Question about Hitachi 60V500 60" Rear Projection HDTV-Ready Television
Yellow spots & dulling picture
ARe the bulb and "light engine" the same? It appears this may need to be changed. Is there more than one? Is this something I can do myself? Where can I purchase these most reasonably?
    President:
  • 1,952 Answers
Hitachi WILL replace the part.... They will sent a new light engine free of charge When you call them make sure to ask for their superior if you get denied by someone.
Posted on Nov 15, 2008
  • 3,037 Answers
No they are not the same, two completely different componenents
www.partstore.com
the above website should have a new part
It is only the light engine that you should be replacing which is a pricey part
If you have any more questions, or need help finding the specific part, please let me know
  • 101 Answers
No, as far as I know, These parts are related but they are not the same.
Its not a cheap part have a look around this website
http://www.nexttronics.com/catalog/hitachi/U/UX22201DR.htm - note that this is most likely not the part you need, look for the correct part with your model number, or part number.
    President:
  • Hitachi Master
  • 1,314 Answers
No, the light engine is the whole assembly that the bulb fits in, They aren't cheap, though you could probably replace it yourself with a little patience in a couple of hours or so.
  • Kevin Shafer
    Kevin Shafer Nov 15, 2008
    I've located one for $475 or so.
  • Kevin Shafer
    And here is the manual that will tell you exactly how to remove and replace it :c)
We have a Hitachi 50vf820 LCD television. We have changed the lamp several times since purchase. The picture is dull and not as sharp as it was new. We also have blue/purple splotches around the...
you can fix the dimmed look to the tv by purchasing a new ballast for the DLP bulb.
The spots are non-repairable as they are in the light engine assembly and those are nearly $500-$600 and very labor intense to install.
Hope this helps. Click the hyperlink above to buy the ballast.
Please rate!
Apr 11, 2011 | Hitachi 50VF820 Projection TV
I just replaced all 8 bulbs in my projectors. we are a large church and they are used quite a bit each week. when i tested them yesterday, one of my projectors had a yellow dull spot in the center of my...
Hi
If spot is light ( like a clouds ) then probelm is with dust .if is dark then LCD panel is faulty.pl conatc your nearest service centre
ANS BY
M.R. Mumbai & Dubai
Aug 31, 2010 | Sanyo PLC XF45 Multimedia Projector
Having a big yellow spot background in the middle of the picture.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 09, 2010 | Hitachi 50VS69 50" Projection HDTV
I Followed the directions and changed the bulb. When
there is a burn spot on one of the light filters located next to the blue lcd panel. it is caused from excessive heat and dust. unfortunately, you'd need to replace the entire optical engine because infocus does not sell individual optical engine parts.
Oct 06, 2009 | InFocus Proxima UltraLight S520 Multimedia...
CRT monitor's background colour is changed to dull yellow colour
hello,
i think this problem accure due to chage of CRT CATHODE. if you are not a hardware engineer then check it from hardware engineer. any crt monotor have 3 RGB Cathode to release electron on screen. the electron comes shodow mask and create a pixel on the screen the pixel make a picture. The RGB color make the perfect picture. if your picture is dull then i think that happen due to less negative chage of Cathode or any Crt base Bios ic is failior. so you have to checked it from hardware engineer.
ok
bye
Oct 22, 2008 | Samsung 21" FLAT CRT COLOR MONITOR
Yellow spots are appearing in the upper right quadrant of the screen. After the set has been on for a couple of hours a second spot appears in nearly the dead center of the screen. This issue coincides...
Try the new lamp as indicated by the blink codes. That may resolve the problem. If not, the problem is in the "light engine" portion of the set which should be covered under warranty.
Keep us posted.
Dan
May 29, 2008 | Panasonic PT-52LCX65 44" HDTV
Yellow spot on Sony 55"
Possible dust in light engine? What ever you do, don't blow it out with the set on or hot. This easily equals instant death to bulb.
Apr 23, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Yellow Spot
Sorry that I have to be the one to let you know this but the light engine in your set has a spot that has developed on your lens. It is not possibile to clean this without making your picture worse. The light engine would need to be replaced in your set to fix this and the cost will not be cost effective. Part number is 3141VSN916C and I cant find it at any dealer for less than 1200 dollars.
Josh
Feb 08, 2008 | Zenith E44W48LCD 44" Rear Projection HDTV
Hitachi 60V500 60" Rear Projection HDTV-Ready Television Logo
67 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
