Question about Panasonic NV-GS50 Mini DV Digital Camcorder
IMovie not recognizing Mini DV Panasonic GS50 camcorder
I've got a Macbook with OSX and iMovie (or the Mac in general for that matter) will not recognize the camcorder at all when plugged in....just nothing.   Is there a software update I would need somewhere? Any thoughts would be great!Thx,shawn
4 Suggested Answers
SOURCE: I need a driver for Panansonic NV-GS50 Mini DV
Here is a link.
http://panasonic.jp/support/global/cs/e_cam/download/downdvc_usb.html
Posted on Feb 14, 2010
  • 14 Answers
SOURCE: I have a mac osx version 10.4.11 and when I plug
This tool you need is iMovie Video Converter.
Free guide:
http://ilifesoft.com/how-to/import-video-to-imovie.htm
Posted on Aug 03, 2010
Omn1cide
  • 8 Answers
SOURCE: Hello, could you advice where I
Panasonic usually includes the Mac software program "Imagemixer 3" that imports the videos/photos you have on your camera. If the software isn't included with your camera, try Googling around for the program and it should come right up! I hope this helps. - Omn1cide
Posted on Mar 05, 2011
SOURCE: reset switch of Panasonic NV-GS50 Mini DV Digital Camcorder
the sound of my sony camrecorder is gone, when i record there is no sound. so please help me fix the problem!
Posted on Nov 21, 2011
Macbook pro doesnt recognize the panosonic pv-gs9 when connected with firewire
I take it that your macbook pro has imovie on it. If you open up imovie and plug in your camcorder it should recognise the camcorder and give you access to putting the movie onto your mac. Have a look at http://www.apple.com/support/imovie/ it should help.
Mar 03, 2012 | Panasonic Palmcorder PV-GS9 Mini DV...
Hello, could you advice where I could purchase Panasonic NV-GS150 DV Camera MAC OSX 10.5 Support? I cannot connect my Panasonic NV-GS150 DV camera with my MacBook Pro. Thanks a lot for your help!...
Mar 05, 2011 | Panasonic NV-GS150 Mini DV Digital...
Can not copy MiniDv to Mac 10.6.2
usb is not compatible with mac os. so, use a firewire/i.link cable to transfer the videos to the mac computer
Mar 16, 2010 | Sony Handycam DCR-PC9E Mini DV Digital...
Panasonic pv gs 180 can't import into imovie
Hi, I managed to down load mine by connecting with a firewire and setting the camera to playback mode (not PC), opening imovie, turning the camcorder on and selecting file -' import from camera". a screen came up then I started playback on the camcorder and was able to select import from the screen on the imac.
Sep 28, 2009 | Panasonic PV-GS180 Mini DV Digital...
Macbook not recognizing camcorder
I had this problem when first plugging in my Canon zr80 to my Mac. What I did first was (if you have it) open up the program Imovie in you're applications menu. Then plug the firewire cable into both the camera and computer. Turn the camcorder on and set it to play(VCR). Once this happens you should see a "DV in" on the camcorders screen, followed by a blue window on you're computer. The rest should be easy.
Jul 01, 2009 | Canon ZR800 Mini DV Digital Camcorder
DCR-PC330E to MacBook Pro
unfortunatley all sony products only work on pc your best bet would be to transfere to dvd and import that way
May 27, 2009 | Sony Handycam DCR-PC330E Mini DV Digital...
Transfer to MacBook Pro from digital video camera
when you connect the camera to your mac via firewire, make sure you have an application open that will allow you to import the material.    The most common application being 'imovie'.
Dec 15, 2007 | Panasonic Palmcorder PV-GS12 Mini DV...
Panasonic GS150 Camcorder- MAC not recognizing camera
Make sure you're using the right connectors -- the DV port on the inside of where the LCD screen opens up.
Mar 19, 2007 | Panasonic PV-GS150 Mini DV Digital...
Panasonic NV-GS50 Mini DV Digital Camcorder Logo
51 people viewed this question
Top Panasonic Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
