Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Printer says printhead not in right after turning off. i
I have taken out and clicked back in several times still not working. please help
  • baybe213 Nov 28, 2008
    ok so I have the same problem just bought the printer and installing it. I am at the Calibrate Printer. Put the Paper in and got error on the display and it says...Printhead missing, not installed correctly or has come loose. Already took everything out and put back in and still get the same error.
    Scholar:
  • 162 Answers
To resolve the error condition:
  1. Open the printer access door.
  2. Remove the color and black ink cartridges.
  3. Remove, then reinstall the printhead.
Follow the link:
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/printhead/AUR1780-9_UE_RevC.pdf
Posted on Nov 23, 2008
Get error oxc 18a0001, when I turn on Hp Photosmat c5180 all in o
THAT 0X ERROR IS AN INK SYTEM FAILURE IT MAY HAVE BEEN CAUSED FROM THE REFURBED CARTRIDGES... THE HP WILL WORK WITH THE REFURBS FOR A FEW TIMES BEFORE REJECTING THE CARTRIDGE OR CAUSING AN 0x ERROR. THE UNIT NEEDS TO GO THRU AN ELABORATE INK SYSTEM RESET. OR HAVE THE PRINTER REPLACED
Mar 29, 2010 | HP Photosmart C5180 All-In-One InkJet...
Black ink noggle not working
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Feb 23, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Every time I change the ink cartridges, the computer had "E" in the box next to quantity. I have taken them out several times, but don't know what to do. Please help! I cleaned to print head, and put it...
in this case you need a new printhead for your ESP 3. You can order one when you go on www.kodak.com/go/itg. Then follow the step by step solution for image quality and at the end you can enter your adresse and get a new printhead.
Feb 22, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
My printer is saying it has ink system failure. How can I fix it?
Hi
Thanks for using FixYa. First disconnect the USB cable from the back of the printer without turning it off. Now remove the cartridges. Wait till the ' Insert Cartridges ' message is displayed on the control panel. Disconnect the power cord from the back of the product. Wait for a minute and then reconnect the power cord. Press the power button if it does not automatically turn on. Replace the cartridges and close the door. On receiving any command to print a test page let it do so. Now reconnect the USB cable to the rear of the product, and then try printing again.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 24, 2009 | HP Photosmart C5180 All-In-One InkJet...
My black ink does not work. I have put 2 new
please clean the heads of your black cartridge also the scanner or sensor for cartridges this can cause to black cartridge not to print.
Aug 19, 2009 | HP Photosmart C6180 All-In-One InkJet...
Not prinitng
Try placing sheet of black text on copy board, and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK
This worked on my C6180. Good Luck
Apr 29, 2009 | HP Photosmart 3110 All-In-One InkJet...
Hp 3310 all in one
black printhead must be replaced
Oct 09, 2008 | HP Photosmart 3310 Printer
HP PHOTOSMART C5180
Please tell me what you have done so far to the printer?
Sep 07, 2008 | HP Photosmart C5180 All-In-One InkJet...
C5180 printer won't print.
I just had this problem and here's what I did (with a little help from a previous yahoo answers post)...
1. Turn printer and computer off
2. Disconnect printer from computer
3. Unplug printer completely
4. Hold power button on printer while plugging printer back into power source. Maintain holding power button in until printer cycles completely (Ihave no idea if hold it actually does anything...but I tried it and it worked)
5. Turn printer back off (which actually may happen anyway when you finally release the power button)
6. Reconnect printer back to power source and computer.
7. Power both back up.
That should do it hopefully. Also make sure your printer cartridges aren't totally out. It won't let you print if even one of them is completely empty.
Good luck.
Aug 24, 2008 | HP Photosmart C5180 All-In-One InkJet...
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
22 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
