Question about Cell Phones
Display problem my phone is having display problem.it occours 2 time in every month and it remains bad till a day or two. actually what happens is display goes as plain white and nothing could be seen.or shows vertical colored lines. i tried switch off and switch on but it doesnt work
  • 101 Answers
What phone is it?
Posted on Nov 16, 2008
Phone shorted out
1. try and replace the base cord (goes from the phone to the wall)
2. try and plug into another jack within the office
3. If it does not work go to http://www.telecom.toshiba.com/ and find a dealer as it has to be trouble shot back in the KSU of the system
Sep 05, 2013 | Toshiba Lands Phones
My wife and I had purchased E63 mobile set each, since the time of buying for almost 10 months now, we are facing frequent problems of the mobile hanging especially while receiving a call. We had even...
Please see that your memory card is not crowded with media files, that only safe scanned files are loaded.
See that you are not receiving through bluetooth files from other cameras which is corrupting the software.
Also check your inbox messages, delete offf any media messages.
When this happens remove battery, memory card and replace only battery back after some time till the software loads and corrects, then put the memory ( have it scanned in your laptop for any virus)
Sep 03, 2010 | Cell Phones
Display Clock
Changing the time on a Norstar system must be done using a display phone. Using a M7310, M7324, or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) 5 times - display should read "Time and Date"
4.- Press "SHOW" (top right arrow)- display should read "Hour:___"
5.- Press softkey "CHANGE"
6.- Enter hour - display should read "AM OK or Change"
7.- Select AM or PM
8.- Press "NEXT"(bottom right arrow) - display should read "Minutes:___"
9.- Press softkey "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___" 12.- Press softkey "CHANGE"
13.- Enter year
14.- Press "NEXT"(bottom right arrow) - display should read "Month:___"
15.- Press softkey "CHANGE"
16.- Enter month
17.- Press "NEXT" (bottom right arrow)- display should read "Day:___"
18.- Press softkey "CHANGE"
19.- Enter day
20.- Press "NEXT" (bottom right arrow)
21.- Press the Rls key
Apr 01, 2010 | NorStar M7324 Corded Phone
How do i change the time on a norstar m7208 phone
Changing the time on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4" 2.- Enter password (default = 266344) - display should read "Terminals & Sets" 3.- Press "NEXT" 5 times - display should read "Time and Date" 4.- Press "SHOW" - display should read "Hour:___" 5.- Press softkey "CHANGE" 6.- Enter hour - display should read "AM OK or Change" 7.- Select AM or PM 8.- Press "NEXT" - display should read "Minutes:___" 9.- Press softkey "CHANGE" 10.- Enter minutes 11.- Press "NEXT" - display should read "Year:___" 12.- Press softkey "CHANGE" 13.- Enter year 14.- Press "NEXT" - display should read "Month:___" 15.- Press softkey "CHANGE" 16.- Enter month 17.- Press "NEXT" - display should read "Day:___" 18.- Press softkey "CHANGE" 19.- Enter day 20.- Press "NEXT"
Nov 01, 2009 | NorStar M7310 Corded Phone
I have a 91 cherokee.had less than a year.just bought a new battery 2 months ago.my problem is if i let it sit for more than 3 days the battery goes dead.could the alarm sys have anything to do with this?
Yes, and no... at this point you haven't done any testing so anything electrical is suspect. First, you need to check obvious items such as glovebox light etc to make sure they aren't staying on...Then you need to remove one battery terminal and put an ammeter between the terminal and wire. Start pulling fuses one by one till draw shown on ammeter drops. Check to see what system that fuse serves and you can begin narrowing down the problem. If after removing all fuses the draw remains it's likely that there is an internal bleed off in the alternator. sometimes a bad diode or regulator can do that. I would first have the charging system and the new battery checked ...there are defective batteries, not often as there once were, but it can happen.
Jul 30, 2009 | 1991 Jeep Cherokee Limited
Dispaly light off at playing a Videofile but sound remaainsnormal
A blue colour star appears on the control bar on the right bottom of the screen it says " You may be a victim of software counterfeiting " Can anyone help?
Jan 04, 2009 | Computers & Internet
Change time
Hey here is something you can use to adjust the time on your T7206.To Change the Time:
1. Press the CHANGE softkey Display will read: "Hour:
2. Press the CHANGE softkey Display will read: "Hour: _ "
3. Enter the new HOUR. (in 24-hour format - Ex.: 5:00pm = 17:00. Display will then read the new Hour programmed.
4. Press NEXT Display will read: "Minutes: # # "
5. Press the CHANGE softkey Display will read: "Minutes": _ "
6. Enter the new MINUTES.
To Change the Date:
1. Press NEXT Display will read: "Date DD MM YY"
2. Press the CHANGE softkey Display will read: "Year: # # "
3. Press the CHANGE softkey, (If the year is incorrect) Display will read: "Year: _ "
4. Enter the new YEAR Display will then read the new Year programmed.
5. Press NEXT Display will read: "Month: # # "
6. Press the CHANGE softkey, (If the month is incorrect) Display will read: "Month: _ "
7. Enter the new MONTH Display will then read the new Month programmed
8. Press NEXT Display will read: "Month: # # "
9. Press the CHANGE softkey, (If the day is incorrect) Display will read: "Day: _ "
10. Enter the new DAY Display will then read the new Day programmed
Let me know how that turns out and good luck
Oct 03, 2008 | NorStar T7208 Corded Phone
Panasonic KX-T7436 - time/clock
Hi Juliana, to set the time and date you leave the handset on-hook, Press program * * and the user password ( default 1 2 3 4 ), display shows USR - PGM NO?, dial 0 0 0, press next, enter 2 digit year ( to change current entry press clear ), press arrow pointing to the right, press select until month is displayed, enter month, press right arrow, enter day, press right arrow, press select until day of week is displayed, press store, press next, enter hour, press arrow, enter minutes, press arrow, press select for am or pm, press arrow, press select for 12 or 24 hour format, press store, press end. Let me know how it goes. ...Mike
Aug 13, 2008 | Panasonic KX T7436 Corded Phone KX-T7436
How to set time & date on phone
If you subscribe to Caller Display services, the first incoming call will set your phone's date and time automatically. Otherwise, here is how you do it.
1. press Options 2. Press * three times The display shows "Enter time/date?"
You may set both time and date or you may set either of them separately
TO SET BOTH 1. Press # when the display shows "*=Next #=Enter" 2. Wait for each prompt. You will be asked to enter: - the time - am or pm - SAVE - the month - the day, and  - SAVE (Enter the hour, day, and month as two-digit numbers. For example, enter 02:15 for 2:15, 05 for May and 08 for the 8th of the month.)
TO SET ONLY THE DATE 1. Press # when the display shows "*=Next #=Enter" 2. Press * when the time appears 3. Enter the month and day when prompted. 4. Press SAVE
I have a question for you: Can you give me the specs of the AC adapter for this phone (usually written on the adapter)? 1. What is the OUTPUT in volts (V)? 2. What is the OUTPUT in milliamperes (mA)?
3. What is the polarity (i.e. is the + sign in the center of the jack or on the exterior)?
(The wall plug transformer has a diagram depicting two circles with the inner circle representing the center conductor. A line coming from the inner circle will show a minus (-) or a plus(+) symbol to let you know the polarity of the center conductor.)
Thanks!
Mar 30, 2008 | Lands Phones
Cell Phones Logo
59 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
