Question about ASUS P4P800 SE (890552603657) Motherboard
Motherboards and graphics
When i take out a motherboard out of one pc and put it into another the grapics dont seem to work but everything else seems to be working ok and i dont hear any peeps i think it has some thing to do with the ram but i am not sure
    Novelist:
  • 137 Answers
I'm not sure about the RAM thing and I'm guessing that you are using the on-board video because you didn't specify and didn't mention a video card. I'd make sure that the power supply provides proper voltage and amperage for the system, or reduce the number of devices pulling on the power supply. You can reseat the ram but if it was working in the other computer, it should work on the new one because RAM is dependent on the motherboard, not the computer. That is assuming that you are using the same RAM as was in the initial computer. I don't have a lot of other ideas without having more specifics about what the setup is and what you've done so far. good luck
Posted on Nov 15, 2008
How i intall my Graphic driver for windows 7 because i do not have the driver for windows 7 in my mother board cd.
Hi
It doesn't seem that there are Windows 7 drivers for your motherboard (I'm assuming you're talking about your onboard graphics) - See here.
The best option you have is trying to install the VGA drivers for Windows 2000/XP and hope that works. Otherwise you're going to have to revert to Windows XP for your grapics to function correctly.
Another option you have is installing a 3dcard on the motherboard. Click here for a complete list of graphics cards supported.
Good Luck,
-LL
Feb 26, 2010 | Asrock P4I45GV R5 Motherboard
I want to add a grapic card to my motherboard..
you will need an AGP type graphics card for this motherboard, not a PCI-E....hope this helps
Feb 08, 2010 | Gigabyte GA-7VKMP Motherboard
I dont have any picher in the screen
If the graphics are on the board and dosnt seem to be working take it to your local Pc store and ask them to test it with a expansion slot grahics card, the onboard graphics may have been disabled in the bios.
Jan 22, 2010 | Asrock P4i65GV Motherboard
I have a asus striker extreme motherboard, quad core Q6600 processor, 8800 gtx graphics card, my pc was running fine suddenly it just hanged ,this has happened a few time before but after a while it starts...
Sounds like you need to go into the Bios if you know how and adjust the thermal values in there. I suggest checking heatsink on cpu is seated correctly and add a fan to increase airflow in side the case. Seems like a heat problem from what you describe.
Dec 14, 2009 | ASUS Striker Extreme Motherboard
To install graphic
the grapic shouldnt be supported to motherboard
Sep 15, 2009 | Intel 845GE Motherboard
I can't get a video signal to the monitor. Have a new graphics card.....no signal????
1/ first change motherbord on your desktop.if it is work (your old bord is damage ).then keep graphic card/ vj card on old mother bord slaut. if not work . it is seriously problem.mainly in pinless bord we can"t repair it. change or took it on export
Jul 10, 2009 | Intel DX48BT2 Motherboard - X48, Socket...
Dont
You probably need to install the drivers for your sound and graphics again. Try that and if it doen't work let us know.
May 02, 2009 | MSI KM2M Combo-L (MS-6738-010) Motherboard
No graphics on monitor whatsoever, screen completley blank
i think there is a problem with your system's hardware.. check whether your MOBO or your processor.. computers that doesn't startup and has no beep has defective or burned CPU or motherboard
Apr 18, 2009 | Foxconn 661FXME Motherboard
MSI pm8m-v on board grapic
Onboard graphic will be disabled automatically if there is a graphic card in AGP slot.
Mar 19, 2009 | MSI PM8M-V Motherboard
Motherboard problem
Hiw can u say's its display problem,Have u checked the signals on k/b ?
If not check the Num lock status in keyboard. Press the Num lock key ,if the light glows and stands for sometime display is ok,but ur vga adapter is the problem.
Otherwise problem maybe with m/b or psu.
Pl check it.
Regards.
Was this soultion useful?give the apppriciation by rating it.
Apr 04, 2008 | ASUS P5K-V - Motherboard - ATX - iG33 -...
ASUS P4P800 SE (890552603657) Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
