I have an ipod problem
I have a classic ipod it has a sad icon and every time i open it shows that icon and close immediately and the ipod doesn't show on itunes it is a hardware and a battrey problem what can i do
  • 470 Answers
If you're having trouble with your iPod, try these steps (known around here as the five Rs) one at a time until the issue is resolved. These steps will often whip your iPod back into shape.
  1. Retry your iPod with a different USB or FireWire port on your computer (please note that the latest iPods can only be synced through USB).
  2. Reset your iPod. To reset an iPod, iPod nano, or iPod mini, press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step. To reset an iPod shuffle, disconnect iPod shuffle from the computer (if connected), and then move the switch on the back of iPod shuffle to the off position. Wait 5 seconds, and then move the switch on the back to the play in order or the shuffle position.
  3. Restart your computer, and make sure that you have the latest software updates installed.
  4. Reinstall your iTunes software and make sure you have downloaded the latest version. Check your iPod software by connecting your iPod to your computer, and then in iTunes, select your iPod in the Source pane. Click the Summary tab, and the Version section tells you whether iPod is up to date or needs a newer version of the software. Click Update to install the latest version of the software.
  5. Restore your iPod by connecting your iPod to your computer, and then in iTunes, select your iPod in the Source pane. Click the Summary tab, and click Restore to restore iPod to its original settings. Follow the onscreen instructions to complete the restore process. (Important: Please note that restoring an iPod will erase all songs and files on your iPod and restore it back to its original settings. Make a backup of any files on your iPod before restoring it. After restoring, you can transfer your music and files from your computer back to your iPod again.)
Note: Because Restore erases all of the songs and files on iPod, make sure to back up any files you've saved on the iPod disk. All of your songs, videos, podcasts, audiobooks, and games can be loaded back to your iPod provided that you have them stored in your iTunes Library.
How to restore your iPod:
For Windows:
1. Make sure you've reinstalled the latest version of iTunes.
2. Open iTunes, and then connect your iPod to your computer.
3. After a few moments, it will appear in the source list in iTunes. If the iPod's display doesn't show "Connected" or "Do not disconnect" you may need to put the iPod into disk mode to proceed.
4. Select your iPod in the source list and you will see information about it appear in the Summary tab of the main iTunes windows.
5. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software.
The 4 possible restore options are:
Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
Restore Option 3: Use Newest Version - Restores with the latest iPod Software on your computer.
Restore Option 4: Restore and Update - Restores with the latest iPod Software on your computer.
6. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
7. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
8. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
For Mac:
5. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software. The 4 possible restore options are:
Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod, even though a newer version is available.
Restore Option 3: Use Newest Version - Restores with latest iPod Software version on your computer.
Restore Option 4: Restore and Update - Restores with latest iPod Software version on your computer.
6. A message will appear prompting you to enter an administrator's name and password.
7. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
8. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
9. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Or
Try to reinstall
To update and reinstall your iPod software, first download the latest version of iTunes.
http://www.apple.com/itunes/download/
Next, open the new version of iTunes and connect your iPod to your computer.
Select your iPod in the source list and click "Check for Update" under the Summary tab. iTunes will check to see if your iPod needs to be updated and perform the update for you.
http://support.apple.com/kb/TS1382?viewlocale=en_US
http://support.apple.com/kb/HT1320?viewlocale=en_US
It is effective!!!
Regards,
JAN_yuanjia
DON'T FORGET TO RATE
Posted on Nov 15, 2008
30 gb ipod has sad face and low battery icons
could be bad charger or time to replace the battery. lots of places sell new ipod batteries.
does it work if you leave it plugged into your computer for a few hours? if it does not then its a bad abttery.
Sep 23, 2009 | Apple iPod MA446LL/A MP3 Player
IPOD Classic 80G apple icon then red x icon or restore in itunes
I know you tried to fix it, but trying multiple times may work.
The message "go to www.apple.com/support/ipod" usually is preceded by, or followed by, the Apple logo or the sad face icon. It directs you to the Apple support site because either the iPod software is corrupted or their is a hardware problem. You should try to reset the iPod (try several times). If that doesn't right the iPod, then try to restore it (which will erase the entire iPod and reload the software.
Follow the links above and see if that gets your iPod working. You might want to see if you can update the iPod/iTunes software or try this troubleshooting guide. If it is really a hardware problem then your iPod needs to be taken in for service.
Mar 29, 2008 | Apple iPod MA446LL/A MP3 Player
Tip
How to resolve Sad face icon issue for click wheel iPod's
If you are seeing a sad face Icon on your click wheel iPod, you may be able to resolve the issue by following the instructions below.
What you will need:
iPod
USB cable
USB power apple iPod compatible wall adapter
The latest version of iTunes installed on your computer
The process remains the same for Mac and PC
First you will need to force your iPod into disk mode. To do this you will need to reset the iPod by pressing and holding both the menu and center buttons. Continue to do this for at least ten seconds or until the apple icon appears. (Note: You may only see a blip on the screen, continue to the next step. Keep in mind though that you may need to repeat this process once to twice to force the iPod out of the sad face status.)
As soon as you do see the apple icon, remove your fingers and switch to holding both the play and center buttons. Keep holding those until you see a check mark appear on the screen, below it will say Ok to disconnect. At this point your iPod will be in Disk mode.
Next open ITunes on your computer and plug in the USB cable to one of the ports on your computer. Now you will connect your iPod to the USB cable. In the left hand column of iTunes you will see your iPod icon; go ahead and click on that icon. In the resulting page you will see the iPod summary. Within this page you will see a Restore button. Click on that button and follow any on screen instructions. Allow the restore to complete fully. When it has you will see that the screen of your iPod will have changed. It will now be displaying a picture of a power adapter being plugged into a standard wall outlet.
Disconnect the iPod from the USB cable and connect it to the wall adapter. You almost instantly notice the screen will show a status bar that is showing that it is actually being restored to factory settings. Once that has finished the screen will light up and work as it did before the sad face icon incident.
Just as a note: If you have dropped your iPod many times, submerged it in water, or any other extreme damage has occurred; this may not work for you.
Mini Tip:
If it has been submerged in water though, you can place the iPod in a full bowl of dry rice. Completely cover and leave for at least 24 hours. I personally recommend 48 hours for best results. It is not a guaranteed resolution, but has worked for me in the past.
on Feb 03, 2010 | Audio Players & Recorders
Flashing icons while charging... am I really charging?
If the iPod is showing the "Sad iPod face" icon, this means that the hard drive inside the iPod (located on the logic/circuit board) has died/failed and needs to be replaced. If you plan on replacing this part, you may also need to purchase and solder a new battery to the iPod logic board if you were to do it yourself.
May 26, 2009 | Apple iPod nano
Ipod only works wih a power source
Well there is a remote chance it's a battery issue, but most likely you have a broken logic board. If you're not covered under the warranty you can try to open it and make sure the battery is connected properly. There are iPod repair guide websites, that show how to open the iPod classic and replace components.
May 10, 2009 | Apple iPod classic MP3 Player
The sad ipod comes up then I reset it and the apple icon comes up then it goes back the sad ipod
i have th same prob..
it turns on, starts clicking, then shows frowny face ipod, then a website is shown, then turns off........
helpppp
how did urs brake?!?
Oct 02, 2008 | Audio Players & Recorders
Sad face icon
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Dec 06, 2007 | Apple iPod MA446LL/A MP3 Player
IPod does not charge
Search for 'The iPod battery Unplugged' it will probably help you diagnose the problem cheaper than apple will
Nov 27, 2007 | Audio Players & Recorders
My ipod has a sad face icon and the famous 5 r's did not take care of my problem.
Unfortunately, it means your iPod's hard drive is severely damaged. Try putting it into disk mode and formatting it with windows, sometimes that'll take care of bad sectors on the drive and MIGHT make it usable again. It's either that or take it back to Apple to have them fix it.
Nov 13, 2007 | Apple iPod MA446LL/A MP3 Player
272 people viewed this question
 Grubhead
Grubhead
