Question about Samsung RS2578BB Side by Side Refrigerator
Problem in Samsung rs 2555sl Side by Side Refrigerator Troubleshooting Foru
If the defrost timer, defrost heat element or defrost t-stat isn't working then you will not have a defrost cycle.so where do i find the defost timer or deforst t-stat .how it look like.i did remove all around the frige and frezer.the back. on top but didn't see any .the defrost timer i know it. but i didn't see what ever i can open i did all but didn't see or may be my refrigeration SAMSUNGRS2555SL is different with these other.because my refrigeration SAMSUNG RS2555SL on the display at the front is digital (i open the frontjust see only the board and the all the chip) thank you
  • 237 Answers
Look at the link attached, the defrost t-stat is #38 (thermo bimetal). Clips to the coil, looks like a round device with wires on it. Defrost t-stat is normally closed to allow power to the heat element and opens when hot enough to stop the defrost cycle. Heat element #43 should not test "open" with a multi meter, there should be some Ohm value there to show it's good. The defrost timer could be a clock type or circuit board type, page through the links diagrams and you should be able to see where it is physically located in your particular unit. http://www.partselect.com/ModelFrames.aspx?ModelID=575085&ModelNum=RS2555SL&mfgModelNum=RS2555SL&ManufactureID=1&Selected=SS50-1&Position=2&mfg=Maytag&Type=&Mark=2
Posted on Nov 24, 2006
Whirlpool Gold Refrigerator. GB22DKXJW01. Problem: Not defrosting. Initially showed defrost coil with open. Turns out that my fluke is dying/died. Coil is fine. Have a brand new one also...will try...
most likely it will be the defrost thermostat,you also have a timer down at the bottom right side i think where the condenser coil is.that also can be bad.it would be a good idea to change out the t-stat anyway so if your meter isn't working you can unplug the machine,cut the two wires going to the t-stat,wire them together,turn your timer to defrost with a regular screw driver,stick the driver blade into the middle of timer or you can turn this one by hand,turn it until the timer clicks and the evap fan motor stops,if the heater comes on you have a bad t-stat.call your local parts store,give them the model number and they will give you the part number.
Aug 09, 2013 | Whirlpool Gold White-on-White 21.9 cu. ft....
Coil in freezer icing up and auto defrost not working.the heat strip at bottom of coil is not going on and ice build up on coil cuts cold air supply to refigerated side of refrigerator.is there a sensor...
Your fridge is probably suffering from a defrost circuit failure. One (or possibly more) of the following components has failed: 1) the defrost terminator or sensor, 2) the defrost heating element or 3) the defrost controller / timer. Items 1 & 2 should be found in the freezer compartment - behind the back wall. The 3rd item can often be found in the toe space at the bottom of the fridge - behind a kick plate or some other relatively accessible location.
The operation is as follows: The defrost timer runs constantly and about every 8 hours or so, it switches the power from the compressor and its associated controls (fresh food compartment t-stat, etc.) to the defrost circuit that consists of a heating element and a device called a defrost terminator. Power is applied for about 15 to 20 minutes during which time the defrost heater is energized IF the defrost terminator detects the evaporator coil compartment temperature is cold. When the defrost terminator detects that the heater has warmed the evaporator coil compartment to a temperature of about 50 degrees OR the timer has powered the defrost circuit for 15 to 20 minutes, the defrost circuit / heater de-enrgizes. Even if the heater is hasn't reached 50 degrees in the 15 -20 minutes, the timer switches from the defrost circuit back to the compressor through its controls once again. You'll need to determine if 1) the timer is timing, 2) the timer switch can actually send power to the defrost circuit, 3) the defrost terminator can close when cold - or if it is stuck open, or 4) the heater works.
If you don't know how to work with electrical meters and tools or are not comfortable working in tight spaces (back wall of the freezer) with live electric parts, you should call a repair person. Also, refrigerants are very dangerous. If allowed to escape from the tubing, coils, etc. there is a very real danger of instant frostbite if it comes in contact with your skin. You can be blinded if it contacts your eyes. These above reasons make me believe that this is a pretty complicated DIY type job and really isn't a good one for a beginner to attempt. On the plus side, parts are relatively inexpensive, and a qualified person should be able to quickly diagnose the problem. Labor rates and standard parts markup can bring this repair up into $200 and up range, however.
If / when you do call for service, having the freezer emptied & defrosted already - will save the cost of defrosting time by the repair person.
I hope this was helpful and good luck. Please rate my reply. Thank you.
Apr 08, 2011 | Amana ARS266ZB Side by Side Refrigerator
Frig Freezing Up/Frig side warming up Maytag MSD2454GRW
I think your voltage is fine I just believe the defrost timer is worn out and not cycling properly resulting in less defrost and higher refrigerator temperatures. Thanks, sea Breeze
Aug 26, 2009 | Maytag MSD2454G Side by Side Refrigerator
Freezer and refrigerator top part does not cool, only bottom.
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 22, 2009 | Jenn-Air JCD2290HES Side by Side...
The refrigerator side has stopped cooling.
, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
Aug 18, 2009 | Refrigerators
Refrigerator and freezer not working
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
Aug 15, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Kenmore model 57029 side-by-side refrigerator not working
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
Aug 12, 2009 | Kenmore 57029 Side by Side Refrigerator
My Samsung side by side fridge is not cooling properly. The freezer is fine but the refrigerator does not cool enough. I cleaned it recentley but just wiped it down - nothing odd
Aug 11, 2009 | Refrigerators
Samsung fridge rs52530bwp the fridge side will not work
I have a similar situation before in your case if your heating element is working then you are lucky I had a samsung fridge and the defrost heating element was bad and i was forced to install a different one because i would have to change the hole evaporator in order to replace the heating element so what dit was to use a mechanical 10 hour defrost timer and install a generic heating element and a defrost thermostat on serial so it want work on less the evaporator has froze over i drill a hole to the back of the fridge and i wren the cables to the back of the fridge cover then whit foil tape an take power directly from the power cord i install the timer next to the control board so every 10 hours will give power to the heating element but will not come on unless the evaporator has froze up. on my case i had to do it like that because the heating element i use was to strong for the control board and would just burn it up. but will work even better using the original heating element. NOTE: find the diagram of a old fridge that will help you to figure out how to install the timer and the defrost thermostat no need for the timer to cut off the compressor keep in mind than the defrost thermostat only close the circuit when is chill below freezing so i recommend to use a new one I hope this help you
Jun 10, 2009 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2578BB Side by Side Refrigerator Logo
548 people viewed this question
Top Samsung Refrigerators Experts
Paul
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
