Question about Arris SURFboard SBG900 Wireless Router (DHSBG900)
Password for setup program lost /WEP-key??
Hey guys, I got a Motorola SBG900E SURFboard. The problem is that I lost the password to get to the setup program.But I have to get there to find out my WEP-key to use the WLAN with another laptop. Is the only possiblity to find out the WEP-Key to run the setup program of the SBG900 or is there any other way?Please help me, cause I'm going nuts. Installing the modem once again doesn't solve the problem....
  • nashuakalil Mar 29, 2009
    Some time ago, a friend put password protection on my Motorola SBG wireless router. He didn't write it down and forgot it. When friends come over to visit, I want them to have internet access. I saw the reset advice you gave, connected the modem to the laptop via usb, and hit the reset button (I think!) I got the window up, type in "admin" and "motorola" and go nowhere. What am I doing wrong?!
  • 4 Answers
If by set-up program you mean 192.168.0.1, then the default password is "motorola" and username is "admin" from there you should be able to see everything you need. If you changed it from the defaults, then you might have to reset the SBG900 to factory defaults by pushing and holding the small reset button on the SBG900.
I never had to run any "setup program" to get mine working, just plug and play. If you did need to install additional software then you might have problems that I am unaware of. Hope I was able to help.
Posted on Nov 15, 2008
I have a Motorola SURFboard Gateway SBG6580 modem. I want to use the wireless for my DS lite but it says that I need an WEP key, but I don't know how to enable it. Help!
Your wireless is set up with a password. You need to get that password before you can connect any more devices. From a computer that can connect to the internet go to 192.168.0.1. Then type admin for the username and motorola for the password. I believe from there you click Wireless then click Primary Network. You should see your wireless network name and password from there. I'm getting this from the modems manual here: http://www.midcocomm.com/_files/files/SBG6580.pdf
Oct 16, 2012 | Arris SURFboard® SB5101 Cable Modem
We have a SBG900E but have lost the password. If we hold the reset button will it go back to factory settings allowing us to rename and repassword?
Is that a Motorola router? Usually when you press the reset button on the router everything does go back to factory settings... Another question, what password did you loose the wep password or the password to access the routers settings? Let me know if this solved the problem and good luck..
Sep 09, 2011 | SMC : Cable/DSL Broadband Router...
Hi, I have a new Moto SurfBoard 5101U and I just set it up. But when I try to connect to it wirelessly, it asks for password? Where can I find one? thanks.
By accessing to the configuration page of the cable modem, you should have a wireless settings section. You will find the password there. It will either be a Wep Key or a WPA password.
Apr 26, 2011 | Arris SURFboard SB5101 Cable Modem
Set up wireless security
1 On a computer wired to the SBG900 USB or Ethernet port, open your web
browser (for example, Microsoft Internet Explorer)
2 Type http//:192.168.100.1 and press ENTER to display the login window:
3 In the User ID field, type admin (case sensitive) and press TAB.
4 In the Password field, type motorola (case sensitive) and click Log In to
display the SBG900 Setup Program main window:
As soon as your network is operational, run the SBG900 Setup Program to:
"Wireless Network Setup"
For a LAN with one or more wireless clients, enable wireless security on the SBG900.
After enabling wireless security on the SBG900, as required on each wireless client:
> If you disabled ESSID broadcasting on the SBG900, set the client Network
Name (ESSID) identical to the ESSID on the SBG900.
> If you enabled WEP on the SBG900, set the client WEP key identical to the
WEP key on the SBG900.
> If you enabled Allow Only Listed Stations Access, be sure the MAC
address for each client is correctly listed on the SBG900.
Dec 22, 2010 | Arris SURFboard SBG900 Wireless Router...
Change wep password for a motorola sbg900
you can chane the wep key or network key by simply accessin the router paGe and on the wireless settin chane the wep key with your desired passowrd
to access the router just key in 192.168.100.1 on the address bar
the default usename: username and the password: motorola
wireless settins is located on the left of the paGe
Jul 24, 2010 | Arris SURFboard SBG900 Wireless Router...
Where do i find the wep? i am tryin to connect my ps3 to the wifi.
HI,
Please go to one of the computer which can go online
browser (for example, Microsoft Internet Explorer or Netscape
Navigator®).
now you would be able see your WEP key
Hope it can resolve your issue
Thanks for using Fixya
Apr 19, 2010 | Arris SURFboard SBG900 Wireless Router...
Can't set up my security password for my Motorola sbg900 on mac
You don't need your disk to do this you need to type http://192.168.0.1 into your web browser. this will access your your modems setup program. your default user name will be "admin" and password will be "motorola" as long as you haven't changed it.. you can read in your manual how to set up your wep key from here on in. if you need to download the manual give be a bell and i will post it on my web page for you.
hope this helps
Aug 20, 2009 | Arris SURFboard SBG900 (49402201900) Modem
WEP security setup on SBG900
If you set a WEP security connection, of course you will be kicked out of your connection. You have to re configure your laptop to gain access to your WiFi, inserting the new password you set the WEP with... Hope this helps
Jun 02, 2009 | Arris SURFboard SBG900 802.11g/b...
Cant access the cinfiguration
In your browser's top window type:
http://192.168.0.1
or try
http://192.168.1.1
If it is new, try :
user: admin
pasword:password or password1 or admin
May 03, 2009 | Arris SURFboard SBG900 (49402201900) Modem
Wep key
Try admin for the username and motorola for the password.  The default SSID is Motorola.  Here is the pdf with all of this info.
http://broadband.motorola.com/consumers/products/SBG900/downloads/SBG900_Quick_Install%20_Guide.pdf
Apr 24, 2009 | Arris SURFboard® SB5101 Cable Modem
Arris SURFboard SBG900 Wireless Router (DHSBG900) Logo
1,077 people viewed this question
Top Arris Computers & Internet Experts
Suddenlink Help
Level 1 Expert
 John
John
richie46
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
