Please help. I'm out of work and can't afford another bill
Can I reset this?
SOURCE: GE Profile Harmony dryer error message
PCB is probably the printed circuit board. you'll need the model# off the dryer (not from the manual), then go to GE's website to get an idea of the cost ($150-200). It's located under the control panel of the dryer. GE calls it 'PWR/PCB ASM-MAIN'.
Is the dryer still under warranty?
SOURCE: GE profile Harmony electric dryer
not sure of a reset button there maybe a fuse on the controller board What is the problem you are having??
SOURCE: ge profile harmony electric dryer doesn't always heat.
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
SOURCE: I have a GE profile harmony gas dryer that says
If there were no problems before replacing drum I would go back and make sure all 3 wiring connections are made behind the door panel. From there this machine is too complex to diagnose over the phone.
