Network adapter kann nicht gefunden
Huh? I only understood Network Adapter.
If you're connected to the LAN with a network cable then you will not see an SSID. The purpose of the SSID is so that a wireless device can see it and connect to the correct network.
You've got some other issues going on with the Network Connection.
Let's start with Internet Options. If you have Windows XP Click Start/Control Panel/Internet Options. If you have Windows Vista or Windows 7 click Start/Control Panel/Network and Internet/Internet Options.
When the Internet Options window opens on the General Tab make sure you have a valid web address as the Home Page. If not, create a simple Home Page by typing:http://www.google.com You don't have to click OK now because if you do the Internet Options window will close.
Click the Security Tab and under where it says "select a zone to view or change settings" Click on the one that says Internet, then scroll down to near the bottom right and make sure that DEFAULT is grayed out (whereas you cannot click on it). You can Click on Default just to be sure. Next click the Intranet so that it is highlighted and make sure DEFAULT is grayed out so that you cannot click on it. Do the same thing for the other two zones (Trusted Sites and Restricted Sites). After all zones under the Security Tab are set to Default click the next Tab which is the Privacy tab.
On the Privacy Tab you want to make sure that DEFAULT is grayed out, if not click on it. When in doubt just click the Default tab.
Next skip over the Content tab and proceed to click the Connections Tab. On the Connections Tab make sure that the Never Dial A Connection is checked if you have something in the white box above it in for Dialup and Virtual Private Networks settings. Look down on the right near the bottom and Click the LAN SETTINGS button. When Lan Settings open up the only box that should be checked is the very first box that says: Automatically Detect Settings. If any other box is checked remove the check from it or you will never be able to connect. Click OK to close the LAN SETTINGS tab.
Next skip over the Programs tab and click the Advanced tab. When it opens slide the blue bar on the right all the way down until you get to the bottom of the window. You want to be able to make sure that if you see something like (Use SSL 2.0, Use SSL 3.0, Use TSL 1.0) that you put a check in the box to the left of each one of them. Afterwards you can click OK to close the Internet Options Window.
Next lets go boot your computer in Safe Mode.
Go to www.google.com and in the search box type:"Download cnet Malwarebytes" (without the quotes). Download andinstall malwarebytes from the sites download.cnet/malwarebytes. When thesite opens up click on the Green Download button on the left. Do notclick the Red Download button, that's junk. When it finishes installing the GuiInterface will open up with an offer to Accept a Trial Version orDecline. CLICK DECLINE you want the totally free version. Run aQUICK SCAN. As it scans, if it finds infections the number will be inred. When it finishes scanning, click SHOW RESULTS. A notepad textdocument will open up showing you the results. You can close the textdocument and go back to the Gui Interface where you will click
If after all this you still can't get on Open the Internet Options again then select the Advanced tab and click the Reset Tab near the bottom to reset Internet Explorer to the Default Settings.
SOURCE: Datenrettung von Festplatte
Hi and welcome to FixYa,
To copy the contents of the hard disk of the Dell Inspiron 6000 before reformatting/re-installing a new/fresh Windows XP, try to:
Good luck and Thank you for using FixYa.
SOURCE: ich habe Toschiba tecra a8 bei start jetzt
Im not sure i understood all in German ...but I guess you are talking that you have a BIOS password that you do not know ...and you need access that it is denied cause of this password..
To get rid of it ..you will have to open the computer ..and get to the motherboard and remove the Bos battery for a few seconds..This will remove any passwords and reset it to the factory optimal defaults..
I will try to translate in German the basic part ..
?ffnen Sie den Laptop und entfernen Sie die BIOS Batterie seit ein paar Sekunden.. STELLEN SIE es .. ZUR?CK und schlie?en Sie es.. Das wird das Kennwort entfernen..
SOURCE: Hallo! Samsung R60 plus, Nachdem ich
Ihr Samsung R60 plus hat Problem beim Anbringen von Fenstern 7 angetroffen. Es ist der Grund, warum die Funktionstasten und andere Anzeigeformate beeinflu?t werden. Versuchen Sie, Ihr Festplattenlaufwerk wieder zu umformatieren und Fenster 7 wieder zu installieren
SOURCE: Meine Webcam funktioniert nicht richtig
Usually you have to set the webcam in your messenger's options. There might be a default setting that doesn't allow you to connect.
My wireless doesnt work, my Lan does. I cant find my SSID and therefore cant type in my password either. Yes the settings in my Router are correct (SSID hide is unticked).
I downloaded the newest drivers for my Acer Aspire TimelineX 4820T and when I try to install the settings again. I get the message, there is already a wirles under this name. So this tells me that its working but I just cant find it.
I fixed my problem.
My router was incorrectly set. I have a dsl televison/ internet and my phone company said I should set the bandwith from a-b-g-n. I changed it to b-g-n and my wireless worked right a way. Now I called my provider and they told me that since you are working with windows and lion you should also change your channel from automatic to 9. They said Mac works best on a 1 digit channel. They also told me to change my key from WPA2 to WPA1/2? Does anyone understand why this works?
