Question about Samsung Televison & Video
Samsung TV restarts
When I switch on the TV (29 inch Samsung) it keeps switching on and off on its own for about five times. Then it stays switched on . If I switch off the TV and switch it on again within a short period the problem does not happen but if the TV has been switched off for some time even in standby mode, then it happens.
TV Model is Samsung CW 29M206
Thanks
Regards
David
5 Suggested Answers
SOURCE: TV keeps turning itself on and off, onto standby
I managed to find a local repair man who fixed the problem. He put in a new transformer.
Posted on Dec 05, 2008
  • 52 Answers
SOURCE: i have a wega 29 inch tv. it does not turn on no
Check the fuse in the plug has not blown.
Check that the power socket is working for other devices by trying them where the TV would normally plug in.
Posted on Jul 07, 2009
SOURCE: Samsung ps42q96hd switches off.
hi Shaun Mine started this morning. If you find a solution please let me know jrgiliomee@aol.com
Posted on Mar 20, 2010
gopakumarg43
  • 74666 Answers
SOURCE: my sony wega kv-32fq86b, some times it will switch
Hello
Standby light blinking is a fault indication in Sony sets. You just count the exact number of blinks at one time, after switching on and off the set by its front panel power control switch, NOT BY THE REMOTE CONTROL HANSET. Just inform me the exact number of blinks occur there, after counting it at least four times. It will help me to reach the faulty stage, of sometimes to the exact fault location also. OK.
Posted on Dec 20, 2010
My samsung 29 inch flat CRT TV fell down while transporting, after switching it on only yellow display is visible, it can be repaired...?
Someone who can open it is going to have to open it to see if the circuit board is cracked/damaged and if so how bad, some sets when this happens can be repaired and some cannot
Dec 14, 2012 | Samsung CW29M64NS 29" TV
Keep changing channel without any input
Most of the time it is the front contact switches Dirty clean them with contact cleaner or replace contact buttons on front panel board 29 cents each Call Mats 1-800-628-1118
Nov 19, 2009 | RCA F36673ET 36" TV
My 56 inch Samsung DLP keeps shutting off. I have
Once before I had this same problem and FixYa gave me the solution. When you replace the lamp door, there is a switch inside so be sure the door is put in at an angle so to hold the switch up. It solved my problem after numerous repairmen missed it.
Sep 02, 2009 | Samsung DLP HL-P5663W 56" TV
29 inc flat tv flickering
maybe your tv screen has a problem much better if you bring it to a tv technician.
Jul 30, 2009 | RCA TruFlat 27F520T 27" TV
No audio is coming at all in my philips 29 inch Hi-fy tv.
If you have a provider box it also has a volume control,manully turn your tv up and use your controller to turn the box up.
let me know
Jan 30, 2009 | Philips HI-296 Iron
KEEPS SWITCHING OFF AFTER ABOUT HALF HOUR OK WHEN YOU SWITCH BACK ON HAVE CHECKED TIMER THAT IS OFF
This may be an overheating problem.
Place a large floor fan so it will blow into the back of the tv.
If the tv stays on longer or stays on all the time after that.
If it is an over heating problem, then you may have transformer flyback that needs replacement.
Jun 12, 2008 | Samsung Televison & Video
Failure to switch on
fails to switch on again despite repeated attempts.
this is due to power supply failure.
please call skilled tech to fix it.
Oct 14, 2007 | Televison & Video
Televison & Video Logo
199 people viewed this question
Henry  Thomas
Henry Thomas
