Question about Sanyo DP32746 32 in. LCD Television
Television has audio but no video
I woke up a couple days ago, and my television wasn't workig properly. You can hear the sound, but there is no picture. It was working the night before. I turned it off, as usual, and attempted to turn it on the next morning, and there was no video, but the sound is still working. Do you have any suggestions on how to fix this problem.
  • 1,139 Answers
Hello blondemommy0,
This sounds like your inverter or back-light has gone out. What you can do to test this is to turn the TV on and then turn off all of the lights until the room is dark. Then shine a flashlight at an angle on the screen and see if you can see a picture. If you can the back-light and or inverter has malfunctioned. If this is the case, then I would suggest that you have a qualified TV technician fix this problem, but first ask for a estimate because the inverters and back-lights are sometimes part of the screen and is it is you might as well buy a new TV.
I hope this helps,
Thank you,
Electron-Age Technologies LLC
Posted on Nov 28, 2008
Just baught a used saround sound speaker system and have no manual to show us how to hook it up and where the conection wires are supose to conect to my television
Without knowing its model number and that of your television this answer has to be very general. Generally speaking you would connect a television to a surround sound system from the television's audio outputs to one of the surround sound system's auxiliary inputs. However most televisions do not have outputs. If your television fortunately has one, then you'd proceed to connect either the red and white RCA audio cable or the digital audio out one depending upon your television's capabilities. The RCA connection though just stereo sound is more reliable as the optical cable's performance can be iffy, and can have a lot of conditions that'll end up with it not working most of the time. The way I have mine set up is I connect all of my devices to the television with a video cable and then separately connect all of them to the surround sound system with an audio cable. Then to hear the sound from the various devices I press my function button on my remote or surround sound system to switch between FM radio, the set top box, and the dvd player.
Sep 21, 2011 | Audio Players & Recorders
No sound in television
Go to your menu.
go to sound or audio. look for any audio output options and disable them.
Does your audio go out while you watch antenna tv or when you watch a dvd/game?
Aug 06, 2008 | Televison & Video
TV picture goes out after 10 minutes of viewing with popping sound
It can be a couple things. Something bad on the power board. Or the vertical output circuit. How long ago did you purchase the television. Your best course of action is to have it serviced.
If you need any information or other assistance let me know.
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Tv has sound on all channels but one. Had sound but 30 min later no sound. When watching two tv's on same channel the one with no sound was lagging behind other tv not in sync as all other tv's in house...
Check to see if your audio source is set to SAP. This stands for secondary audio program. For example, some stations broadcast english and spanish. Some stations broadcast english and nothing. If you are on a channel that broadcasts english and nothing, and you are SAP setting, you will hear nothing.
Jul 03, 2010 | Sony KDF-E42A10 42 in. LCD Television
My tv is flashing like a strobe light, a blue like color and I can hear the sound coming from the speakers. Not sure what the problem is...need new lamp?
More than likley YEP! Contact an audio/video store that carries your brand of television to see if they can order a lamp for you. They are not cheap. Get a couple of quotes on price and availability if you can before you drop your $.
Aug 05, 2009 | Televison & Video
Protron PLTV26 - Only Audio but No Video
Hi jnks2005, We need to check your backlight, while tv is on and you have sound, take a flashlight and shine it on the screen, look very close and see if you can see a dark video image, If so you have a bad backlight inverter. You can try to unplug your tv for a couple of hours and let it reset but it is most likely the inverter. Let me know what you see and I can help you locate parts and instruct the replacement. Please rate this solution. lone99star
Jan 11, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
Convergence problem wiht jvc av 48wp30
Bad chips...There are a ton of cheap fakes out there....Or bad resistor...
Projection TV sets have several common problems listed below.
Problem #1) Convergence
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
Sep 29, 2008 | JVC AV-48WP30 48" Rear Projection...
No sound on four channels while all other channels sound is fine.
You most likely have the SAP1.gif mode activated. Look for a button on your remote or an item in the on-screen menus of your television1.gif called MTS or SAP. You want to set this to "Main" "Normal" or "Stereo" (or even "Mono") mode to hear the regular television sound.
If it is in SAP (Secondary Audio Program) mode, as I believe yours is, you may hear no sound or a different audio program. Often this is a translation to another language, such as Spanish, and other times (notably with PBS stations) it is an unrelated audio (often music) feed. On some stations there may be no sound at all with the audio mode set to SAP.
Feb 14, 2008 | Sharp Aquos LC-13SH3U 13 in. EDTV-Ready...
No sound
That is a good clue. Sounds like there is a bad connection in the audio circuitry. Does the audio output still work? The second thing I would do is visually inspect the solder joints in the area of the audio circuitry for anything suspicious.
Dec 28, 2007 | Protron PLTV-32 Television
Sanyo DP32746 32 in. LCD Television Logo
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
