Question about Canon imageCLASS D880 All-In-One Laser Printer
Canon D880 Printer/Fax
Copy paper is jammed inside the printer. I can't pull it out .
Where do I locate a "Take it apart manuel" to disassemble the unit so I can remove the paper jam.
Or
How do I take it apart "Step by Step"
  • dmarinos Nov 22, 2008
    Thanks for your help.
    I started to do it, WOW. What a job, finally called Canon repair, for $272 they did it and replace 6 bad paper rollers & a LARGE print roller.
    Problem:
    NEVER try to copy the other side of the paper by putting the copy you did thru you machine again upside down.
    It only jams the machine.
    Thanks again,
  • 42 Answers
1. Take off 3 plastic covers one above exit area-slide top to left to access screw
remove lower exit cover and side cover -unsnaps with 2 pins and there is one more cover I think over the fan that needs to come off.
2.Locate black plastic sheet covering a circuit board carefully pull this back-disconnect 3 plastic connectors that lead from the heater to the circuit board
3. using a offset phillips #2 screwdriver remove 3 screws that hold the fuser to the frame. carefully lift fuser up and out toward the exit area.
4. pop off black cover remove 2 screws from top of fuser, disengage cover lid locks with a small screwdriver, lift upper fuser heater-be careful NOT to damage
plastic heater membrane. remove paper jam and reassemble.
Posted on Nov 21, 2008
  • fixman72 Feb 14, 2011
    Yes, I see what has to be done. Thank you for the good instructions.
    Requires small hands and much experience. I can't do it.
How to reset error 5100
Jams in the Document Tray
When a document jams or misfeeds in the Document Tray, <OPEN COVER> and <SEE FIG. 1> <!!CHECK!! 5100> are displayed on the LCD.
Note
You do not need to unplug the fax when clearing document jams.
* When <OPEN COVER> and <SEE FIG. 1> are displayed alternatively
1. Press [Stop].
Important
Do not pull out the jammed paper manually at this point.
2. Hold down [Start/Copy] for a few seconds.
* The document will be fed out automatically.
* If the document is not fed out, gently pull the document out of the fax.
* When <!!CHECK!! 5100> is displayed
1. Check if any paper is jammed.
If jammed, make sure to take out all the jammed paper.
2. After taking out jammed paper, turn the fax off, then turn it back on with [ON/OFF].
Jams in the Multi-Purpose Tray
If paper jams in the Multi-Purpose Tray, <CLEAR PAPER JAM> is displayed on the LCD.
1. Gently pull any jammed paper out of the fax as shown, then press [Stop].
* Pull it gently in either direction.
* If you cannot pull the paper out, continue with the steps below.
2. Open the Printer Cover.
3. Gently remove the jammed paper inside the fax.
4. Press [Stop].
The fax returns to standby mode.
Sep 24, 2013 | Canon FAX-JX200
Paper is jammed
Only 2 things can be done. Switch it on or off repeatedly, the paper will automatically come out. Second, disassemble it and take out the papers.
Audi Headlights
Aug 27, 2012 | Canon PIXMA MG2120 Photo All-in-One Inkjet...
Took out all possible paper, but keeps saying there is a paper jam
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 12, 2010 | Canon imageCLASS D880 All-In-One Laser...
Paper jam in canon d880, Have tried every way to get paper out, but can't. Need to know what to do?
Make sure to blow off the optical device near the print head.
It may not have a paper jam at all.
Apr 07, 2010 | Canon imageCLASS D880 All-In-One Laser...
Paper jam in front roller of imageclass D880 (about 1/3 inside)
dirty pick up rollers. take the paper tray out and them you will see 2 half moon rollers, clean them with alcaho and you will be ok.
Oct 08, 2009 | Canon imageCLASS D880 All-In-One Laser...
Paper jam in canon Imageclass D861 copy machine
Where inside in fixing unit, drum unit,...
It is problem if its fixing unit jam.Best take it to service
Mar 30, 2009 | Canon imageCLASS D880 All-In-One Laser...
Paper jam that I cant get at
the paper must be jammed in the fixing assembly.
you are gonna have to remove some screws to remove the plastic covers. once you took them off proceed to unscrew what ever needed in order to free the fixing assembly, which is the one located in the upper back part of your copier. once you released the fixing assembly release the springs and remove the metal stoppers. now you should be able to remove the paper jam. good luck!
Jan 27, 2009 | Canon ImageClass D880 Copier
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
Cannot fax
Clean the big rubber roller in the document feeder with a microfiber cloth moistened with windex or alcohol then retry fax
Dec 31, 2007 | Canon imageCLASS D880 All-In-One Laser...
Canon imageCLASS D880 All-In-One Laser Printer Logo
1,247 people viewed this question
old marine
old marine
