Question about Zenith IQB64W10W 64" Rear Projection Television
Picture is off center, (skewed to the left)
I am proficient in converging the PRO900X and have the Service remote, but I cannot get it to work with the IQB64W10W. Oddly, the internal convergence cross hairs are centered, but the actual image is off center, regardless of source/input.
I don,t have an anwser for you but if you are going to get rid of your set I would be willing to buy a board out of your set.
Posted on Mar 06, 2008
Convergence does not work. Black spot in corner of picture
Convergence will not cause the black spot--picture will look 3d or colors skewed, confirm model please and a clear idea of what set is doing or not.
Oct 14, 2012 | Sony KP-65WS510 65" Rear Projection...
RCA hd52w67 analog convergence problem.
with Tv off press and hold ch- and vol- at same time untill tv turns on then release and you should be in factory settings service mode.
May 26, 2010 | Televison & Video
My big screen panasonic tv has a double fuzzy picture what am I supposse to doto fix it
Adjust the convergence or reset it to factory default. Use only the remote when adjusting convergence. The front controls have no effect.
  1. Press action button to enter MENU.
  2. Navigate to SETUP.
  3. Scroll down to CONVERGE.
  4. Press VOL > to select.
  5. Press CH buttons to navigate up or down.
  6. Choose CONVERGENCE ADJ or RESET TO DEFAULT.
  7. Press VOL > to select.
  8. If CONVERGENCE ADJ is selected the align Green to Center screen will be displayed.
  9. Use the navigation buttons on the remote control to align the horizontal and vertical green lines on screen, with the cabinet reference marks on top center and left
    center of cabinet.
  10. Press ACTION button to display red center correction screen.
  11. Use the navigation buttons on the remote control to align the red cross with the white cross pattern at the center of the screen. To prevent picture tube damage do not leave test pattern on for an extended period of time.
  12. Press “0” on the remote control keypad to display the BLUE center correction screen, repeat procedure for adjusting blue. If needed press “0” again to return to RED correction screen. An adjusted cross pattern appears white with a minimum of color protrusion.
NINE POINT CONVERGENCE CORRECTION
Remote Control must be in TV mode.
  1. Press ACTION button to display red correction screen.
  2. Press the 1 through 9 keypad buttons on the remote control to select the desired convergence position.
  3. Use the navigation buttons to align the RED cross with the white cross pattern.
  4. Press “0” on the remote control keypad to display the BLUE correction screen, then repeat procedure.
  5. To exit press ACTION button repeatedly, then press CH up.
Nov 07, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Hitachi 65F59 65-Inch CRT Projection HDTV picture skewed.
The convergence output IC's have failed and need to be replaced. Sometimes when they go biasing resistors burn open also. These are large amplifiers mounted to heat sinks and have as many as 18 pins soldered into the circuit board. Better be handy at desoldering even if it's only the IC's that are bad.
Jul 10, 2009 | Hitachi Televison & Video
Skewed picture
you need ned convergance chips
Mar 22, 2009 | Mitsubishi VS-60621 60" Rear Projection...
Center Target Blue Convergence and Contrast Adjustment
Yes there is a Service Code you have to have to get into Alinement menu and its a Dog following step by step to get in! (1) Turn set on cable (2) Turn sleep timer on 30 min (3) Press Action Twice exit menu 4) now tune to ch 124 (5) adjust vol half way down (6) Now Press vol- on front of TV ,now you should see a RED chk appear in upper corner (7) Now Power on remote hand unit and you shiuld be in menu Press cursor to move Mute locks where you want to aline ADJUST with vol-,Vol+ ch- ch+ for up&down back and forth.If you need anymore help let me know .
Press R-tune to change R-G-B
Dec 25, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Phillips 43pp92 0217
Sorry to bother you again but I did some research and the chip numbers are STK 392-120 but using STK 392-180 is recommended replacement. If the picture is bowed or skewed any at all then the chips are needed replace both and check if any 6.8 ohm resistors are burned or open. Resistors Can be measured out of circuit with a digital volt-ohm meter. Have you tried the consumer menu and located the convergence adjustments? If it only need touch up you should go there. And the numbers I gave you 062597 must be followed with pressing the status button on the original remote. this goes into the service menu and adjustment to convergence can be made there also if touch up is needed or after you replace the chips Hope this helps
Dec 30, 2007 | Televison & Video
Red convergence is bad.
Hi, you need to change the convergence ICs , STKs: and some resistors,low values; , after changing them, you will have to go into the service mode, to do some adjustments.that's it.
Nov 27, 2007 | Samsung HCN4226W 42" Rear Projection...
Convergence problem, lower left corner fixed green gun convergence bows upward
You have a componet out of tolerance in the green drive circuits, resistor or capacitor. If you have the service manual you should be able to take some raedings off the test points for the circuit and be able to track it down. I am enclosing a link where you can purchase the service manual for that set for 10.99. They will mail it to you unless you go back to the site and request that they email it to you by clicking on the contact us link. They also offer unlimited free support if you purchase your manual. I am one of their support techs. Hope this helps. Heres the link
http://servicemanuals.vstore.ca/
Dec 27, 2006 | Pioneer PRO-119 60" Rear Projection...
Zenith IQB64W10W 64" Rear Projection Television Logo
118 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
