Question about Ruud UBHC Air Conditioner
Frost on my heat pump
I've never had a heat pump before and I am wondering is there supposed to be so much frost on the "fins"? It has been heating for a couple months with our outside temps running in the 20 to 40 dogree range. House is set at 65. I just worried if it builds up too much it will fry the pump. Any info. wouuld be helpful. Thanks.
  • 96 Answers
All you are seeing is the moisture in the air outside starting to freeze on the fins there is no worries the system has a cycle time built in to check for freezing and will defrost itself if it does not thaw out it has a bad sensor or board
Posted on Nov 16, 2008
When the heat pump is running in the fall, I notice frost build up the next morning. What cold cause this problem?
Heat Pumps and Refrigerators are the same unit running backwards. To get refrigeration you create heat, to get heat, you create frost. The end blower is the thing that either gives you heat or cold air depending on what setting you are choosing.
To stop the frost building up, you just need to cover that area with insulation. The frost is caused by a cold surface that is below freezing point and water vapour in the ambient air.
Nov 19, 2016 | Frost Refrigerators
Why water is leaking in freezer where cooling fins are
The defroster coil melts the frost build-up on the coils and the water hits the aluminum plate that guards the plastic drain from he heat of the defrost element, but the drain freezes over because the air temperature and the metal heat shield are still cold enough to freeze the drain. You can cut away a small portion of the metal pan liner and expose the drain to the heater coil while defrosting. I also wrapped a piece of copper 14 guage wire around the heating coil and routed it down the drain to heat it while in defrost. No problems after this fix.
May 31, 2014 | Whirlpool GB2FHDXWD Refrigerators
Ambiance 16 seer unit frozen
This sounds like a heat pump. If so, it sounds that the unit is not staying in the defrost mode. Heat pumps have a temp sensor so when the outdoor unit goes into a defrost mode, this temp sensor takes it out of the defrost mode when the temp reaches a set point to ensure there is no more frost. Usually about 51 degrees as a general rule. I would start there.
Jul 25, 2017 | Ambiance Designs Heating & Cooling
My thermostats call for heat but the heat goes off and on.circulator pumps work pilot light stays on.heat will stay on for awhile but cuts off.
Here is a tip that I wrote about heating circulator pump problems.
It will give you the information you need to learn about your circulator pump problems and solutions for it.
Heating Circulating Water Pump Problems
Dec 17, 2010 | Slant Fin Slant/Fin 2 Gallon Humidifier
Outside fins frosting over, in teens
Due to ambient temp on -. Check when you keep heat mode in your a/c the outside fan won't run unless the pressure build up. First, you defrost by heating torch or pouring hot water on your condenser. And also clean your condenser coil.
Dec 16, 2010 | Heating & Cooling
I just moved into this home and am wondering what EM heat is compared to just Heat and my outside unit is full of frost what do I need to do?
Hi, EM stands for emergency heat. You should only need to use it if the outdoor unit does not operate. You have what we call a heat-pump. If the outdoor coil is iced up, it should go into a defrost cycle to melt away the ice. You will know when it does as you will see steam coming up from the unit as though it is on fire. The outdoor fan will also shut down during this process. These units will defrost using time and temperature to defrost the coil. If the ice continues to build-up, and does not defrost every couple of hours, I would say you have a faulty defrost board or defrost thermostat. There is not alot you can do as these are very complicated systems to work on. You will more then likely have to call out a service tech to check this outdoor unit for you.It also should have heat strips in the outdoor unit for EM heat if the outdoor unit fails. If it is iced up it is on and running. Thats what I would do is keep an eye on it to see if it does defrost, and if not, you will need to get a tech out to check it. It takes special equipment to check these units. Please keep me posted.
Feb 01, 2010 | Honeywell Programmable Thermostat Heater
The frost should be uniform on the coils. Uneven frost pattern is a sign of low freon. Most systems are sealed but a qualified tech can recharge the system after finding the leak and cap it off.
Jul 01, 2009 | Amana 22.6 cu. ft. Side-By-Side...
LG Bottom Freezer Frost Issue
It sounds like your defrost controller has gone bad. I have an LFC25760 and had ice build up in the bottom of the freezer such that water would start leaking onto the floor. The ice build up in the bottom of the freezer was due to a failing/bad defrost controller. Behind the back white wall in the freezer compartment exists the cooling fins along with a heating element underneath. Due to moisture that comes into the freezer from opening it, frost/ice builds up on the cooling fins. Thus the defrost controller turns on the heating element to melt the ice/frost off of the fins which then drips into a metal pan which channels the water to a drain hole which drops into the drip pan underneath the fridge next to the fan. The problem is that the defrost controller doesn't keep the heating element on long enough or the cooling cycle comes on too soon thereby freezing the water and plugging up the drain. I had my defrost controller replaced (just outside the warranty period!) and it worked for about 1-month and then same thing happened again. Instead of paying for another defrost controller that would probably not work 100% my serviceman used the old paper-clip trick. He took a paper clip, stretched it out and then wrapped one end around the heating element and placed the other end into the drain hole. Thus when the heating element comes on the paper clip keeps the drain hole warm/hot and prevents the water from freezing. It has been 9 months since this fix and I haven't had any ice pooling in bottom of the freezer.
Jun 22, 2009 | LG LRFD25850 French Door Refrigerator
No water in bucket
possible that the cooling fins have frosted over...this happens when a cold surface appears in a humid room that does not have enough heat to prevent the freeze-up on the fins. If you look at the fins (above the water bucket), you may see the frost. One solution is to turn up heat in room, followed by placing a fan to blow air through fins if still frosted. If you do not have a frost problem, then ensure compressor is running. If comp is running, then return dead unit.
Feb 16, 2008 | Kenmore 53301 Dehumidifier
Ruud UBHC Air Conditioner Logo
212 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
