Mge nova avr 1250 problem
First, sorry for my english.
My MGE nova 1250 it's old 5 day (purchase before 5 day's) and is charged (recharging) 24h. After charging I'm connect critical devices (computer + monitor 19") and telephone line , usb ... When is WIN XP run firs time after connection UPS, batery level was 30%??!?!?, and begining charging 7-8 h by 100% (Power pac software +power management Win).But when I shut down XP and disconnect UPS (powewr switch) and de-energize UPS and comp.(through surge protector, I'm not remove power cord). Upon this again power on surge protector, UPS ,XP run again and anon batery level is 30% and anon charging couple hours by 100%.
Again Shut down comp +UPS , run again same thing , HELP.
When UPS connect to power souce all 3 led is on + continuous beep 10 sec.
  • 3 Answers
Try to discharge the UPS (let it run on a load untill it goes off) and then connect it to the mains again,for the batteryes to recharge.
Posted on Jan 17, 2011
All is fine. Your UPS doesn't measure battery voltage, so 30% is just an estimation. The battery charging is controlled not by UPS microprocessor, but by some analog circuits that doesn't report to any digital interface - so, UPS is unaware of it's charged level.
The only measure point of battery voltage is yes-or-no trigger of "low battery" - when is fires, UPS will change it's beep sequences.
Posted on Feb 20, 2010
  • smaximenko Feb 20, 2010
My MGE nova 1250 when the ups is completely charged 100%, disconnect then rerun the ups it shows battery level of 30%.please help chahine_waseem@hotmail.com
Posted on Jan 08, 2010
Ups charged for 8 hrs .No alarms but on powerfail no output to connected device
Posted on Jun 20, 2009
Self test error
Is the UPS in Bypass? Is the Inverter running? What alarms other than that code are on? Have you shut the unit down. Its best to call MGE, that unit requires to have software to work on it. Even though you find the problem, and replace the board, the Board needs to be program to that unit. YUP! This way MGE always makes money on the UPS's no matter where and no matter how old the UPS is. They lock you out. Which is unfair for the customer. The customer has no choice but to call the dealer to fix it. Trust me.. Then again when a customer buys a product, isn't it his for life? Why can't he fix his ups or hire whoever he wants besides the Manufacture? Wrong, NOT WITH MGE Products. I guess it's Job Security for MGE. That one positive thing.
Jan 23, 2014 | MGE Galaxy 3000 UPS System
Mge nova avr 500 repair manual
there is nothing called repair manual, service manual might be available (I dough it)
Dec 17, 2013 | MGE Computers & Internet
The Alarm Indicator and Battery indicator is red for a faction of a second and the PC is turned off. Is the battery problem?
Hi Roger,
Yes, that seems to be the issue. The power to your UPS is interrupted and when it tries to switch to battery it dies instantly because the battery is dead.
Call me if you would like affordable battery pricing, or if you would like more assistance -- 407.380.9200.
Oct 30, 2013 | MGE NOVA AVR 1100VA Tower UPS 81111 UPS...
I get an alarm with continuos beep sound everytime I plug in the unit, even without load
Time to change the batteries. Open the UPS and get the battery type numbers and spec written on the batteries. Locate a local battery distributor and you can order batteries. APC uses industry batteries.
The batteries last an average of 2 to 3 years. They wear out inside. You can also order APC original batteries if you feel insecure about purchasing them from a battery dealer. APC will charge more for the batteries, but they will be original to the UPS type.
Jerry G.
Jun 25, 2012 | MGE NOVA AVR 1100VA Tower UPS 81111 UPS...
MGE Galaxy 3000 UPS, do i require to reconfigure the ups after battery replacement? Thanks.
No you don't have to reconfigure the UPS after battery replacement. However you may have to reset the battery Timer. There are 4 possible ways.
1. Press and hold the fault reset button for 3-5 seconds
2. Press and hold the fault reset and security key simultaneously for 3-5 seconds
3. Press an dhold the fault and alarm silence buttons simultaneously for 3-5 seconds
4. Cycle the logic Power. This means to remove power from the main processor.
5. Call MGE. They have the software to reset the battery replacement alarm
Oct 19, 2011 | MGE Galaxy 3000 UPS System
Hello my UPS MGE 850 evolution is just blinking a red alert and does not charge even when conected to the power suply.. What could be the problem??
Battery has drained and gone.
Get new battery here http://www.battery-direct.com/ups/MGE-Evolution-MGE-EV850R.html
Please rate if this solved your problem.
Apr 19, 2011 | MGE Evolution 850 (68453) UPS System
Please can you tel me whitch Kind of battery, and how many battery there is in this model : MGE PULSAR EXTREME 1500C RACK and MGE PULSAR EXTREME EXB 1500C RACK
Specifications for MGE Pulsar Extreme 1500 C 2U Rack Battery kit
Voltage 12V (Per Cell) Capacity 6Ah (24W) Weight 8Kg Dimensions 151mm x 94mm x 51mm (Per Cell) Lifespan 3 - 5 years Type Sealed Lead acid battery rechargeable highly efficient, leak proof and maintenance free
I think there are four batteries in the pack.
Feb 16, 2011 | MGE UPS Pulsar EXtreme 1500 C UPS System
UPS not charging
Sir, Our UPS is not charging at all. After following the procedure for shuting and starting up, it show battery charging 0%. The model is MGE Galaxy 3000 UPS and also cooling fan is going to falt mode .with best regards
Jul 02, 2008 | MGE Galaxy 3000 UPS System
Computers & Internet Logo
1,041 people viewed this question
David Payne
David Payne
