where to get the parts you need better than the actual manufacter.
May 12, 2008 | Bunn BT10B Coffee Maker
Drips onto counter when pouring from carafe
There are other makes and models with carafes that do the same thing. One tip I saw on tv, though not for this particular brand, said one cheap fix was simply to smear the tiniest trace of vegetable oil or shortening on the pour spout. What is happening is that the liquid wants to cling to the pot. It doesn't like letting go of the surface. But water-based liquids readily let go of oiled or greasy surfaces.
I have a Stay and Go. I had the same problem. I tried this technique, and it worked immediately. Two issues I imagine folks will have with this is, it doesn't last (after a few cups, the hot water has cut the oil off the spout) and they will not like the idea of oil or shortening in their coffee. But the amount you need is so small, I never saw a trace of oil or grease in my coffee cup at all.
It does work, but... perhaps a different spout design or material would be better? Don't designers know about such problems?
Joe
Mar 02, 2008 | Hamilton Beach Stay or Go 45234 Coffee...
My bunn is too slow
Use the de-liming spring to clean the copper tube behind the spray head. Pour several pots of clear white vinegar through the unit to further remove lime and scale from the interior of your coffee maker. My Bunn is 24 years old, and the only replacement parts I've ever required are new carafes and the 4041 silicone washer repair kit.
Sep 15, 2007 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn BT10B Coffee Maker Logo
1,044 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
